    Unhandled exception in callback handler
    3 Posts 2 Posters 58 Views 2 Watching
      AlganEren
      from machine import UART
      from network import Bluetooth
      import adafruit_gps
      import _thread
      def parse_and_broadcast():
              gps.update()
              if not gps.has_fix:
                  print('Waiting for fix...')
                  continue
              print('=' * 40)  # Print a separator line.
              print('Latitude: {} degrees'.format(gps.latitude))
              print('Longitude: {} degrees'.format(gps.longitude))
              print('Fix quality: {}'.format(gps.fix_quality))
              latitude = gps.latitude
              longitude = gps.longitude
              latlong = latitude + longitude
              print("latlong:",latlong)
              chr1.value(latlong)
                  #if gps.satellites is not None:
                      #print('# satellites: {}'.format(gps.satellites))
                  #if gps.altitude_m is not None:
                      #print('Altitude: {} meters'.format(gps.altitude_m))
                  #if gps.track_angle_deg is not None:
                      #print('Speed: {} knots'.format(gps.speed_knots))
                      #print('Track angle: {} degrees'.format(gps.track_angle_deg))
                  #if gps.horizontal_dilution is not None:
                      #print('Horizontal dilution: {}'.format(gps.horizontal_dilution))
                  #if gps.height_geoid is not None:
                      #print('Height geo ID: {} meters'.format(gps.height_geoid))
      def conn_cb (bt_o):
          events = bt_o.events()
          if  events & Bluetooth.CLIENT_CONNECTED:
              print("Client connected")
              print("Client disconnected")
      def char1_cb(chr,arg1=None):
          events = chr.events()
          if events &  Bluetooth.CHAR_READ_EVENT :
      uart = UART(1, baudrate=115200, pins=('P8','P4'))    #tx rx
      gps = adafruit_gps.GPS(uart)
      print('Advertising Bluetooth...')
      bluetooth = Bluetooth()
      bluetooth.advertise(True)
      bluetooth.set_advertisement(name='gps', service_uuid=b'1234567890abcdef')
      srv1 = bluetooth.service(uuid='0000000000000000', isprimary=True)
      chr1 = srv1.characteristic(uuid='0000000000000002', properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_WRITE| Bluetooth.PROP_NOTIFY, value='InitialValue')
      chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT | Bluetooth.CHAR_NOTIFY_EVENT, handler=char1_cb)
      I am using fipy over pysense. I connected external gps. I am reading on uart. I parse. I broadcast the data over ble to the terminal application. after a while I get an error from ble as below
      How can ı fix this error?
      Do you have any ideas guys?
      Can you help me?
      Thank you!!
        jcaron @AlganEren
        @AlganEren You can't write to the characteristic unless there is a client connected. You'll have to store the current connection state and only update the characteristic when you are connected.
          AlganEren
          @jcaron How can I do what you say
