Need Help to connect NB-IOT 1nce / Germany
Hello togehther, I need help.
I have multiple FiPy Boards with and without expansion board try´d.
I have used two 1nce SIM-Cards. The cards working good. and its a NB-IOT Contract.
FiPy Rev. 1.2 RMA from Pycom
Modem Firmware is already updated to DUP NB1-41019
LTE-Antenna is connected
SIM-Card is correctly plugged in.i have try multiple NB-IOT connection Scripts. no ones run.
i have running the script multiple hours inside and outside of the House.any Ideas and Hints?
Sysname: FiPy Release: 1.18.2.r3 Version: v1.8.6-849-a1641ca on 2019-02-28 Machine: FiPy with ESP32 Query LTE modem imei... 35434********** Query SIM iccid... 89882*************** Sent to modem: 'ATI1', delay 1000 ms UE6.0.0.0 LR6.0.0.0-41019 OK Sent to modem: 'AT!="showver"', delay 1000 ms SYSTEM VERSION ============== FIRMWARE VERSION Bootloader0 : 5.1.1.0 [39529] Bootloader1* : 6.0.0.0 [41019] Bootloader2 : NA NV Info : 1.1,0,0 Software : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15 UE : 6.0.0.0 COMPONENTS ZSP0 : 1.0.99-3171 ZSP1 : 1.0.98-3170 OK Sent to modem: 'AT!="RRC:setDbgPerm full"', delay 1000 ms OK Sent to modem: 'AT!="RRC:showcaps"', delay 1000 ms == CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 1 -- EUTRA bands -- . supported : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1 . board : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66 . admin : . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================ OK``` -
@svonbentzel Did you setup the AP?
Something like 'AT+CGDCONT=1,"IP","internet.nbiot.telekom.de"' ? -
@Elizar Hello, Yes I think ;)
from network import LTE import time lte = LTE() lte.attach(band=8, apn="iot.1nce.net") while not lte.isattached(): time.sleep(0.5) print(".", end="") print("\nAttached!") print(lte.send_at_cmd("AT+CSQ")) lte.connect() # start a data session and obtain an IP address while not lte.isconnected(): time.sleep(0.5) print("-", end="") print("Connected!")Second Script:
import os from network import LTE import usocket import time def send_at_cmd_pretty(cmd, delay=1000): response = lte.send_at_cmd(cmd, delay=delay).split('\r\n') print('Sent to modem: \'{}\', delay {} ms'.format(cmd, delay)) for line in response: if line.strip() != '': print(line) # Print module details un = os.uname() print('Sysname:', un.sysname) print('Release:', un.release) print('Version:', un.version) print('Machine:', un.machine) # Initialize LTE object lte = LTE() time.sleep(5) # Pre attaching debugging print('Query LTE modem imei...', lte.imei()[:5] + '*' * 10) print('Query SIM iccid...', lte.iccid()[:5] + '*' * 15) send_at_cmd_pretty('ATI1') send_at_cmd_pretty('AT!="showver"') send_at_cmd_pretty('AT!="RRC:setDbgPerm full"') send_at_cmd_pretty('AT!="RRC:showcaps"') time.sleep(5) send_at_cmd_pretty('AT+SQNCTM?') # Attach LTE print('LTE attaching...') lte.attach(band=8, apn="iot.1nce.net") attempts = 0 while not lte.isattached(): time.sleep(5) attempts = attempts + 1 print('Attaching...', attempts) if attempts % 15 == 0: send_at_cmd_pretty('AT+SQNMONI=9') send_at_cmd_pretty('AT+CEREG?') send_at_cmd_pretty('AT+CFUN?') send_at_cmd_pretty('AT+CSQ') send_at_cmd_pretty('AT!="showphy"') send_at_cmd_pretty('AT!="fsm"') print('LTE attach succeeded!') # Debug attached state send_at_cmd_pretty('AT+CEREG?') send_at_cmd_pretty('AT+SQNMONI=9') send_at_cmd_pretty('AT+CSQ') send_at_cmd_pretty('AT!="showphy"') send_at_cmd_pretty('AT!="fsm"') send_at_cmd_pretty('AT+CGPADDR') send_at_cmd_pretty('AT+PING="8.8.8.8"', delay=5000) # Connect LTE lte.connect() attempts = 0 while not lte.isconnected(): time.sleep(5) attempts = attempts + 1 print('Connecting...', attempts) print('LTE connection succeeded!') # Test DNS try: usocket.dnsserver(0, '8.8.8.8') usocket.dnsserver(1, '1.1.1.1') usocket.dnsserver() print(usocket.getaddrinfo('www.google.com', 80)[0][-1]) except Exception: print('DNS over NB-IoT failed...') # Shutdown LTE print("Disonnecting LTE ... ") lte.disconnect() print("Detaching LTE ... ") lte.dettach() print("Shuttting down LTE...") lte.deinit() -
@svonbentzel The first script is the one I uss too for testing and it works. Only I have a different firmware version:
Pycom MicroPython 1.20.0.rc10 [3911a85-dirty] on 2019-04-17; FiPy with ESP32
Edit: updated to:
Pycom MicroPython 1.20.0.rc11 [55accd1-dirty] on 2019-05-24; FiPy with ESP32, same good state. -
