    Syncing RTC To Network Time
    24 Posts 8 Posters 13.8k Views 10 Watching
      dchappel
      Documentation states:
      "The current calendar time may be set using machine.RTC().datetime(tuple) function, and maintained by following means:
      • By a backup battery (which may be an additional, optional component for a particular board).
      • Using networked time protocol (requires setup by a port/user).
      • Set manually by a user on each power-up (many boards then maintain RTC time across hard resets, though some may require setting it again in such case)."
      Does anyone have a simple way they have come up with to sync the RTC to an open network source (bullet 2 above)?
      • K Offline
        Knoahlr
        @dchappel
        In my boot.py after connecting to WiFi, I open up a socket and query the NIST servers, they provide UTC time accurate to the second. You can the parse the string and initialize your RTC from there.
        This is all you have to do. However, time will differ, unless you live on the prime meridian.
        >>import socket
        >>s=socket.socket()
        >>s.connect(socket.getaddrinfo("time.nist.gov",13)[0][-1])
        >>s.recv(1024)
        >>'\n57777 17-01-24 16:42:49 00 0 0 595.8 UTC(NIST) * \n'
        Im using an older firmware that doesn`t include the RTC class, so I have a formula to calculate the epoch time during boot and save it to a variable. This works for most applications as epoch time is more common.
        Hope this helps.
          crankshaft @dchappel
          @dchappel - to communicate with a ntp server you need the socket.sendto(), however I believe this is not implemented yet.
          Also, the rtc interrupts is not implemented yet, so you can't really power down the device int low power mode and wake it up again.
          The RTC module is there, but in my opinion it is not yet usable.
            thefebruaryman
            I have been looking at the same issue tonight and came up with this script
            # imports
            from machine import Pin
            import ustruct
            from machine import RTC
            from socket import AF_INET, SOCK_DGRAM
            rtc = RTC()
            rtc.init((1970, 0, 0, 0, 0, 0, 0, 0))
            def getNTPTime(host = "pool.ntp.org"):
                port = 123
                buf = 1024
                address = socket.getaddrinfo(host,  port)[0][-1]
                msg = '\x1b' + 47 * '\0'
                msg = msg.encode()
                TIME1970 = 2208988800 # 1970-01-01 00:00:00
                # connect to server
                client = socket.socket(AF_INET, SOCK_DGRAM)
                client.sendto(msg, address)
                msg, address = client.recvfrom(buf)
                t = ustruct.unpack("!12I", msg)[10]
                t -= TIME1970
                rtc.calibration(t)
                return t
            def pin_handler(arg):
                print("Got an interrupt in pin %s" % (arg.id()))
                pycom.rgbled(0x0000ff)
                pycom.rgbled(0x000000)
                print(getNTPTime())
                print(rtc.now())
            # use the button on the expansion board  P10
            p_in = Pin('G17',  mode=Pin.IN,  pull=Pin.PULL_UP)
            # on button push trigger pin_handler
            p_in.callback(Pin.IRQ_FALLING,  pin_handler)
            however the calibration method doesn't like it
            >>> Got an interrupt in pin P10
            Unhandled exception in interrupt handler
            File "<stdin>", line 36, in pin_handler
            File "<stdin>", line 28, in getNTPTime
            OverflowError: overflow converting long int to machine word
              livius @thefebruaryman
              @thefebruaryman
              what you got when you do?:
              print(str(ustruct.unpack("!12I", msg)[10]))
                thefebruaryman
                returns
                1485764691
                which in python I can normally
                >>> time.ctime(1485764691)
                'Mon Jan 30 08:24:51 2017'
                  @thefebruaryman
                  ok - then you succesfully got value
                  but issue is in calibration procedure
                  but i suppose you can fix problem by setting time by
                  ct = time.ctime(t)
                  rtc.init((ct[0], ct[1], ct[2], ct[3], ct[4], ct[5], 0, 0))
                    dchappel
                    Here is what I came up with (builds on Knoahlr contribution below):
                    s=socket.socket()
                    s.connect(socket.getaddrinfo("66.199.22.67",13)[0][-1])
                    r=s.recv(1024).decode()
                    s.close()
                    year = 2000 + int(r[6:9])
                    month = int(r[10:12])
                    day = int(r[13:15])
                    hour = int(r[16:18])
                    min = int(r[19:21])
                    sec = int(r[22:24])
                    rtc = machine.RTC()
                    rtc.init((year, month, day, hour, min, sec, 0, 0))
                    print(rtc.now())
                    Current time (in seconds since 1970 / UNIX time) is now available using utime.time().
                    I found that I needed to use the numeric IP address for NIST. Alpha URL gave me a timeout. Since I got it to work with numeric I didn't go back and try to understand why...
                    • K Offline
                      Knoahlr @dchappel
                      @dchappel You might want to use RegEX,
                      Assuming Current time is your response from the NIST server.
                      >>import re
                      >>CurrentTime='\n57783 17-01-30 16:14:50 00 0 0  37.8 UTC(NIST) * \n'
                      >>DateList=re.search("[0-9]+-[0-9]+-[0-9]+",CurrentTime).group(0).split("-")
                      >>DateList
                      ['17', '01', '30']
                      >>TimeList=re.search("[0-9]+:[0-9]+:([0-9]+.[0-9]+)",CurrentTime).group(0).split(":")
                      >>TimeList
                      ['16', '14', '50 00']
                      Cheers.
                        thefebruaryman
                        Ok I got it. I have to use utime for localtime method to work with the large int else you get an error.
                        import utime
                        import ustruct
                        rtc = RTC()
                            port = 123
                            buf = 1024
                            msg = msg.encode()
                            # connect to server
                            t -= TIME1970
                            tuple_time = utime.localtime(t)
                            rtc.init((tuple_time))
                            client.close()
                            utime.sleep(1)
                            getNTPTime()
                            print(rtc.now())
                          abilio
                          We've just finished adding support for a NTP (SNTP) client. Syncing time will be as easy as:
                          rtc = machine.RTC()
                          rtc.ntp_sync("pool.ntp.org") # select an appropriate server
                          By default it will resync every hour, but you can change the period by passing it as a parameter: rtc.ntp_sync("pool.ntp.org", 1200) # do it every 20 minutes
                          This feature will probably be included in the next release. Hope you'll find it useful.
                          T K R 3 Replies Last reply Reply Quote 4
                            thefebruaryman @abilio
                            @abilio that's great news and much easier to use. Cheers for the good work!
                            • K Offline
                              Knoahlr @abilio
                              @abilio Will the method sync the RTC to local time or UTC ?
                                abilio @Knoahlr
                                @Knoahlr, to UTC, but then you'll be able to set the time offset calling:
                                time.timezone(3600) # GMT +1 for the Netherlands
                                A call to time.localtime() will return the time using the provided offset. If you want the number of seconds since Epoch adjusted to the timezone, you can do something like:
                                time.time() + time.timezone()
                                Also, time.gmtime() will be included, working like time.localtime(), but without adjusting for the offset.
                                So far, this is what would be available in the release.
                                • K Offline
                                  Knoahlr @abilio
                                  @abilio Great, amazing feature.
                                  • R Offline
                                    rdixey @abilio
                                    @abilio Apparently this is not yet implemented in 1.6.1.b1 ?
                                    '1.6.1.b1'
                                    >>> os.uname()
                                    (sysname='LoPy', nodename='LoPy', release='1.6.1.b1', version='v1.8.6-450-g31ef5170 on 2017-02-15', machine='LoPy with ESP32', lorawan='1.0.0')
                                    >>> import machine
                                    >>> rtc = machine.RTC()
                                    AttributeError: 'RTC' object has no attribute 'ntp_sync'
                                    >>> import time
                                    >>> time.timezone(3600)
                                    AttributeError: 'module' object has no attribute 'timezone'
                                      abilio @rdixey
                                      @rdixey, you are totally right and I must personally apologize for it. We forgot to merge it with master just to realize it after making the release (yeah, it happened twice :( ) . I will work so is included in the next firmware release.
                                      • R Offline
                                        rdixey @abilio
                                        @abilio These new rtc.ntp_sync() & time.timezone() functions work nicely with the 1.6.4.b1 update. They are very convenient!
                                        I think there is a typo on the Utime doc page though. The first function listed there is utime.mktime([secs]), is this intended to be utime.gmtime()?
                                        Thanks for the good work on this :)
                                        L S 2 Replies Last reply Reply Quote 0
                                          livius @rdixey
                                          @rdixey said in Syncing RTC To Network Time:
                                          mktime
                                          It is standard in many languages - google for it ;-)
                                          R 1 Reply Last reply Reply Quote -1
                                            santorcuato @rdixey
                                            Its not working for me :-(
                                            Can you post a working example?
                                            Thanks!
                                            • 1
                                            • 2
                                            • 2 / 2
