  • 10 Topics
    Hi, Edward. Whilst Pycom B.V. has decided to bid the Helium Hotspot Miners adieu, you may still manage your existing miners via Nebra's solution. For more information, please check out https://hub.balena.io/organizations/nebraltd/fleets/HELIUM-PYCOM
  • Hotspot debugging
    @Jason-Timmins I have several hotspots placed at friends, relatives, and offices. I stuck with makers that were into IoT before helium was a thing. RAK, SenseCAP (Seeed), Heltec and now Pycom. Seems all of them get a bad firmware update from time to time. I've gotten in the habit of imaging the SD cards of the ones that use SD storage. (Heltec uses non-removable eMMC) The Pycom hotspot is a great performer, so I hope they work out the kinks in the coming weeks. I sent another user a zipped SD card image to get him going again.
  • Buttons
    @Jason-Timmins The Pycom helium hotspot is built off of their Pygate 8 channel LoRaWAN gateway module and uses the same housing. The buttons don't serve any purpose in this application as far as I know.
  • WiFi Auto-reconnect
  • Need help - SD cards image bad/corrupted
    @Razvan-Ciltea I had a similar problem. A Pycom hotspot did an OTA update (I suspect) and then went down sometime after that. It had asked me to change the password to the local web interface, which it had never done before, so I assume it had updated. The solid indicator lights I got were just like yours, except I didn't know there was one on the back of the CM4 adapter board. In any case, the SD Card was corrupt. I could see the 256Mb FAT partition and its contents, but could not delete or write any new files. DISKPART could not wipe the disk. I plugged it into a Linux laptop and tried to use DD to wipe it and that failed. Luckily, I still had a brand new hotspot I had not installed, so I used Balena Etcher to clone the card to a Samsung 64gb high endurance card. It booted up, I paired it to bluetooth, and it is back up and running normally. If you have a dropbox or similar account, I can image the OEM drive using USB Image Tool (https://www.alexpage.de/usb-image-tool/) and upload the image so you can restore it on a new drive using the same utility. The file will be 32Gb though - unless it will compress well. Note: My hotspots are US915, so I don't know if the image for an EU or different region is the same or not.
  • Ethernet Port
    Hi Jason, I'm afraid it doesn't support wired ethernet. Sorry
  • Trouble shooting guide Pycom Miner
    5 Votes
    @Bram-Djakaria Yeah, I get a pause then this... [image: 1661951788507-ce7b1e8d-8341-4e92-8503-0799511b2236-image.png] I wonder what we're missing. I'd love to be able to see what's going on with my miner.
  • Pairing mode not enabled
    i had the same issue. i opened the case and the individual parts weren´t connected this guy had the same issue https://forum.pycom.io/topic/7668/unable-to-assert-location-helium-hotspot?_=1660984068047
  • No Hotspots found - Pairing mode?
    @Laurenz-von-Recklinghausen I hadn't the same problem but with one of the three we kept trying to enter the data until I thought of making a network scan. That revealed that the hotspot was already online (look for an unknown raspberry pi device). I think you must stop the maker app before trying again, just to be sure.
  • Unable to add hotspot
    i have the same problem, did u find a solution ?
  • Error: Unable to find hotspot
    @Manuel-Espinosa Thanks, I guess I'll need to wait a bit
  • "...We will make sure to squeeze you into batch 1...."
    Hi Gerhard, We are currently shipping batch the first batches of Helium Hotspots, so I would think you will be receiving your device soon. If you want to find out the status of our order you can email sales@pycom.io
  • Is it already shipping?
    We have had a hold-up with the connector board, but that is expected to arrive soon, at which point they will be assembled and shipped.
  • Light Hotspot
    @WENG-WAI-KENNETH-LEONG Yes we're ready :-)
