    lopybluetoothblebeaconibeacon
    123 Posts 15 Posters 89.1k Views 14 Watching
      alanm101 @jmarcelino
      @jmarcelino Thanks J. If there's anything else I can try meanwhile that might shed more light, please let me know.
        alanm101 @alanm101
          alanm101 @alanm101
          @alanm101 My ignorance knows no bounds. The adv is broadcast on 3 channels, hence the multiple events per broadcast. My new tests are <cough> compensating for that.
            alanm101 @alanm101
            Test1: Single beacon using ESP32 at one second intervals.
            Changes to ble_adv/main/app_bt.c
            Lines 157-158:
            uint16_t adv_intv_min = 256x3; // 160ms
            uint16_t adv_intv_max = 256x3; // 160ms
            <The 'x' is replaced with an asterisk. Some issue with uploading.>
            Result: 2 hours with no problems.
            Test2: Single beacon using ESP32 at one second intervals.
            Lines 157-158:
            uint16_t adv_intv_min = 256x2; // 160ms
            uint16_t adv_intv_max = 256x2; // 160ms
            Result: 50 minutes, advs no longer detected.
              alanm101 @alanm101
              I'm no longer convinced that this is a Lopy/uPython issue. I hacked raw C code and ran on a generic ESP32 using newly acquired knowledge. The code failed. It could be my hacks were wrong or perhaps the ESP32 or the IDF is screwed. I'm now trying new uPython code on the Lopy.
                @jmarcelino Hi. Have you had a chance to work on this?
                Regards,
                Alan.
                  jmarcelino @alanm101
                  @alanm101
                  Starting on it tonight! I got this to be partially funded by my current client so I’ll have more time for it :)
                    @jmarcelino This hack is working for me so far. If I don't detect a BLE event within 10 seconds, I machine.reset().
                    from network import Bluetooth
                    import binascii
                    import gc
                    beaconlist = ['d3e0f6cd4ca9','e9f1db4814ef']
                    beaconevents = []
                    timelastdata = time.time()
                    def new_adv_event(event):
                        global beaconlist, beaconevents, timelastdata
                        if event.events() == Bluetooth.NEW_ADV_EVENT:
                            anydata = True
                            while anydata:
                                adv = bluetooth.get_adv()
                                if adv != None:
                                    devid = binascii.hexlify(adv[0]).decode('utf-8')
                                    rssi = str(adv[3]*-1)
                                    if devid in beaconlist:
                                        if len(beaconevents) > 5:
                                            beaconevents.pop(0)
                                        beaconevents.append([devid, rssi])
                                    anydata = False
                    print('Starting BLE scan')
                    bluetooth = Bluetooth()
                    bluetooth.callback(trigger = Bluetooth.NEW_ADV_EVENT, handler = new_adv_event)
                    bluetooth.init()
                    bluetooth.start_scan(-1)
                    cycles = 0
                    p_in = machine.Pin('G17',machine.Pin.IN, pull=machine.Pin.PULL_UP)
                        if p_in() == 0:
                            print('pin')
                            bluetooth.stop_scan()
                            break
                        cycles += 1
                        # Run garbage collector every 20 cycles.
                        if cycles%20 == 0:
                            gc.collect()
                        # If no BLE event for 10 seconds, hard reset
                        if time.time() - timelastdata > 10:
                            machine.reset()
                      duffo64 @alanm101
                      @alanm101
                      This is a small Arduino sketch on ESP32 Thing (Sparkfun) running without a glitch since this morning.
                      Moreover, it's happily seeing even my EMBC02 beacons. So, should I presume that in the end it's a micropython issue ?
                      /Claudio
                        duffo64 @duffo64
                        Wow...
                        On 1.10.1.b1 it's really, really, really better !
                        ...did I say "really" ?
                        /Claudio
                          alanm101
                          Thanks! I will test this weekend.
                            duffo64 @alanm101
                            @alanm101
                            Despite my initial enthusiasm, I must say that the situation is slightly better using 1.10.2.b1. Basically I had two issues:
                            • my beacons were not recognized, and this is solved
                            • callback for advertisements stops firing after a while, but I know that the program is not frozen somewhere. This still unsolved
                            The very same script is loaded on four WiPy 2.0, two WiPy 3.0 and one LoPy. Only one WiPy 3.0 survived after 18 hours. Sigh.
                            /Claudio
                              livius @duffo64
                              @duffo64
                              If it survived only on wipy3, this can point me that memory is here problem (only guess).
                              Did you tried track it down and print gc.mem_free() in the code to see memory consumption?
                              And do you have gc.collect() in the code or you have enabled automatic garbage collector?
                                duffo64 @livius
                                @livius Hi,
                                Been there, done that. Unfortunately the culprit is not does not seem lack of memory (one WiPy3 still working, the other went south like all WiPy 2).
                                Anyway, I have collection in code as soon as a ble scan cycle ends.
                                /Claudio
                                  duffo64 @duffo64
                                  Follow up:
                                  I restarted both WiPy 3 giving them another chance without modifying code at all, and this time was better: more than 24 hours of normal behavior without reboots or BLE lockups. Still, BLE acts randomly in the long run.
                                  BTW there is an IDF related issue on Github that could lead to weird results on the BLE side, as I read.
                                  /Claudio
                                    livius @duffo64
                                    @duffo64
                                    good finding on github.
                                    I saw this kind of assert on the forum.
                                      duffo64 @livius
                                      Yet another update:
                                      This is a WiPy 1.0 with a not-so-recent firmware. Running since two weeks and counting. BLE, WiFi and MQTT are running without hiccups :D
                                      {"ts":1517336479,"pmac":"24xxxxxxxxxx","up":1302802,"fw":"1.12.0.b1","ip":"192.168.0.111"}
                                      /Claudio
                                        jcaron @duffo64
                                        Hi @duffo64,
                                        Can you clarify what was the change that made the difference in the end?
                                          duffo64 @jcaron
                                          @jcaron Hi,
                                          only the firmware :-)
                                          I did not touch anything in my code because I was pretty sure it was working as is.
                                          Now I am patiently waiting for the death (hope not) of two WiPy 3 with the very latest firmware that are running since 47 hours.
                                          /Claudio
                                            tudro
                                            I'm having the same problems with reading the BT advs. My setup is a lopy with a deepsleep shield and 3 ruuvi tags that adv every second. The ruuvis are placed about 3 meters apart. The lopy is on 1.17.0.b1.
                                            The process is: read BT data, go to deepsleep for 15 sec, wake up, read BT data, deepsleep, etc.
                                            I have tried first with the BT example in the pycom docs. The scan was set to 20 seconds. In about 40% of the cases the lopy would not read the data from all the 3 ruuvis.
                                            Then i tried with the deinit/init. Scan for 10 sec, if not all 3 ruuvis read, deinit/init, scan for another 10 sec. It reduced the loss to only about 10%.
                                            In the real case the deepsleep interval will be 1 hour. So, if it doesn't read all the ruuvis, some results will be 2 hours apart or even more, depending on luck, i guess :)
                                            Is there any plan or update on this problem?
                                            Thank you
                                            • 5
                                            • 6
                                            • 7
                                            • 6 / 7
