Core 1 panic'ed (IllegalInstruction) before importing anything!
Hello, everyone,
I have a Wipy device (W01) running into the firmware Wipy 1.20.0.rc11,
I was testing the stability of the system by restarting it every 5 secondes.
And sometimes before importing anything, I receive this message , explaining me that I have made a IllegalInstruction.
The error:rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:2156 ho 0 tail 12 room 4 load:0x4009fa00,len:19208 entry 0x400a05f4 Initializing filesystem as LittleFS! Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x400eacfc: 0633a8c0 00000000 00000000 Core 1 register dump: PC : 0x400ead02 PS : 0x00060d30 A0 : 0x800ecb80 A1 : 0x3ffd9cf0 A2 : 0x3ffc5afc A3 : 0x00000000 A4 : 0x3f94ee54 A5 : 0x00000018 A6 : 0x000002b4 A7 : 0x00000870 A8 : 0x800945de A9 : 0x3ffd9cf0 A10 : 0xffffffac A11 : 0x00000888 A12 : 0x00001000 A13 : 0x00000001 A14 : 0x000000fe A15 : 0x3f40b302 SAR : 0x0000001a EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x4009c069 LEND : 0x4009c079 LCOUNT : 0xfffffffe Backtrace: 0x400ead02:0x3ffd9cf0 0x400ecb7d:0x3ffd9d20 0x400ee6b4:0x3ffd9d60 0x401ccad9:0x3ffd9d80 0x40108e56:0x3ffd9db0 0x401cc5df:0x3ffd9de0 0x400f2ee8:0x3ffd9e00 0x400f3a5d:0x3ffd9e30 0x400dee72:0x3ffd9eb0 0x400df10d:0x3ffd9f50 0x400ddf43:0x3ffd9f70The code :
print('------ BEGINNING ------') from machine import Pin, UART, SPI, RTC, ADC, Timer, reset print("Main.py Machine OK") from time import sleep, time, gmtime print("Main.py Time OK") from pycom import nvs_set, nvs_erase_all, rgbled print("Main.py Pycom OK\n------ END ------") reset()Thank you for everything.
I believe you are experiencing the same issues as discussed here:
https://forum.pycom.io/topic/5765/loadprohibited-core-panic-when-initialize-wlan
Can you review the discussion?
There are of course slight differences between the antennas etc. on the boards (manufacturing tolerances etc) and doing a full erase using the update firmware tool might help in that regard.Let me know!
@Gijs
I have this problem after importing the WLAN class from network
Moreover on other cards I have no problems.
Would it be a manufacturing defect ?
@Gijs
I upgraded the Wipy to the latest , and I see the most of time a LoadProhibited error------ STARTING UP ------ import sleep import reset Main.py Importation WLAN Main.py WLAN OK Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Core 1 register dump: PC : 0x400edc8f PS : 0x00060930 A0 : 0x800edcdf A1 : 0x3ffd8c90 A2 : 0x3f958390 A3 : 0x00000003 A4 : 0x3f4276a8 A5 : 0x3f427720 A6 : 0x3f428288 A7 : 0x3f4276b8 A8 : 0x00005959 A9 : 0x00009151 A10 : 0x17404004 A11 : 0x00000059 A12 : 0x00000010 A13 : 0x3f9583a0 A14 : 0x00000030 A15 : 0x00000001 SAR : 0x0000001c EXCCAUSE: 0x0000001c EXCVADDR: 0x17404005 LBEG : 0x4008e936 LEND : 0x4008e941 LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x400edc8c:0x3ffd8c90 0x400edcdc:0x3ffd8cc0 0x4010ba2e:0x3ffd8ce0 0x4010bc26:0x3ffd8d00 0x4010bcfb:0x3ffd8d60 0x4010bd89:0x3ffd8dc0 0x4010bdaa:0x3ffd8e30 0x400fd34f:0x3ffd8e60 0x400fd6ae:0x3ffd8e90 0x400f4a0d:0x3ffd8f70 0x400ffe75:0x3ffd8fb0 0x400f7a76:0x3ffd9050 0x400f4099:0x3ffd90b0 0x400f40c6:0x3ffd90d0 0x400fd2dc:0x3ffd90f0 0x400fd356:0x3ffd9180 0x400fd6ae:0x3ffd91b0 0x400f4a0d:0x3ffd9290 0x400ffe75:0x3ffd92d0 0x400f7a76:0x3ffd9370 0x400f4099:0x3ffd93a0 0x400f40c6:0x3ffd93c0 0x400d8031:0x3ffd93e0 0x400d82c9:0x3ffd9480 0x400d6dbc:0x3ffd94a0Code here :
print('------ STARTING UP ------') from time import sleep print('import sleep') from machine import reset print('import reset') sleep(1) from network import WLAN print("Main.py WLAN OK") wlan = WLAN() print("Main.py wlan Instantiation OK") wlan.deinit() print('Main.py Disable Wifi') from machine import Pin, UART, SPI, RTC, ADC, Timer print("Main.py Machine OK") from time import time, gmtime print("Main.py Time OK") from pycom import nvs_set, nvs_erase_all, rgbled print("Main.py import pycom OK") print("------ END ------") sleep(0.5) reset()
@Gijs said in Core 1 panic'ed (IllegalInstruction) before importing anything!:
@ElinhohHD said in Core 1 panic'ed (IllegalInstruction) before importing anything!:
Only 1 device shows me these errors after an average of 10 restarts
We assume here that the device must have overheated, or that a component of the device is non-functional.Did you try updating the firmware to the latest version? I do not think overheating or malfunctioning components will cause this problem.
I did this in the past but these firmwares are not stable
But nevertheless, I will try to update and see the difference between these 2 firmwares.
Can you elaborate?
I did the test on 3 different devices.
Can you elaborate?
@Gijs I have this problem that only on 1 component.
dd that this event only acts on a si
When I try to reproduce your error, it does not print the whole message,st:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2140 ho 0 tail 12 room 4 load:0x4009fa00,len:19760 entry 0x400a05bc ------ BEGINNING ------ Main.py Machine OK Main.py Time OK Main.�ets Jun 8 2016 00:22:57 rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2140 ho 0 tail 12 room 4 load:0x4009fa00,len:19760 entry 0x400a05bc ------ BEGINNING ------ Main.py Machine OK Main.py Time OK Main.�ets Jun 8 2016 00:22:57I believe it has something to do with the order of instructions, when I include only a little delay using
sleep_ms()it does print everything.
Now I still cannot reproduce your error however. Have you tried updating the firmware to the latest? (1.20.2.rc10)
Let me know!
I add that this event only acts on a single chip which has probably been too heated
