    Update Firm wipy3 with expansionboardV3.1
    firmware update
    3 Posts 2 Posters 65 Views 2 Watching
      Jean Bikie
      Hi
      I tried to update my device, the update worked successfully but when I connect it to Atom, i can't more upload my code
      1 Reply Last reply Reply Quote -1
        I suggest you try the safeboot as it suggests: https://docs.pycom.io/gettingstarted/programming/safeboot/. It could be the case your wipy is still running some code that cannot be cancelled (like sleeping). Instead, you could use the firmware updater tool and click erase flash in the advanced section
          Jean Bikie
          thanks
          I tried firstly the second option you told and it worked well.
