    LoPy to LoPy over WIFI, socket Exception <class 'OSError'> -1
    lopywifiwifi send dataoserrorlopy4
    3 Posts 2 Posters 311 Views 2 Watching
      goro
      Hi, I'm triying to connect 2 loPy's over Wifi to send information but I get this error:
      <class 'OSError'>
      -1
      This is the code I'm using:
      wlan = WLAN()
      wlan.deinit()
      wlan = WLAN(mode=WLAN.STA)
      for i in range(sendRetry):
          nets = wlan.scan()
          for net in nets:
              if net[0] == connectTo:
                  wlan.connect(ssid=net[0], auth=(net[2],"witeklab@2018"),bssid=net[1])
                  while not wlan.isconnected():
                      continue
                  print(wlan.ifconfig())
                  break
              print(connectTo+" not found")
          if wlan.isconnected():
              break
          pycom.rgbled(0x00000f)
          sendInfo(wlan)
          wlan.disconnect()
      def sendInfo(wlan):
          sock = socket.socket()
          try:
              fullpath = "/flash/registry"
              ficheros = os.listdir(fullpath)
              if len(ficheros) > 0:
                  print("______START______")
                  ip, subnet, gateway, dns = wlan.ifconfig(id=0)
                  port = 80
                  add = socket.getaddrinfo(gateway, port)[0][-1]
                  print(socket.getaddrinfo(gateway, port))
                  print("connecting socket to ->",add)
                  sock.setblocking(True)
                  sock.settimeout(1)
                  sock.connect(add)
                  print("socket connected")
                  #rest of code is not executed
          except Exception as e:
              print(type(e))
              print(str(e))
          finally:
              sock.close()
      And this is the output:
      ('192.168.4.2', '255.255.255.0', '192.168.4.1', '192.168.4.1')
      ______START______
      [(2, 1, 0, '', ('192.168.4.1', 80))]
      connecting socket to -> ('192.168.4.1', 80)
      <class 'OSError'>
      -1
      Thank you
        robert-hh @goro
        @goro Do you have a matching socket.accept() open at the device you want to connect to?
          goro
          Indeed we have the "socket.accept ()" method in the first LoPy, but the problem was in the pointing address to the other LoPy which was wrong.
          It's already solved, thank you!
