WLAN init = core dumped?
  • I would like to be able to disable Wi-Fi, and then reenable it at a later point in time (e.g. on user input from the serial console when debugging). To achieve that I try the following:
    from network import WLAN
    wlan = WLAN()
    wlan.deinit()
    This disables the Wi-Fi and everything is fine... until I do:
    wlan = WLAN()
    wlan.init(mode=WLAN.AP, ...)
    This makes my LoPy do a core dump and restart... Does anybody know how to fix that? If I can't reenable Wi-Fi on demand, I can't disable it at all, since I'd loose the ability to upload new software to ;-)
    Best regards,
    Mads
  • I just tried it using the most recent firmware 1.6.5.b1 and it seems to work just fine now 👍
  • Mine started doing that today. Was running fine and then started doing that. Different PC though.
    Guru Meditation Error of type IllegalInstruction occurred on core 0. Exception was unhandled.
    Register dump:
    PC : 0x40191680 PS : 0x00060730 A0 : 0x800816ba A1 : 0x3ffcd300
    A2 : 0x0000f424 A3 : 0x00000000 A4 : 0x000f4240 A5 : 0x0000000c
    A6 : 0x0000002a A7 : 0x3ffd49a0 A8 : 0x00064e94 A9 : 0x00000000
    A10 : 0x00000014 A11 : 0xf4240000 A12 : 0x0072c000 A13 : 0x00000000
    A14 : 0x00000002 A15 : 0x3ffd4970 SAR : 0x00000014 EXCCAUSE: 0x00000000
    EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
    Backtrace: 0x40191680:0x3ffcd300 0x400816ba:0x3ffcd320 0x40120fe8:0x3ffcd340 0x400d821c:0x3ffcd360 0x400e0e37:0x3ffcd390 0x4011ca3a:0x3ffcd3b0 0x40085a38:0x3ffcd3d0
  • @madsdk
    same for me on Wipy2.0 and 1.6.3 firmware
    >>> wlan = WLAN()
    >>> wlan.deinit()
    I (2273759) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 1
    I (2273759) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6
    I (2273760) wifi: eb_mgmt_s_free_list i = 2
    I (2273760) wifi: eb_tx_bar_free_list i = 0
    I (2273760) wifi: eb_rx_block_free_list i = 0
    I (2273760) wifi: Deinit lldesc rx mblock:10
    I (2273760) wifi: Deinit lldesc rx ampdu len mblock:7
    I (2273760) wifi: Deinit lldesc rx ampdu entry mblock:4
    >>> wlan = WLAN()
    >>> wlan.init(mode=WLAN.AP)
    Guru Meditation Error of type LoadProhibited occurred on core  0. Exception was unhandled.
    Register dump:
    PC      : 0x4018e631  PS      : 0x00060230  A0      : 0x8010af4a  A1      : 0x3ffcfdd0
    A2      : 0x00000000  A3      : 0x3ffc864c  A4      : 0x3ffd3c94  A5      : 0x00000000
    A6      : 0x00000000  A7      : 0x3ffd0080  A8      : 0x8018e62c  A9      : 0x3ffcfd90
    A10     : 0x00000001  A11     : 0x3ffcc7c8  A12     : 0x00000c00  A13     : 0x00000000
    A14     : 0x00000016  A15     : 0x00000000  SAR     : 0x0000001a  EXCCAUSE: 0x0000001c
    EXCVADDR: 0x0000000c  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
    Backtrace: 0x4018e631:0x3ffcfdd0 0x4010af4a:0x3ffcfe00 0x401043ce:0x3ffcfe30 0x400dec7b:0x3ffcfe50 0x400dedc8:0x3ffcff00 0x400dedee:0x3ffcff40 0x400ee6ed:0x3ffcff80 0x400eabe0:0x3ffcffb0 0x400eac48:0x3ffcffd0 0x400f6730:0x3ffcfff0 0x400ee686:0x3ffd0090 0x400eabe0:0x3ffd0110 0x400eac0d:0x3ffd0130 0x400d8849:0x3ffd0150 0x400d8ae3:0x3ffd01f0 0x400d7cb3:0x3ffd0230
    uBwAAAkAAABsAQAA
    zAP9PxD9/D/AA/0/
    UP38P2AD/T/IKyMA5Dj8P+Q4/D/MA/0/3Dj8PxQAAAB0PP0/dDz9P8wD/T8AAAAA
    BQAAAMTj/D9NaWNyb1B5AClhP8DFDL8AAAAAAMAD/T8AAAAAIAUGAAUAAAACAAAA
    AAAAAIRD/D8AAAAAAAAAAAAAAAAQsfw/eLH8P+Cx/D8AAAAAAAAAAAEAAAAAAAAA
    0EtCPwAAAABIHQBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP+UOA==
    SKwOgDHmGEAwAgYASq8QgND9/D8AAAAATIb8P5Q8/T8AAAAAAAAAAIAA/T8s5hiA
    kP38PwEAAADIx/w/AAwAAAAAAAAWAAAAAAAAABoAAAAcAAAADAAAAAAAAAAAAAAA
    AAAAAAAMAAAAAAAA0A8IQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAFgAAAAAAAADOQxCAAP78P7z+/D8AAAAA
    ////fwMAAAAwWg+AAQAAAJQ8/T8AAAAAAAAAAIAA/T977A2AMP78PwEAAAD4R/w/
    sP78PwAAAAAjCwYAIAsGAAoAAAAXAAAAMP///wwAAADI7Q2AUP78PwIAAAAAAAAA
    AAAAAJAA/T8CAAAAcAD9P+7tDYAA//w/AAAAAAIAAAABAAAAIRIIQBgAAACIZghA
    CJ0JgJD+/D9AlP0/AQAAANmEDoCg/vw/8AD9PwkBAAAAAAAA8kgIgCADBgC8w/w/
    J4UOgND+/D/wAP0/QED+PwoAAADA/vw/lDz9P2w6/D+A//8CAAEAAAAAAACwyRFA
    CgAAAPD+/D/wAP0/QED+PwAAAAAAAAAAAgAAAAEAAAAAAAAAAAAAAAAAAAAKAAAA
    7eYOgED//D8BAAAAtAD9PwEAAAAAAAAAAAAAAAEAAAAGAAAAAAAAAAAAAAAZ/BhA
    AAAAAByiQD8cQPw/AAAAAOCrDoCA//w/1O0NQAEAAAACAAAAAAAAAByiQD8BAAAA
    AAAAAAAAAAAZAAAAAQAAAID//D///wAAAQAAADAB/T9IrA6AsP/8P0QwQD8BAAAA
    DwAAAAEAAAC4AP0/AgAAAAEAAAC0AP0/xEP8PyYEAAAwZw+A0P/8PwAAAAABAAAA
    AQAAALQA/T/A////AQAAAIbmDoDw//w/YD/+P7AA/T+wAP0/gAD9PxgA/T+AAP0/
    4KsOgJAA/T/AQ/w/BQAAAFAB/T+IQP4/huYOgPD//D9QAf0/wAD9PwUAAAAEAAAA
    vAD9P0Y//j8AAAAAVAMAAChaDoBgAP0/4KsOgJAA/T/AQ/w/BQAAADBaD4CMQP4/
    AAAAALQA/T8A////AAAAAAAAAACQAP0/wAD9P7wA/T8EAAAAYT/+P8AA/T+8AP0/
    AAAAAAgAAAAw////DAAAAA2sDoAQAf0/gDv+PwAAAABGP/4/Xj/+PwAAAACoAP0/
    tAD9P8BD/D8FAAAAiLxAP0QwQD8cQPw/1ggAAAUAAADjig2AUAH9PwAAAAAQAAAA
    Qj/+PwAB/T8gAf0/AAAAAAAAAAAAAAAAaJpAPwAAAAB8Q/w/kAD9PwAAAADQAP0/
    SYgNgDAB/T+AO/4/AAAAAAAAAAAAAAAAEAAAAAAAAADjig2AUAH9P4A7/j8QAAAA
    QDb+PwIAAAABAAAAFQEAALN8DYDwAf0/zB9APwAAAAAAAAAAgAH9P+OKDYBQAf0/
    QD/+PwAAAAAGAAAAAAAAAAAAAAAAAAAAfEP8P9giQD98Q/w/AAAAALN8DYDwAf0/
    zB9APwAAAAAOiA2AjED+PyBA/j8AAAAAlHwNgBAC/T9cRPw/2CJAPxIAAAAVAQAA
    BgAAAPEzIwBAP/4/AAAAAEA//j8GAAAAAAAAAAAAAAAAAAAAMAL9PyAT/D/QQ/w/
    IAAAABcAAABQOf4/CAAAAAAAAAAwAv0/IBP8P9BD/D8AAAAAjB9AP1A//D8AAQAA
    AAAAAGAD/T8AAAAAAAAAAAYAAAAAAAAAAQAAAKWlpaW4AAAAIewcACBCT09ULlBZ
    AKWlpaWlYm9vdC5weQClpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
    paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaUgEAhAYHoNQDAABQAAAAAA
    YAP9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAD/////
    AAAAAP0eFtqy9r9Jfpa2MFjP8/GsVmqxAAAAAAAAMgAwAv0/AAAAAAAAAAAAAAAA
    AAAAABQeQD8AAAAA4Dv8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAGwD/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    3NP8P3DS/D/Q0/w/
    cNL8P3DT/D+pKXdEgDj8P4A4/D/c0/w/eDj8PxkAAACfOfsIESEZV9zT/D8AAAAA
    AAAAAJTO/D9JRExFAGke3wjMncCQ1+MAAAAAANDT/D8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAQsfw/eLH8P+Cx/D8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEU3rA==
    IBAIQEjKEUAwCQYAOFoIgDDT/D8IAAAAAQAAACMABgDc0/w/AQAAAAAAAABEdvw/
    ENP8PwAAAAAAAAAAjJT9PwAAAAAAAAAAIwAGAAwAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAACESCEAAAAAAiGYIQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAIyU/T8AAAAAAAAAACMABgAAAAAAUNP8PwAAAAAAAAAA
    IwAGANzT/D8BAAAAAAAAAAAAAABw0/w/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAfNP8PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAA==
    VA/9PwAO/T9ID/0/
    AA79P+AO/T8hLCMAbDj8P6ww/T9UD/0/ZDj8PwcAAABIBv0/SAb9P1QP/T9ABv0/
    EgAAAEwH/T90aVQAXQ9wnjh2pD+tTcQA////f0gP/T8AAAAAIAUGABIAAAABAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEQUPg==
    AAAAANtMCIAgBQYAAgAAAFg5E4BgDv0/vHj8P7AO/T8AAAAAvSsjAJR+/D9wfvw/
    ZAAAAAAAAAARAAAAcEQAAGgG/T8AAAAAAQAAAJzE/D8LhBKAkA79P7x4/D+wDv0/
    C4QSgJAO/T+8ePw/sA79P2QAAAC9KyMABgAAABQAAAAAAAAAsA79P3xOE0AAAAAA
    QDgTQAAAAAABAAAAAAAAAAAAAADgDv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOwO/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
    pDD9P9Av/T+YMP0/
    0C/9PzAw/T/LKyMAXA/9P2w4/D+kMP0/ZDj8PxQAAADsMiqhNeKQJ6Qw/T8AAAAA
    BQAAAJwk/T9TZXJ2ZXJzAGW3ZcYHLi0A////f5gw/T8AAAAAIAUGAAUAAAAAAAAA
    MML8PwAAAABgTxNAAAAAAAsAAAAQsfw/eLH8P+Cx/D8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFdOhA==
    AAAAAKhZCIAgBQYAAAAAAAAAAAAQMP0/AAAAAAAAAAAAAAAA+DP9PzAv/T8vAAAA
    AAAAADAw/T8AAAAAAAAAABQT/D8BAAAAaT78PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA8MP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    UOL8P2Dh/D9E4vw/
    YOH8P+Dh/D8AAAAAWDj8P1g4/D9Q4vw/UDj8Pw8AAAB81fw/fNX8P1Di/D901fw/
    CgAAAEjW/D9UbXIgU3ZjAIc/o/875ToAAAAAAETi/D8AAAAAIAkGAAoAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFZ9Yg==
    AAAAAFplCIAgCQYAAAAAAAAAAACw4fw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AQAAAFDi/D8BAAAAAAAAAAAAAADg4fw/AAAAAAAAAAABAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOzh/D8AAAAA
    YAr+P2Ae/j/MH/4/
    YB7+P2Af/j8AAAAAMCP9PxC5/D9gCv4/CDj8Pw4AAABEMv0/RDL9P2AK/j88Mv0/
    CwAAANAL/j9JbnRlcnJ1cHRzAAAAAAAAAAAAAMwf/j8AAAAAIAUGAAsAAAAAAAAA
    AAAAAAwf/j8AAAAAAAAAAAAAAAAQsfw/eLH8P+Cx/D8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
    AAAAANtMCIAgBQYApaWlpdR+DYDAHv4/YEL8PwAAAAAAAAAAAQAAAAEAAACAAAAA
    /////8Ae/j8YH/4/AAAAAGQy/T8AAAAAAQAAANBD/D8AAAAAQB/+PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYH/4/ABQAAAAAAAAAAAAA
    IwoGAGAK/j8BAAAAAAAAAAAAAABgH/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbB/+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    KCP9PwAi/T8cI/0/
    ACL9P7Ai/T8+SqJW0Mf8P2gK/j8oI/0/CDj8PwUAAAD0EP0/9BD9Pygj/T/sEP0/
    FAAAACAX/T9ldmVudFRhc2sAQViaqdUAAAAAABwj/T8AAAAAIAkGABQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPvDjA==
    AAAAANtMCIAgCQYAMFn8PwAAAABgIv0/AAAAAAAAAAAAAAAA06siACMJBQAAAAAA
    /////2Ai/T8AAAAAAAAAABQR/T8AAAAAAQAAAAAAAAAAAAAAsCL9PwAAAAAAAAAA
    DQAAAP////8AAAAACQAAAAAAAAABAAAAOsT8PzTE/D8AAAAAvFr8PwAAAAAwWfw/
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALwi/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    yMf8P6BH/T+cSP0/
    oEf9PzBI/T9gL/0/EDj8PzAj/T/Ix/w/CDj8PwMAAACoxPw/qMT8P8jH/D+gxPw/
    FgAAAKA8/T9ydFQAQKUAAAEApaUAAAAA////f5xI/T8AAAAAIAAGABYAAAAAAAAA
    AAAAANtMCIAgAAYAAAAAAAAAAAAASP0/9Ib8P1GG/D8AAAAAyisjAAAAAAAAAAAA
    /////wAAAAAAAAAAAAAAAMjE/D8AAAAAAQAAAAAAAAAAAAAAMEj9PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAGQh/D8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA8SP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAA
    CLn8PxC4/D/8uPw/
    ELj8P5C4/D90LT47aAr+PxA4/D8Iufw/CDj8PwEAAACUs/w/lLP8Pwi5/D+Ms/w/
    GAAAAMCz/D9pcGMwANnUwSq+8EBpuF8AAAAAAPy4/D8AAAAAIAAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJH9vA==
    AAAAANtMCIAgAAYAAAAAAAAAAABwuPw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    /////wAAAAAAAAAAAAAAALSz/D8AAAAAAQAAAAAAAAAAAAAAkLj8PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAALoLCICAPP4/+Df8PyDN/D8AAAAAAAAAAJy4/D8AAAAA
    Rebooting...
    ets Jun  8 2016 00:22:57
    rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0x00
    mode:QIO, clock div:2
    load:0x3fff9010,len:8
    load:0x3fff9018,len:248
    load:0x40078000,len:4056
    load:0x4009fc00,len:920
    entry 0x4009fde4
    I (1577) wifi: frc2_timer_task_hdl:3ffd49a4, prio:22, stack:2048
    I (1593) wifi: Init lldesc rx mblock:10
    I (1593) wifi: Init lldesc rx ampdu len mblock:7
    I (1593) wifi: Init lldesc rx ampdu entry mblock:4
    I (1595) wifi: pp_task_hdl : 3ffdbae0, prio:23, stack:8192
    I (1600) wifi: sleep disable
    I (2589) wifi: mode : softAP (24:0a:c4:00:6e:c3)
    17.2189 100599.7 252.1453
    wifi_ap
    MicroPython v1.8.6-463-g468b9d27 on 2017-02-16; WiPy with ESP32
