    LoPy Nano-Gateway Extended (Timeout and Retry)
    31 Posts 14 Posters 20.1k Views 17 Watching
      Butch @Butch
      Following up on my own post (which seems to be a theme for me), I discovered that it is, indeed, the length of the payload that's causing the problem. If I limit the payload to 61 bytes (plus a three-byte header), it works:
      Sending a message: 1234567890123456789012345678901234567890123456789012345678901, length = 61
      >>>>>>>>>>>>>> Sending package b'\x01=\x001234567890123456789012345678901234567890123456789012345678901', length = 64, bytes sent = 64
      ACK RECEIVED: 0
      If, however, I increase the length of the payload to 62 bytes (plus a three-byte header), it fails:
      Sending a message: 12345678901234567890123456789012345678901234567890123456789012, length = 62
      >>>>>>>>>>>>>> Sending package b'\x01>\x0012345678901234567890123456789012345678901234567890123456789012', length = 65, bytes sent = 65
      MESSAGE FAILED
      Any ideas?
        Butch @Butch
        And, once again replying to my own post, I understand why:
        LoRa spec:
        7.2.6 US902-928 Maximum payload size
        2 The maximum MACPayload size length (M) is given by the following table. It is derived from
        3 the maximum allowed transmission time at the PHY layer taking into account a possible
        4 repeater encapsulation. The maximum application payload length in the absence of the
        5 optional FOpt MAC control field (N) is also given for information only. The value of N might
        6 be smaller if the FOpt field is not empty:
        DataRate       M         N
        0              19        11
        1              61        53
        2              137       129
        3              250       242
        4              250       242
        5:7             Not defined
        8              41        33
        9              117       109
        10             230       222
        11             230       222
        12             230       222
        13             230       222
        14:15           Not defined
        So, as you can see, at data rate 1, the maximum payload size is 61 bytes. If I want to send more, I have to increase the data rate.
        My question now is how do I increase the data rate? Ideally, I'd like to use data rate 3.
        It looked like I could just do this:
        lora_sock.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
        That code completes with no complaint, but when I make the change on both the node and gateway sides, it does not change the maximum payload size.
        After playing around with it some more, 4 seems to be the maximum supported, in spite of what the chart above says.
        Any ideas? Please?
          Colateral @Butch
          @Butch Are you using 1.6.11b1? How exactly instantiated lora stack for the GW and the Node? I mean all can yu enumerate all params that you configured for the lora object?
            Butch @Colateral
            @Colateral Thanks for your reply. My post below provides all the answers to the questions you asked. Not only does it have the version number of the firmware that I'm using, it also has all the code for both the node and the gateway.
            • F Offline
              fbt @Roberto
              Hi @Roberto , in case i wanted to support more than 2 nodes, i.e 8 nodes, which parameters should i modify on the gateway code?. thanks
              • F Offline
                fbt @gouao
                Hi @gouao, did you get any answer about the compatibility of seeeduino lorawan and lopy? thanks
                  gouao @fbt
                  @fbt hello mate, unfortunately i could't get any informations concerning this..
                  If you find out something please let me know !
                  All the best!
                  • F Offline
                    fbt @gouao
                    Thanks @gouao ... any reply about this issue @jmarcelino ? thanks
                      jmarcelino @fbt
                      @fbt
                      For a LoRaWAN device you'd usually want to be using https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway and not the code on the post. This code is for raw LoRa only.
                      8 devices on the LoRaWAN gateway shouldn't be a problem as long as they don't transmit at the same time.
                      • H Offline
                        heut
                        Hi @Roberto and @Butch
                        Thank you very much for the interesting discussion. I'm currently trying to get the plain code (node_1.py and nano_gateway.py) working on my LoPy(s), without success so far. I have both updated to the latest Firmware for Switzerland and sitting in an extension board with antennas attached. When running the code respective code on the LoPys, not a single message is delivered and acknowledged. All messages that are received on the gateway node have the size 0.
                        From time to time the node_1.py LoPy shows a longer LED blink in blue instead of the heartbeat.
                        Any idea what I might be doing wrong?
                        Best
                        heut
                        • sebS Offline
                          seb @heut
                          @heut try adding a delay in your loop, e.g. 50ms, this seemed to vastly improve the situation for me
                          • H Offline
                            heut @seb
                            @seb Thank you for the hint. However, that didn't make a difference in my situation at all. There is still not a single message transmitted. Any other suggestions what it might be?
                            Just to be sure, here the sources I'm using.
                            Gateway:
                            import struct
                            from network import LoRa
                            # A basic package header
                            # B: 1 byte for the deviceId
                            # B: 1 byte for the pkg size
                            # B: 1 byte for the messageId
                            # %ds: Formated string for string
                            _LORA_PKG_FORMAT = "!BBB%ds"
                            # A basic ack package
                            # B: 1 byte for the Ok (200) or error messages
                            _LORA_PKG_ACK_FORMAT = "BBBB"
                            # Open a Lora Socket, use rx_iq to avoid listening to our own messages
                            #lora = LoRa(mode=LoRa.LORA, tx_iq=True, frequency=870000000, sf=7)
                            lora = LoRa(mode=LoRa.LORA, tx_iq=True)
                            lora_sock.setblocking(False)
                            while (True):
                                # Since the maximum body size in the protocol is 255 the request is limited to 512 bytes
                                recv_pkg = lora_sock.recv(512)
                                # If at least a message with the header is received process it
                                if (len(recv_pkg) > 3):
                                    print("Package received")
                                    recv_pkg_len = recv_pkg[1]
                                    # If message is corrupted should not continue processing
                                    #if (not len(recv_pkg) == recv_pkg_len + 3):
                                        #continue
                                    # Unpack the message based on the protocol definition
                                    device_id, pkg_len, msg_id, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                                    # Respond to the device with an acknoledge package
                                    # time.sleep(0.15)
                                    ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, msg_id, 200)
                                    lora_sock.send(ack_pkg)
                                    print("sent ack")
                                time.sleep(0.2)
                                    # Do any extra processing required for the package. Keep in mind it should be as fast as posible
                                    # to make sure that the other clients are not waiting too long for their messages to be acknoleged
                            Node:
                            import struct
                            from uos import urandom
                            # This device ID, use different device id for each device
                            _DEVICE_ID = 0x01
                            _MAX_ACK_TIME = 5000
                            _RETRY_COUNT = 3
                            # Open a Lora Socket, use tx_iq to avoid listening to our own messages
                            # Method to increase message id and keep in between 1 and 255
                            msg_id = 0
                            def increase_msg_id():
                                global msg_id
                                msg_id = (msg_id + 1) & 0xFF
                            # Method for acknoledge waiting time keep
                            def check_ack_time(from_time):
                                current_time = time.ticks_ms()
                                return (current_time - from_time > _MAX_ACK_TIME)
                            # Method to send messages
                            def send_msg(msg):
                                print("SEND MSG")
                                print(msg)
                                global msg_id
                                retry = _RETRY_COUNT
                                while (retry > 0 and not retry == -1):
                                    retry -= 1
                                    pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), _DEVICE_ID, len(msg), msg_id, msg)
                                    lora_sock.send(pkg)
                                    # Wait for the response from the server.
                                    start_time = time.ticks_ms()
                                    while(not check_ack_time(start_time)):
                                        #print("RECV_ACK")
                                        recv_ack = lora_sock.recv(256)
                                        # If a message of the size of the acknoledge message is received
                                        if (len(recv_ack) == 4):
                                            print("SIZE CORRECT")
                                            device_id, pkg_len, recv_msg_id, status = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                                            if (device_id == _DEVICE_ID and recv_msg_id == msg_id):
                                                if (status == 200):
                                                    # Do some code if your message arrived at the central
                                                    return True
                                                    return False
                                    time.sleep_ms(urandom(1)[0] << 2)
                                return False
                            # Main Loop
                            while(True):
                                success = send_msg("DEVICE %d HERE" % _DEVICE_ID)
                                if (success):
                                    print("ACK RECEIVED: %d" % msg_id)
                                    increase_msg_id()
                                    print("MESSAGE FAILED")
                                    # Manage the error message
                            • sebS Offline
                              seb @heut
                              @heut I will have a closer look at your code now but in the mean time, a few things that often catch users out:
                              • Make sure both LoPy modules are running the same firmware
                              • Please set the frequency to ensure it is the same on both
                              One thing I have already noticed is you have set tx_iq on both the node and the gateway, it should be rx_iq=True for the gateway and tx_iq=True on the nodes.
                              • H Offline
                                heut @seb
                                @seb Thank you so much, that was the point! Setting rx_iq instead of tx_iq True on the Gateway solved the issue. And frequency is set as well.
                                  Archana Kadam @Roberto
                                  @roberto
                                  I have used the above code and the communication between the one node and gateway is generated, but the device id and package. What is the procedure to get the exact connected device.Please update as soon as possible your help will be appreciable.
                                  Thank You
                                  • 2 / 2
