    Connecting to NEO-M8N GPS
    1 Posts 1 Posters 88 Views 1 Watching
    • securigyS Offline
      securigy
      So eventually I gave up on PyTrack GPS and bought GNSS 5 CLICK dev board from MicroElektronika.
      Board information
      It has NEO-M8N GPS receiver that has aGPS (Assist GPS) with cold start (Time To First Fix) of about 25 sec. By all means looks like a great device...
      My problem is I have no clue how to physically connect it to FiPy. All I know is the range of available pins on FiPy:
      [Analog Input Pins on Expansion Board 3.1 that I use for FiPy are P13, P14, P17, P18 (G4, G5, G30, G31)].
      For some reason, however, it does not look relevant in that case. The boards has I2C and UART interfaces...
      So, I'd appreciate if any EE guru can tell me what I need to do to connect this dev board to FiPy...
      EDIT Dec 22. 2019:
      I found the answer here:
      https://docs.pycom.io/firmwareapi/pycom/machine/i2c/
      which is P9 is for SDA and P10 is for SCL
      Is that correct?
      EDIT Dec 24, 2019:
      However, what is best or more simple - connecting over SCL and SDA pins (I2C) or over SPI/UART ?
