I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?
 I connected a passive GPS on a LoPy device. What is the pin number to read those values?
 @livius said in I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?: @rskoniec
 Thank you :)P.S. price? About 30$
 @rskoniec
 @livius said in I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?: @rskoniec said in I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?: BTW, I'm using this one SparqEE GPS Can you bring some light about it (if you have one) - datasheet is realy poor without anyd details.
 How fast it is (hot start, cold ...) and how accurate?
 Power consumption?- Hot start - aprox. 1-2s
- Cold start - aprox. 30-40s
- Accuracy - aprox. 3-5m (good view open sky)
 Power consumption?
 @lawrence said in I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?: @rskoniec What antenna do you recommend to use? It have to be as small and light as possible. That was the reason why i chose the passive ufl antenna. Or should i wait until the Pytrack expansion board of Pycom is released? If we are talking about GPS antenna many GPS-RX modules are in 2 flavours: - with integrated (built-in antenna) sometimes with uFL connector - for example this BTW, I'm using this one SparqEE GPS
- with uFL connected external antenna - for example this
 PyTrack can be pre-ordered here with shipping in this month, so I guess it's up to you how fast you need GPS functionality and amount of money you'll want to spend on it.
 This could be good start for GPS adventure: ;o) @johnmcdnz said in LoPy UART for GPS not reading data: @livius It's this
 http://www.addicore.com/NEO-6M-GPS-p/231.htm
 available and cheap :-)
 (I don't buy from that website, just a local supplier of the same thing)@affoltep said in LoPy UART for GPS not reading data: @livius This module here, as well cheap and with integrated antenna.
 @Shaun tnx for help
 @lawrence
 You have connected a passive GPS antenna to the uFL connector meant for a WiFi antenna .
 There is no GPS receiver in the LoPy or WiPy.
 You will be required to connect an entire GPS module to the LoPy
 @lawrence said in I connected a passive GPS on a LoPy device on the GPS pin. What is the pin number to read those values?: I'm not using an expension board i connected the GPS antenna on the LoPy itself. There are 2 possible antenna possibilities ( LoRa and gps antenna). i'll post a picture after this post. AFAIK 2 uFL antenna connectors are for WLAN/BT and LoRa. According to your picture you've connected your GPS antenna to uFL WLAN/BT connector.
 Anyway, your setup would be OK if LoPy board would have GPS receiver built-in. AFAIK it hasn't.
 @rskoniec
 i need it in p notation this is wat i tried.from machine import Pin
 from machine import UART#Interface definitons for GPS
 gps_pps = Pin('P23', mode = Pin.IN)
 gps_enable = Pin('P8', mode=Pin.OUT)
 gps_enable(False)
 gps_uart = UART(1, 9600)
 gps_uart.init(9600, bits=8, parity=None, stop=1)gps_enable(True)
 if gps_uart.any():
 print(gps_uart.readline())
 If you need pin number in P or G notation you have to give us more details: - Are you using Expansion Board or breadboard for GPS connection?
- Can you share a photo of your setup?
