    lopybluetoothblebeaconibeacon
    123 Posts 15 Posters 89.1k Views 14 Watching
      crumble @alanm101
      @alanm101 you may be right. Increase the complexity in your test environment.
      It seems that you are using unblocked communication. So yor timings are not the same when your device is connected to your PC or runs stand alone. Femove the print statements or write to an SD card to make the timings compareable.
      You may receive corrupt data in your demo. Fix A beacon on yourself and your pet. Walk in and out of the BT range during the test. Send data over BT with your mobile.
      And more important. Test your system wit the same settings as the demo. If you cannot increase the amount of beacons in your test, reduce the amount in the demo.
        alanm101 @crumble
        @crumble Good thoughts. However, since some of the original posts, there are new indicators. In a controlled environment (home) where I have 4 beacons, the simple test fails when using Lopy and the Pycom firmware downloaded early this week. See the test code posted a few hours ago.
        Using DIOT ESP32 dev board with official espressif firmware and a simplified version of the gatt_client example, no problems in the same environment.
        Btw, the demo environment is usually at an exhibition centre where there are myriad devices and beacons.
          jmarcelino @alanm101
          @alanm101
          What is this gatt_client.c code? do you mean the gatt_client project at https://github.com/espressif/esp-idf/tree/master/examples/bluetooth/gatt_client ?
          Did you change any esp_ble_scan_params_t there?
          I’m glad you got good results with IDF directly, but I still feel it’s not optimal. My plan is to use the HCI layer directly to scan beacons and skip 90% of the stack.
            alanm101 @jmarcelino
            @jmarcelino Yes, that's the code.
            Changes:
            Line 313: Changed time from 30s to 20000s.
            Lines 331 - 347 removed.
            I'm getting interesting results with further tests. Will post later.
              alanm101 @alanm101
              This is depressing.
              I put all my beacons in a faraday cage (aka microwave oven) and turned off all bluetooth devices. I checked with the Nordic app; no bluetooth signals. I then disabled bluetooth on my phone.
              I fired up a single ESP32 to broadcast an advertisement once per second, using the ble_adv example from the IDF. The serial output of the ESP32 confirmed 1 per second. Fired up the simple code posted before on the Lopy. After around 100 minutes, it stopped picking up beacon signals. After a hard reset, it started working again, so it was not the ESP32 that stopped advertising.
              One thing is strange. Even though the ESP32 is definitely advertising once per second (I can post the serial log and the code), the Lopy is picking up 2.3 - 2.5 advertisements per second. What? Is this expected behaviour? I fired up the Nordic app again and still just the ESP32 broadcasting.
              I'm beginning to think this is a lost cause. Controlled environment, controlled broadcast, one beacon broadcasting once per second, but still the Lopy fails. Anything else I should try before giving up on the Lopy?
              J A 3 Replies Last reply Reply Quote 0
                @alanm101
                Don’t give up yet :) This BLE scanning problems have been on my “to look into” list for far too long and I’ll look into it next week.
                  @jmarcelino Thanks J. If there's anything else I can try meanwhile that might shed more light, please let me know.
                    alanm101 @alanm101
                      alanm101 @alanm101
                      @alanm101 My ignorance knows no bounds. The adv is broadcast on 3 channels, hence the multiple events per broadcast. My new tests are <cough> compensating for that.
                        alanm101 @alanm101
                        Test1: Single beacon using ESP32 at one second intervals.
                        Changes to ble_adv/main/app_bt.c
                        Lines 157-158:
                        uint16_t adv_intv_min = 256x3; // 160ms
                        uint16_t adv_intv_max = 256x3; // 160ms
                        <The 'x' is replaced with an asterisk. Some issue with uploading.>
                        Result: 2 hours with no problems.
                        Test2: Single beacon using ESP32 at one second intervals.
                        Lines 157-158:
                        uint16_t adv_intv_min = 256x2; // 160ms
                        uint16_t adv_intv_max = 256x2; // 160ms
                        Result: 50 minutes, advs no longer detected.
                          alanm101 @alanm101
                          I'm no longer convinced that this is a Lopy/uPython issue. I hacked raw C code and ran on a generic ESP32 using newly acquired knowledge. The code failed. It could be my hacks were wrong or perhaps the ESP32 or the IDF is screwed. I'm now trying new uPython code on the Lopy.
                            @jmarcelino Hi. Have you had a chance to work on this?
                            Regards,
                            Alan.
                              @alanm101
                              Starting on it tonight! I got this to be partially funded by my current client so I’ll have more time for it :)
                                @jmarcelino This hack is working for me so far. If I don't detect a BLE event within 10 seconds, I machine.reset().
                                from network import Bluetooth
                                import binascii
                                import gc
                                beaconlist = ['d3e0f6cd4ca9','e9f1db4814ef']
                                beaconevents = []
                                timelastdata = time.time()
                                def new_adv_event(event):
                                    global beaconlist, beaconevents, timelastdata
                                    if event.events() == Bluetooth.NEW_ADV_EVENT:
                                        anydata = True
                                        while anydata:
                                            adv = bluetooth.get_adv()
                                            if adv != None:
                                                devid = binascii.hexlify(adv[0]).decode('utf-8')
                                                rssi = str(adv[3]*-1)
                                                if devid in beaconlist:
                                                    if len(beaconevents) > 5:
                                                        beaconevents.pop(0)
                                                    beaconevents.append([devid, rssi])
                                                anydata = False
                                print('Starting BLE scan')
                                bluetooth = Bluetooth()
                                bluetooth.callback(trigger = Bluetooth.NEW_ADV_EVENT, handler = new_adv_event)
                                bluetooth.init()
                                bluetooth.start_scan(-1)
                                cycles = 0
                                p_in = machine.Pin('G17',machine.Pin.IN, pull=machine.Pin.PULL_UP)
                                    if p_in() == 0:
                                        print('pin')
                                        bluetooth.stop_scan()
                                        break
                                    cycles += 1
                                    # Run garbage collector every 20 cycles.
                                    if cycles%20 == 0:
                                        gc.collect()
                                    # If no BLE event for 10 seconds, hard reset
                                    if time.time() - timelastdata > 10:
                                        machine.reset()
                                  duffo64 @alanm101
                                  @alanm101
                                  This is a small Arduino sketch on ESP32 Thing (Sparkfun) running without a glitch since this morning.
                                  Moreover, it's happily seeing even my EMBC02 beacons. So, should I presume that in the end it's a micropython issue ?
                                  /Claudio
                                    duffo64 @duffo64
                                    Wow...
                                    On 1.10.1.b1 it's really, really, really better !
                                    ...did I say "really" ?
                                    /Claudio
                                      alanm101
                                      Thanks! I will test this weekend.
                                        duffo64 @alanm101
                                        @alanm101
                                        Despite my initial enthusiasm, I must say that the situation is slightly better using 1.10.2.b1. Basically I had two issues:
                                        • my beacons were not recognized, and this is solved
                                        • callback for advertisements stops firing after a while, but I know that the program is not frozen somewhere. This still unsolved
                                        The very same script is loaded on four WiPy 2.0, two WiPy 3.0 and one LoPy. Only one WiPy 3.0 survived after 18 hours. Sigh.
                                        /Claudio
                                          livius @duffo64
                                          @duffo64
                                          If it survived only on wipy3, this can point me that memory is here problem (only guess).
                                          Did you tried track it down and print gc.mem_free() in the code to see memory consumption?
                                          And do you have gc.collect() in the code or you have enabled automatic garbage collector?
                                            duffo64 @livius
                                            @livius Hi,
                                            Been there, done that. Unfortunately the culprit is not does not seem lack of memory (one WiPy3 still working, the other went south like all WiPy 2).
                                            Anyway, I have collection in code as soon as a ble scan cycle ends.
                                            /Claudio
                                            • 5
                                            • 6
                                            • 7
                                            • 6 / 7
