    Adding information to _make_node_packet(...)
    lorawanlorawan nano gwttn gatewayttn lopybattery
    1 Posts 1 Posters 196 Views 1 Watching
      crispycrafter
      I am currently setting up a lorawan nanogateway ( in preparation for my pygate) .
      The nanogateway is implemented on a Lopy4, using the default nanogateway.py code supplied by pycom.
      My use case does however require that I use solar to power the gateway and nodes. Currently the setup is working smoothly, however I have no way to inspect and send the gateway voltage via Lora > TTN > DB
      I have tried modifying the nanogateway code as follows:
      from machine import ADC
      def __init__(self):
            self.voltage_pin = ADC().channel(pin='P18', attn=ADC.ATTN_11DB)
      def get_battery_voltage(self):
             # Get pin 18 voltage using voltage devider
              R1 = 47*1000
              R2 = 100*1000
              battery = self.voltage_pin.voltage()*(R1 + R2)/R2
              return battery/1000
      def _make_node_packet(self, rx_data, rx_time, tmst, sf, bw, rssi, snr):
              bat = self.get_battery_voltage()
              RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6])
              RX_PK["rxpk"][0]["tmst"] = tmst
              RX_PK["rxpk"][0]["freq"] = self._freq_to_float(self.frequency)
              RX_PK["rxpk"][0]["datr"] = self._sf_bw_to_dr(sf, bw)
              RX_PK["rxpk"][0]["rssi"] = rssi
              RX_PK["rxpk"][0]["lsnr"] = snr
              RX_PK["rxpk"][0]["data"] = ubinascii.b2a_base64(rx_data)[:-1]
              RX_PK["rxpk"][0]["size"] = len(rx_data)
              RX_PK["rxpk"][0]["gw_voltage"] = bat
              return ujson.dumps(RX_PK)
      Conceptually this works well as I receive gw_voltage in my terminal over pybytes:
      (Battery not connected value expected to be <0V)
      However gw_voltage is not present on TTN.
      How can I go about fixing this? Or is there an alternative approach?
      Thanks!
      Re: lorawan nanogateway pytrack gps
