    Json fipy afer urequest
    9 Posts 4 Posters 320 Views 4 Watching
      Tgasser
      I wish you to enjoy the Christmas holiday.
      I'm coming to you because I can't get them back to you because I wish I could. I do a get on api that returns a JSON object with objects inside. I would like to retrieve the data and store it but the conversion doesn't work. Do you have an idea?
      Thanks ! :)
        andreas @Tgasser
        Dear @Tgasser,
        line 133 obviously needs an import json statement in order to be able to invoke the loads function on the module level.
        With kind regards,
        Andreas.
          Tgasser @andreas
          @andreas Sorry, I made a mistake with the picture, this is the correct screenshot : 479bfb79-7374-4990-bed7-c29d4fc53eeb-image.png
          the lib use is https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
          Thank you for your help.
            andreas
            This looks like a programming error on line 77 within your main.py. Without seeing the code, there's no way to reason about the error.
              Tgasser @andreas
              @andreas You have to look at the library I've linked to and here's my full code if it helps. Thanks :)
              lte = LTE()
              lte.init()
              rtc= machine.RTC()
              def connect_to_LTE():
                  lte.send_at_cmd('AT+CMEE=2')
                  lte.send_at_cmd('AT+CREG?')
                  lte.attach(band=8,apn="iot.1nce.net")
                  lte.send_at_cmd('AT+COPS=1,2,"26201",9')
                  lte.send_at_cmd('AT+CEREG=2')
                  #lte.send_at_cmd('AT+CGDCONT=0')
                  i=0
                  while not lte.isattached():
                      time.sleep(0.5)
                      print(".", end="")
                      i=i+1
                      if i%3 == 0:
                          print(lte.send_at_cmd('AT+COPS=1,2,"26201",9'))
                          print(lte.send_at_cmd('AT+CSQ'))
                  print("\nAttached!")
                  print(lte.send_at_cmd("AT+CSQ"))
                  lte.connect()       # start a data session and obtain an IP address
                  while not lte.isconnected():
                      time.sleep(0.5)
                      print("-", end="")
                  print("Connected!")
                  pycom.rgbled(0xd5362a) # red
              def request():
                  print("DSN :")
                  print(usocket.dnsserver())
                  usocket.dnsserver(0, '8.8.8.8')
                  usocket.dnsserver(1, '10.0.0.1')
                  flag=False
                  while(flag==False):
                      try :
                          print("Using library urequest...")
                          r= urequest.get("http://api.open-notify.org/iss-now.json?callback=?")
                          print("Return:", r.text) #r.content
                          flag=True
                          pycom.rgbled(0x7ed446) # green
                          return r
                      except OSError as err:
                          print("OUPS ! OS Error {0}".format(err))
              def deconnect_to_LTE():
                  try :
                      lte.disconnect()
                      print("Disconnected!")
                      lte.detach()
                      print("Dettached!")
                      lte.deinit()
                      print('Oups..')
              connect_to_LTE()
              r=request()
              deconnect_to_LTE()
              print(json.loads(r))
                jcaron @Tgasser
                @Tgasser please give matching source and errors/logs, and correctly format source code by putting ``` alone one a line before and after your code.
                As it stands, line numbering of the errors and your code don’t quite seem to match.
                  andreas
                  Dear @Tgasser,
                  the code you are showing should grok with the NameError: name 'json' isn't defined error again.
                  I don't see that error coming from the urequests module. At least, you didn't show any Python traceback indicating so.
                  AttributeError: 'str' object has no attribute 'json'
                  is even more strange to me.
                  Are you sure you are running only this code on the device?
                  With kind regards,
                  Andreas.
                    Tgasser
                    Thank you for your help and Happy New Year.
                    It's all code this time and well formatted.
                    from network import LTE
                    from machine import Timer
                    import sys
                    from machine import Pin
                    import usocket
                    import urequest
                    from network import Bluetooth
                    import ubinascii
                    import sys
                    import usocket
                    import urequest
                    from machine import SPI, Pin
                    from ssd1306 import SSD1306_SPI as ssd
                    import utime
                    import json
                    import ujson
                    lte = LTE()
                    lte.init()
                    rtc= machine.RTC()
                       i=0
                           time.sleep(0.5)
                           print(".", end="")
                           i=i+1
                           if i%3 == 0:
                           time.sleep(0.5)
                           print("-", end="")
                       print("Connected!")
                    def request():
                       print("DSN :")
                       flag=False
                       while(flag==False):
                           try :
                               flag=True
                               return r
                       try :
                           lte.disconnect()
                           lte.detach()
                           print("Dettached!")
                           lte.deinit()
                           print('Oups..')
                    def timestamp():
                       print(rtc.ntp_sync("0.pool.ntp.org") ) # printing None
                       timestamp = utime.localtime(utime.time()) #printing (2000, 1, 1, 0, 20, 16, 5, 1) but i would like to have  (2019, 12, 24, 12, 36, xx, xx, xx)
                       print(timestamp)
                       return timestamp
                    def is_known():
                       flag=-1
                       for i in range(0, device_found):
                           check=ubinascii.hexlify(adv.mac)
                           if (check == list_device[i][1]):
                               flag = i
                       return flag
                    def is_flower_care():
                       name=bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)
                       if(name == 'Flower care'):
                           print(name)
                           return True
                           return False
                    check_time = 60 #second
                    list_device = []
                    device_found = 0
                    spi = SPI(0, SPI.MASTER, baudrate=100000, polarity=0, phase=0)
                    disp = ssd(128,64,spi,Pin('P9'),Pin('P8'),Pin('P22'))
                    disp.text('I\'m ready',0,0)
                    disp.show()
                    connect_to_LTE()
                    r=request()
                    deconnect_to_LTE()
                    print(json.loads(r.text)) #line 134
                      crumble @Tgasser
                      @Tgasser
                      r does nor contain valid JSON,
                      The valid part is surrounded by ?()
                      If you cannot fix the web service, you have to remove the invalid part before using it as a parameter
