    FiPy Pysense 2.0X not showing up on lsusb
    9 Posts 3 Posters 175 Views 3 Watching
      Stefano Ordine
      I am writing to gather some support after reading multiple other forum posts about not being able to access the REPL from VSCode anymore.
      I am running:
      • MacOS BigSur 11.6.4
      • FiPy
      • PySense 2.0X
      • VSCode with Pymakr extension
      • Node.js v14.16.1 installed
      After some time of not connecting the board to the PC I am retrying tweaking with this wonderful device and ecosystem, but I am unable to access the REPL anymore... The prev firmware loaded is still working, but now I need to update it with new features :-)
      I tried these resolutions options:
      • Execute a Safe Boot following this procedure https://docs.pycom.io/gettingstarted/programming/safeboot/ with the "< 3", "3<t<6", "6<t<9" orange blinking cases but in all of those cases no success, the FiPy is entering in the blue heart-beat mode but the REPL does not show up on the VSCode Terminal
      • Checked troubleshooting https://docs.pycom.io/gettingstarted/troubleshooting-guide/ no luck
      • checked some issues on github and forum posts https://forum.pycom.io/topic/7432/cannot-connect-device-after-firmware-update and https://github.com/pycom/pymakr-atom/issues/102 and https://forum.pycom.io/topic/6817/pymakr-connection-timed-out-repl-accessible-via-screen/3 no luck either
      • the Firmware Update Tool is not recognising the device even when connected to usb in in safe mode (trying to flash the firmware from scratch)
      • my lsusb:
      2022-04-01 17:45:21.535 system_profiler[15092:2246756] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
      2022-04-01 17:45:21.536 system_profiler[15092:2246756] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
      2022-04-01 17:45:21.537 system_profiler[15092:2246756] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
      Bus 000 Device 001: ID 05e3:0626 Genesys Logic, Inc. USB3.1 Hub
      Bus 000 Device 002: ID 0bda:8153 Realtek Semiconductor Corp. USB 10/100/1000 LAN  Serial: 000001
      Bus 020 Device 001: ID 05e3:0610 Genesys Logic, Inc. USB2.1 Hub
      Bus 020 Device 002: ID 1a40:0801 TERMINUS TECHNOLOGY INC. USB 2.0 Hub
      Bus 020 Device 004: ID 1a40:0801 TERMINUS TECHNOLOGY INC. USB 2.0 Hub
      Bus 020 Device 005: ID 2000:dd00 2000 USB PnP Audio Device  Serial: U2dc0z7ws53a79rn
      Bus 020 Device 003: ID 1d5c:7102 Fresco Logic Inc. Generic Billboard Device
      Bus 128 Device 000: ID 05ac:8102 Apple Inc. Touch Bar Backlight  Serial: 0000000000000000
      Bus 128 Device 000: ID 05ac:8302 Apple Inc. Touch Bar Display  Serial: 0000000000000000
      Bus 128 Device 000: ID 05ac:027b Apple Inc. Apple Internal Keyboard / Trackpad  Serial: FM79056046YJ3VXAG+TTN
      Bus 128 Device 000: ID 05ac:8103 Apple Inc. Headset  Serial: 000000000000
      Bus 128 Device 000: ID 05ac:8262 Apple Inc. Ambient Light Sensor  Serial: 000000000000
      Bus 128 Device 000: ID 05ac:8514 Apple Inc. FaceTime HD Camera (Built-in)  Serial: CC290138Y0GJ3Y33L
      Bus 128 Device 000: ID 05ac:8233 Apple Inc. Apple T2 Controller  Serial: 0000000000000000
      Bus 001 Device 001: ID 1d6b:CITR Linux Foundation USB 3.1 Bus
      Bus 000 Device 001: ID 1d6b:CITR Linux Foundation USB 3.1 Bus
      Bus 000 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 000 Device 000: ID 05ac:8102 Apple Inc. Apple T2 Bus
      it seems it does not even see the device
      Do You have any hints or help to share?
      Thanks for Your time
      Stef.
        Stefano Ordine
        PS: forgot to mention that I attempted also to connect with Atom on the same machine (MacOS) and also with another completely different machine too (a Windows 10 PC the Devices List is not even showing the unknown device for which is required to install the custom driver as reported from this guide https://docs.pycom.io/gettingstarted/software/drivers/)
          Stefano Ordine
          Any help here? Please :)
          • M Offline
            Meriç SARIIŞIK
            Hi Stefano,
            Can you check whether your USB cable is faulty or not? It seems that it isnot related to firmware.
            You mentioned that the previous firmware works fine. Which firmware did you mention? Does it belong to pysense 2.0x or fipy firmware? Do you have any other shield from us to check usb cable and the connection?
            Best regards,
            Meric
              Stefano Ordine @Meriç SARIIŞIK
              @Meriç-SARIIŞIK thanks for the reply! I made some progresses here, hopefully this may help for the resolution:
              Checked and changed cable just to be sure, I am 100% sure that the cable I am using now is ok :-)
              Unfortunately not, but eventually if I cannot fix this one I can buy a new one
              I meant the FiPy firmware, but actually the question You made allowed me to have a further idea on how to fix this: flash the PySense 2 firmware following this guide https://docs.pycom.io/updatefirmware/expansionboard/
              After the flash finally the lsusb is recognising the Pysense board (with the new cable mentioned above)!
              sudo dfu-util -D pysense2_v16.dfu
              dfu-util 0.11
              Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
              Copyright 2010-2021 Tormod Volden and Stefan Schmidt
              This program is Free Software and has ABSOLUTELY NO WARRANTY
              Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
              Match vendor ID from file: 04d8
              Match product ID from file: f011
              Opening DFU capable USB device...
              Device ID 04d8:f011
              Device DFU version 0100
              Claiming USB DFU (Run-Time) Interface...
              Setting Alternate Interface zero...
              Determining device status...
              DFU state(2) = dfuIDLE, status(0) = No error condition is present
              dfu-util: WARNING: Device already in DFU mode? (bState=2 dfuIDLE)
              Claiming USB DFU Interface...
              Setting Alternate Interface #0 ...
              DFU mode device DFU version 0100
              Device returned transfer size 64
              Copying data from PC to DFU device
              Download	[=========================] 100%        16384 bytes
              Download done.
              Done!
              lsusb
              Bus 020 Device 029: ID 04d8:f012 Microchip Technology Inc. Pysense  Serial: Py244d42
              Then I flashed the FiPy last firmware (1.20.2.r6)
              Changed baud rate to 230400
              Read 4 KiB from config in 0.18 seconds
              Changed baud rate to 921600
              File system type set to FatFS
              Erased 4 MiB flash fs in 9.85 seconds
              Erased 28 KiB at address 0x00009000
              Wrote 28 KiB from bootloader.bin in 0.79 seconds
              Wrote 4 KiB from partitions_8MB.bin in 0.08 seconds
              Wrote 1.93 MiB from fipy.bin in 25.03 seconds
              Booting from partition: factory
              Wrote 4 KiB to otadata in 0.09 seconds
              Wrote 4 KiB to config in 0.09 seconds
              Device ID: ...
              LoRa MAC: ...
              Sigfox ID: ...
              Sigfox PAC: ...
              with success, now I am blocked on another point unfortunately, I cannot access the prompt using visual studio code :-(
              code --version
              1.67.2
              # VSCode extension Pymakr v2.12.3
              node --version
              v14.16.1
              When I add the new device using the Extension:
              it does not connect returning the error below:
              Also I tried to connect from the terminal directly with not success either:
              node /Users/sordine/.vscode/extensions/pycom.pymakr-2.12.3/src/terminal/bin/client.js
              events.js:292
                    throw er; // Unhandled 'error' event
              Error: connect ECONNREFUSED 127.0.0.1:5364
                  at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16)
              Emitted 'error' event on Socket instance at:
                  at emitErrorNT (internal/streams/destroy.js:106:8)
                  at emitErrorCloseNT (internal/streams/destroy.js:74:3)
                  at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                errno: -61,
                code: 'ECONNREFUSED',
                syscall: 'connect',
                address: '127.0.0.1',
                port: 5364
              Actually the version of the extension available now on VS Code, is slightly different from the one described in the getting started guide https://docs.pycom.io/gettingstarted/software/vscode/ is there any other reference to follow with the new current version of extension?
                jcaron @Stefano Ordine
                @Stefano-Ordine Do you get a prompt if you use tools such as screen or minicom pointed to the /dev/tty.usbmodemXXXX device?
                  Stefano Ordine @jcaron
                  @jcaron unfortunately I cannot, this is the output:
                  ❯ screen /dev/tty.usbmodemPy244d421
                  Sorry, could not find a PTY.
                  [screen is terminating]
                  ❯ minicom /dev/tty.usbmodemPy244d421
                  minicom: cannot open /dev/modem: No such file or directory
                  I really do not understand what's the point here 🤔
                  Do You have any other suggestion?
                    @Stefano-Ordine In the case of minicom, you need to specify the serial port via the -D command line option.
                    As for screen... What operating system are you using? The "could not find a PTY" message is not related to the serial port, it's a different issue. What OS and and terminal interface are you using?
                      @jcaron
                      In the case of minimum, you need to specify the serial port via the -D command line option.
                      🤦‍♂️ Oh thanks! I am not familiar with that binary, but I read the f...ing manual now that You mentioned that option ^^
                      ❯ minicom -D /dev/tty.usbmodemPy244d421
                      And the prompt attached everything is working now, also the VSCode extension now see the device I run the RGB test program just to be sure and every thing is workingas expected now! We can close this!
                      In the end I think that the problem was on the PySense firmware once reflashed from scratch all the rest has been quite easy to figure out :-)
                      Thanks for Your time and effort @jcaron
                      have a good one!
                      Stefano
