    I flashed old firmware to Pysense 2.0 boards
    7 Posts 3 Posters 61 Views 3 Watching
      prothorin
      I followed manual and flashed boards with 0.8 dfu.
      Is possible to repair ?
        sachindayma
        I got myself into the same issue. I received the Pysense 2.0 board just yesterday and in a hurry, I updated the firmware as per the instructions, not noticing the warning.
        I realized this when I tried to run the sample Pysense code and got an error of 'Firmware Out of date'. I am kind of stuck as the sample code of pysense will not work.
        Please help. Thanks
          Hi, I have the firmware revisions here:
          pysense_app_v15.py
          (the forum does not allow for .dfu uploads, so change the extension back to .dfu after downloading ;) )
          You should be able to update it like normally!
          Best
            prothorin @Gijs
            @Gijs Thanks
            One of my Pysense 2 board are start working.
            But other board have a special problem, Vin pin not connecting to Lopy vin, so no power on Lopy4.
            Checked other box and this is ok, all other pins are ok, but Vin not connecting.
              Did you insert the Lopy4 correctly? There is virtually nothing in the signal path between the USB connector and the Vin pin that can block the voltage. Other than a direct short ofcourse. Do you have loose metal bits laying around your workbench maybe?
              P 2 Replies Last reply Reply Quote 0
                prothorin @Gijs
                @Gijs I checked all pin holes,
                Two front pin holes are very loose, dont hold pin.(Vin and Pin9)
                  prothorin @Gijs
                  @Gijs said in I flashed old firmware to Pysense 2.0 boards:
                  I solved problem with a very thin copper wire, now working fine,
