    Testing nanogateway with lorawan devices
    lopy4lorawan otaananogatewaylorawan
    3 Posts 2 Posters 286 Views 2 Watching
      serafimsaudade
      I'm running the nanogateway example on this setup:
      (sysname='LoPy4', nodename='LoPy4', release='1.20.0.rc13', version='5bddb57-dirty on 2019-09-19', machine='LoPy4 with ESP32', lorawan='1.0.2', sigfox='1.0.1')
      I'm trying to connect some lorawan (OTAA) devices that a buy. But the nanogateway but the majority otaa joins and uplinks
      fails. But if i use a lopy4 runing the node_otaa example, the join and uplinks work well.
      Have someone run with the same issue?
      Cumps,
      Luís Santos
      mfalkviddM 1 Reply Last reply Reply Quote 0
      • mfalkviddM Offline
        mfalkvidd @serafimsaudade
        @serafimsaudade the nanogateway only supports one channel, which means it is not lorawan compliant. The lorawan devices you bought probably require a lorawan compliant gateway.
          serafimsaudade @mfalkvidd
          @mfalkvidd Hi, tks for the reply.
          Ok, that explains the problems that I have.
