    Using Pybytes with FiPy, NB-IoT and Vodafone Sim from GoInvent London event
    fipynb-iotvodafonegoinventpybytes
    4 Posts 3 Posters 566 Views 3 Watching
      thinginnovations
      There was mention that the sim included with the FiPy was of limited connectivity due to the way the apn has been setup and that it was possible to use it with Pybytes with some fiddling somehow. The details for this were not shared, presumably because we ran out of time and the NB-IoT service wan't 100% available at the time and in that particular location.
      I now have the FiPy NB-IoT working a lot better from where I am now and would like to be able to access data that is being sent otherwise it's not going to be useful at all. I know there are others interested in achieving this.
      Andrew
      • H Offline
        hayesey
        I have got it working this evening, the code I used is here, it's basically the pybytes getting started example with a couple of lines added to tell it to use LTE. Add to pybytes as a "wifi" device and update to the latest pybytes firmware using the pycom firmware uploader. Firmware version I'm using is: 1.18.2.r6.
        # Import what is necessary to create a thread
        import _thread
        from time import sleep
        # Increment index used to scan each point from vector sensors_data
        def inc(index, vector):
            if index < len(vector)-1:
                return index+1
                return 0
        # Define your thread's behaviour, here it's a loop sending sensors data every 5 seconds
        def send_env_data():
            idx = 0
            sensors_data = [0, -0.2, -0.5, -0.7, -0.8, -0.9, -0.9, -0.9, -0.8, -0.6, -0.4, -0.2, 0, 0.3, 0.5, 0.7, 0.8, 0.9, 0.9, 0.9, 0.8, 0.6, 0.4, 0.1]
                # send one element from array `sensors_data` as signal 1
                pybytes.send_signal(1, sensors_data[idx])
                idx = inc(idx, sensors_data)
                sleep(5)
        pybytes.set_config('lte', { "band": 20, "apn": "ep.inetd.gdsp", "reset": True})
        pybytes.set_config('network_preferences', ["lte"])
        print(pybytes.get_config)
        pycom.nvs_set('pybytes_debug', 1)
        # Start your thread
        _thread.start_new_thread(send_env_data, ())
        There's a couple of extra lines of debug which can probably be removed.
        Once uploaded, I saw the connection in the pymakr window:
        and in pybytes:
        K 1 Reply Last reply Reply Quote 1
        • H Offline
          hayesey
          • K Offline
            KK @hayesey
            @hayesey I am looking for a SIM card NB-IoT enabled in the UK. Could you let me know how you get your SIM card, or where I can find one please?
