    Bricked?
    fipy
    8 Posts 6 Posters 554 Views 6 Watching
    • M Offline
      misterlisty
      Im getting this from my fipy?
      flash read err, 1000
      ets_main.c 371
      ets Jun 8 2016 00:22:57
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      ets_main.c 371
      Is it broken? Is so how do i return for replacement? I have 2 doing this?
        robert-hh @misterlisty
        @misterlisty Since the devicve is complaining, it is not dead. Try to re-flash the firmware. Maybe you loaded the wrong firmware to the device. Also: check cables, power supply, ...
        • M Offline
          misterlisty
          Tried reflashing but something is wrong...sometimes it connects ie serial com working..sometime scrambled characters
            @misterlisty That looks like an interface problem. Do you use an expansion board? Maybe that is broken or has broken or worn contacts.
              jcaron @misterlisty
              @misterlisty How are you powering the FiPy?
                Dylan
                Was this issue resolved? I am having the same problem with the lopy4.
                • B Offline
                  bbernaud @Dylan
                    Colateral
                    I had the same issue on LOPY4 boards and seems is related with the watchdog.
                    If the watchdog is started and you do P2+GND (bootloader mode) then press reset... always you got this cycled error.
                    The workaround is to put P2+GND (bootloader mode) and unplug then plug power
                    The issue is reproduced on several boards with LOPY4.
