    CAT-M1 and ADC interaction? Calling on EE experts
    5 Posts 3 Posters 189 Views 3 Watching
    • securigyS Offline
      securigy
      For the last few weeks I had continuous problems delivering data to the cloud using MQTT over CAT-M1. The messages were hanging up after a few transmissions. As I discovered recently the culprit was initialization of ADC (even without reading data from the sensor). I used the following code:
      def initECG(analogInputPin, voltref):
          adc = ADC(bits=12)
          print("adc: {}".format(adc))
          # Analogog Input Pin on Expansion Board 3.1 should be P13, P14, P17, P18 (G4, G5, G30, G31)
          adc_c = adc.channel(pin=analogInputPin, attn=ADC.ATTN_11DB) # •	Output Voltage: 0 - 3.3V
          print("got adc channel on P18")
          return adc_c
      and calling it:
      adc_channel = initECG('P18', 460)
      Without initializing ADC the delivery of messages worked just fine and I could send thousand messages without any problem. I discovered that this line is the one that causing problems:
      I tried using ADC(bits=10) and also tried not to use ADC.ATTN_11DB parameter, but at no avail...
      So, I thought maybe it is because the wires are not connected to the sensor...
      Is it possible? likely?
      So then I connected the sensor as I did in the past (and nothing changed since then in physical connection)
      ![Actual setup:](dd3fe8d2-37f5-4b94-b6e1-ac2fadeba10f-image.png image url)
      To my surprise when I do that, the LTE modem does not connect at all...
      I checked and re-checked the wire connections. The Expansion Board 3.1 firmware was updated from the get go, and yet, I am getting this:
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2136
      load:0x4009fa00,len:19944
      entry 0x400a05e8
      Disable MicroPython control and heartbeat of LED
        File "main.py", line 268, in <module>
      OSError: Couldn't connect to Modem!
      Pycom MicroPython 1.20.1.r1 [15b6d69] on 2019-11-02; FiPy with ESP32
      where line 268 is
      lte = LTE()
      Since I am not EE I have no idea what are possible reasons to this and how and why initialization of ADC without connected sensor can affect LTE transmissions at all... And why with connected sensor I cannot initialize LTE at all...
      HELP!!!
      • K Offline
        kjm
        Maybe;
        1. try moving lte antenna well away from the rest of the wiring
        2. try 100k resistor between p18 & sensor analog out
        3. check Vin is >3.5v
        4. check Fipy 3v3 output is 3,2-3.4v
          jcaron @securigy
          @securigy You probably didn't notice that P18 is used for communication with the LTE modem.
          Check out the FiPy pinout
          alt text
          P18 is LTE_RX on the FiPy (it is available on some of the other modules which don't have LTE). You'll have to switch to another pin.
          securigyS 2 Replies Last reply Reply Quote 1
          • securigyS Offline
            securigy @jcaron
            @jcaron Thank you a lot for telling... I am not EE and pinouts are still a mystery to me - so. No I didn't notice ;-) I simply picked up one pin out of available... Which pin should I use for getting data from analog sensor?
            • securigyS Offline
              securigy @jcaron
              @jcaron I use now P13 and it looks like it is working now...
