    Pybytes Downlink Messages
    4 Posts 4 Posters 191 Views 5 Watching
    • M Offline
      mcallistertad
      Is there a way to receive messages from pybytes? I don't see anything documented but it would be nice to enable control on the app layer.
      Something like:
      pybytes.receive_signal(topic, data)
      or even have send_signal return the last message posted to the topic when called.
        jirkakrepl @mcallistertad
        Hi @mcallistertad,
        I agree. Currently, there's no way to do it. We will discuss today and probably implement this functionality.
        On Wi-Fi/ LTE Cat m1 we could send any downlink messages over mqtt.
        on LoRa/Sigfox we need to do something else - we are constraint by bandwidth and downlink connection windows
        software developer @ Pycom
          Carl Folkesson
          Hi @jirkakrepl,
          Any update on downlink functionality over Wi.Fi/LTE?
          ahmadelmasriA 1 Reply Last reply Reply Quote 0
          • ahmadelmasriA Offline
            ahmadelmasri @Carl Folkesson
            Hello @Carl-Folkesson,
            On the latest Pybytes firmware we have implemented the downlink feature over MQTT.
            Steps:
            • Once the device is activated
            • pybytes.set_config('pybytes_autostart', False)
            • in your main.py you have to initialize pybytes
            • To send a JSON string via MQTT to the device, you need to use topic d+<device_id>
            • The message should start with 0x08h + MESSAGE example: To send {"test":"value"} the hex code is: 087b2274657374223a2276616c7565227d
            main.py Test Code:
            def callback_function(message):
                print(message)
            if (len(pybytes_config['username']) > 4 and len(pybytes_config['device_id']) >= 36 and len(pybytes_config['server']) > 4):
                from _pybytes import Pybytes
                pybytes = Pybytes(pybytes_config, user_callback=callback_function)
                if pybytes.connect_wifi():
                    # SEND PING
                    pybytes.send_ping_message()
                    # SEND DEVICE'S INFORMATION
                    # The INFO message should always be sent, otherwise, Pybytes could not be aware
                    # of some important information regarding this device, like its firmware version.
                    pybytes.send_info_message()
                    # ENABLE TERMINAL
                    # This should always be enabled if you're using firmware that is compatible with the pybytes terminal.
                    # The terminal messages will use the virtual pin (or signal) 255.
                    pybytes.enable_terminal()
                    print("Failed to connect to Pybytes! Invalid credentials or network issues?")
                print("Could not load Pybytes configuration!")
            NB: Kindly note that this is still experimental.
            Let me know if you face any errors.
            Have a nice day.
            Best Regards,
            Ahmad El Masri
            Ahmad EL Masri
