    LoPy Nano-Gateway Extended (Timeout and Retry)
    31 Posts 14 Posters 20.1k Views 17 Watching
      gouao
      Can a seeeduino lorawan communicate with the lopys ?
      Can it act as a node, wich is recognized by the lopy nano-gateway ?
        Butch @Butch
        Following up on my own post (which seems to be a theme for me), I discovered that it is, indeed, the length of the payload that's causing the problem. If I limit the payload to 61 bytes (plus a three-byte header), it works:
        Sending a message: 1234567890123456789012345678901234567890123456789012345678901, length = 61
        >>>>>>>>>>>>>> Sending package b'\x01=\x001234567890123456789012345678901234567890123456789012345678901', length = 64, bytes sent = 64
        ACK RECEIVED: 0
        If, however, I increase the length of the payload to 62 bytes (plus a three-byte header), it fails:
        Sending a message: 12345678901234567890123456789012345678901234567890123456789012, length = 62
        >>>>>>>>>>>>>> Sending package b'\x01>\x0012345678901234567890123456789012345678901234567890123456789012', length = 65, bytes sent = 65
        MESSAGE FAILED
        Any ideas?
          Butch @Butch
          And, once again replying to my own post, I understand why:
          LoRa spec:
          7.2.6 US902-928 Maximum payload size
          2 The maximum MACPayload size length (M) is given by the following table. It is derived from
          3 the maximum allowed transmission time at the PHY layer taking into account a possible
          4 repeater encapsulation. The maximum application payload length in the absence of the
          5 optional FOpt MAC control field (N) is also given for information only. The value of N might
          6 be smaller if the FOpt field is not empty:
          DataRate       M         N
          0              19        11
          1              61        53
          2              137       129
          3              250       242
          4              250       242
          5:7             Not defined
          8              41        33
          9              117       109
          10             230       222
          11             230       222
          12             230       222
          13             230       222
          14:15           Not defined
          So, as you can see, at data rate 1, the maximum payload size is 61 bytes. If I want to send more, I have to increase the data rate.
          My question now is how do I increase the data rate? Ideally, I'd like to use data rate 3.
          It looked like I could just do this:
          lora_sock.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
          That code completes with no complaint, but when I make the change on both the node and gateway sides, it does not change the maximum payload size.
          After playing around with it some more, 4 seems to be the maximum supported, in spite of what the chart above says.
          Any ideas? Please?
            Colateral @Butch
            @Butch Are you using 1.6.11b1? How exactly instantiated lora stack for the GW and the Node? I mean all can yu enumerate all params that you configured for the lora object?
              Butch @Colateral
              @Colateral Thanks for your reply. My post below provides all the answers to the questions you asked. Not only does it have the version number of the firmware that I'm using, it also has all the code for both the node and the gateway.
              • F Offline
                fbt @Roberto
                Hi @Roberto , in case i wanted to support more than 2 nodes, i.e 8 nodes, which parameters should i modify on the gateway code?. thanks
                • F Offline
                  fbt @gouao
                  Hi @gouao, did you get any answer about the compatibility of seeeduino lorawan and lopy? thanks
                    gouao @fbt
                    @fbt hello mate, unfortunately i could't get any informations concerning this..
                    If you find out something please let me know !
                    All the best!
                    • F Offline
                      fbt @gouao
                      Thanks @gouao ... any reply about this issue @jmarcelino ? thanks
                        jmarcelino @fbt
                        @fbt
                        For a LoRaWAN device you'd usually want to be using https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway and not the code on the post. This code is for raw LoRa only.
                        8 devices on the LoRaWAN gateway shouldn't be a problem as long as they don't transmit at the same time.
                        • H Offline
                          heut
                          Hi @Roberto and @Butch
                          Thank you very much for the interesting discussion. I'm currently trying to get the plain code (node_1.py and nano_gateway.py) working on my LoPy(s), without success so far. I have both updated to the latest Firmware for Switzerland and sitting in an extension board with antennas attached. When running the code respective code on the LoPys, not a single message is delivered and acknowledged. All messages that are received on the gateway node have the size 0.
                          From time to time the node_1.py LoPy shows a longer LED blink in blue instead of the heartbeat.
                          Any idea what I might be doing wrong?
                          Best
                          heut
                          • sebS Offline
                            seb @heut
                            @heut try adding a delay in your loop, e.g. 50ms, this seemed to vastly improve the situation for me
                            • H Offline
                              heut @seb
                              @seb Thank you for the hint. However, that didn't make a difference in my situation at all. There is still not a single message transmitted. Any other suggestions what it might be?
                              Just to be sure, here the sources I'm using.
                              Gateway:
                              import struct
                              from network import LoRa
                              # A basic package header
                              # B: 1 byte for the deviceId
                              # B: 1 byte for the pkg size
                              # B: 1 byte for the messageId
                              # %ds: Formated string for string
                              _LORA_PKG_FORMAT = "!BBB%ds"
                              # A basic ack package
                              # B: 1 byte for the Ok (200) or error messages
                              _LORA_PKG_ACK_FORMAT = "BBBB"
                              # Open a Lora Socket, use rx_iq to avoid listening to our own messages
                              #lora = LoRa(mode=LoRa.LORA, tx_iq=True, frequency=870000000, sf=7)
                              lora = LoRa(mode=LoRa.LORA, tx_iq=True)
                              lora_sock.setblocking(False)
                              while (True):
                                  # Since the maximum body size in the protocol is 255 the request is limited to 512 bytes
                                  recv_pkg = lora_sock.recv(512)
                                  # If at least a message with the header is received process it
                                  if (len(recv_pkg) > 3):
                                      print("Package received")
                                      recv_pkg_len = recv_pkg[1]
                                      # If message is corrupted should not continue processing
                                      #if (not len(recv_pkg) == recv_pkg_len + 3):
                                          #continue
                                      # Unpack the message based on the protocol definition
                                      device_id, pkg_len, msg_id, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                                      # Respond to the device with an acknoledge package
                                      # time.sleep(0.15)
                                      ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, msg_id, 200)
                                      lora_sock.send(ack_pkg)
                                      print("sent ack")
                                  time.sleep(0.2)
                                      # Do any extra processing required for the package. Keep in mind it should be as fast as posible
                                      # to make sure that the other clients are not waiting too long for their messages to be acknoleged
                              Node:
                              import struct
                              from uos import urandom
                              # This device ID, use different device id for each device
                              _DEVICE_ID = 0x01
                              _MAX_ACK_TIME = 5000
                              _RETRY_COUNT = 3
                              # Open a Lora Socket, use tx_iq to avoid listening to our own messages
                              # Method to increase message id and keep in between 1 and 255
                              msg_id = 0
                              def increase_msg_id():
                                  global msg_id
                                  msg_id = (msg_id + 1) & 0xFF
                              # Method for acknoledge waiting time keep
                              def check_ack_time(from_time):
                                  current_time = time.ticks_ms()
                                  return (current_time - from_time > _MAX_ACK_TIME)
                              # Method to send messages
                              def send_msg(msg):
                                  print("SEND MSG")
                                  print(msg)
                                  global msg_id
                                  retry = _RETRY_COUNT
                                  while (retry > 0 and not retry == -1):
                                      retry -= 1
                                      pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), _DEVICE_ID, len(msg), msg_id, msg)
                                      lora_sock.send(pkg)
                                      # Wait for the response from the server.
                                      start_time = time.ticks_ms()
                                      while(not check_ack_time(start_time)):
                                          #print("RECV_ACK")
                                          recv_ack = lora_sock.recv(256)
                                          # If a message of the size of the acknoledge message is received
                                          if (len(recv_ack) == 4):
                                              print("SIZE CORRECT")
                                              device_id, pkg_len, recv_msg_id, status = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                                              if (device_id == _DEVICE_ID and recv_msg_id == msg_id):
                                                  if (status == 200):
                                                      # Do some code if your message arrived at the central
                                                      return True
                                                      return False
                                      time.sleep_ms(urandom(1)[0] << 2)
                                  return False
                              # Main Loop
                              while(True):
                                  success = send_msg("DEVICE %d HERE" % _DEVICE_ID)
                                  if (success):
                                      print("ACK RECEIVED: %d" % msg_id)
                                      increase_msg_id()
                                      print("MESSAGE FAILED")
                                      # Manage the error message
                              • sebS Offline
                                seb @heut
                                @heut I will have a closer look at your code now but in the mean time, a few things that often catch users out:
                                • Make sure both LoPy modules are running the same firmware
                                • Please set the frequency to ensure it is the same on both
                                One thing I have already noticed is you have set tx_iq on both the node and the gateway, it should be rx_iq=True for the gateway and tx_iq=True on the nodes.
                                • H Offline
                                  heut @seb
                                  @seb Thank you so much, that was the point! Setting rx_iq instead of tx_iq True on the Gateway solved the issue. And frequency is set as well.
                                    Archana Kadam @Roberto
                                    @roberto
                                    I have used the above code and the communication between the one node and gateway is generated, but the device id and package. What is the procedure to get the exact connected device.Please update as soon as possible your help will be appreciable.
                                    Thank You
                                    • 2 / 2
