    Send SMS with Fipy in France
    sms
    6 Posts 3 Posters 139 Views 3 Watching
      almeos
      It is more than one week that I am trying to attach my Fipy to LTE M network. I finally managed to do it. And now it is more than one week that I am trying to send an SMS but with no results...
      I use AT command to send SMS. The response is "OK" but I do not receive the SMS on my mobile phone. Is it the format of the phone number?
      Can anybody help me please? Thank you for your help
      I am in France and I use Orange Network.
      >>> print(lte.send_at_cmd('AT+CGDCONT=1,"IP","simpoint.m2m"'))
      OK
      >>> print(lte.send_at_cmd('AT+COPS=?'))
      +COPS: (2,"Orange F","Orange F","20801",7)(1,"20820","20820","20820",7),,(0,1,2,3,4),(0,1,2)
      OK
      >>> print(lte.send_at_cmd('AT+COPS=1,2,"20801"'))
      OK
      >>> print(lte.send_at_cmd('AT+COPS?'))
      +COPS: 1,2,"20801",7
      OK
      >>> lte.isattached()
      True
      >>> print(lte.send_at_cmd('AT+SQNSMSSEND="0033661xxxx72", "Test SMS 1"'))
      +SQNSMSSEND: ID,8
      OK
      >>> print(lte.send_at_cmd('AT+SQNSMSSEND="0661xxxx72", "Test SMS 2"'))
      +SQNSMSSEND: ID,10
      OK
        jcaron @almeos
        @almeos You probably need to use AT+CMGF=1 to send text (by default it excepts a full PDU encoded in hex, I believe).
        See here for an example.
        Otherwise, have you tried with a +? Have you checked that your subscription actually allows sending SMS?
        A 1 Reply Last reply Reply Quote 1
          Sending SMS should be possible through the Fipy,
          Did you check with your carrier for the possibility to send SMS? I am getting the same as you, where the SNQSMSSEND gives an ID and OK response, but when i check the PyJTAG interface, it gives the
          +SQNSMSSEND: SENT ERROR,6,500
          Where 6 is the ID and 500 the error, as my provider does not allow for SMS
            almeos @Gijs
            @Gijs Thank you for your answer. I had this error message too, one or two times. I am going check with my carrier for SMS.
              almeos @jcaron
              @jcaron Thank you for your answer, I saw the example and tested it as I tested many other.
              I have tested many format of phoner number too. I am going to see my if SIM subscription allows SMS.
                almeos
                Hello, you were right, my SIM subscription does not allow sending SMS...
                So I tried with another SIM card (orange SIM card) and I managed at last to send SMS! Great!
                Thank you for your help every one.
