    New firmware release 1.10.0.b1 (External 4MByte RAM support)
    firmware
    47 Posts 17 Posters 20.3k Views 16 Watching
      ssmith
      @daniel I'm getting the following error while trying to boot
      Rebooting...
      ets Jun  8 2016 00:22:57
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff9028,len:8
      load:0x3fff9030,len:932
      load:0x4009fa00,len:0
      ho 12 tail 0 room 4
      load:0x4009fa00,len:13232
      entry 0x400a04e8
      adding frozen/lib to load path
      Debug print statements TRUE
      mem_free:
      creating ody_globals
      SN: c400b6f0
      _main_interval: 600
      boot_monitor interval: 600
      starting bluetooth configuration
      creating new bt instance
      /Users/danicampora/Code/Espressif/IDF/esp-idf-20171106/components/freertos/./timers.c:670 (prvProcessReceivedCommands)- assert failed!
      abort() was called at PC 0x4008b864 on core 0
      Backtrace: 0x4008cf33:0x3ffd9d50 0x4008cf64:0x3ffd9d70 0x4008b864:0x3ffd9d90
      jDwAABEAAABsAQAA
      NJ79P5Cc/T8snv0/
      wJv9P8Cd/T8AAAAA6D/8P+g//D80nv0/4D/8PxgAAABkl/0/ZJf9PzSe/T8AAAAA
      AQAAADCY/T9UbXIgU3ZjAHn5N0qhEt8AAAAAACye/T8AAAAAIQAGAAEAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAB4Kf0/4Cn9P0gq/T8AAAAAAAAAAAEAAAAAAAAA
      Any ideas?
      Steve
        livius @ssmith
        @ssmith said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
        do you have reproductive test case?
        @daniel interesting which path in xTimerGenericCommand return this failed response
          ssmith @livius
          @livius I haven't tried to narrow it down yet. This occurs while trying to load our whole application. Has something changed with the timers?
            The stack size of the timer task changed. This is probably the culprit (stack overflow).
              daniel @hay4to
              @hay4to we have fixed the machine.reset() hang.
                Hi everyone,
                Thanks for the quick feedback. We are working through all the issues you have reported and a new update will be out within 48hrs.
                  ssmith @daniel
                  @daniel said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                  Is there a way to monitor the stack size and also available memory for loading modules? We have been fighting out of memory issues for months. I know we can move things to frozen bytecode but things are still changing so we can't really do that yet.
                  • X Offline
                    Xykon administrators @ssmith
                    machine.info()
                    System memory info (in bytes)
                    MPTask stack water mark: 5520
                    ServersTask stack water mark: 988
                    LoRaTask stack water mark: 1720
                    TimerTask stack water mark: 976
                    IdleTask stack water mark: 268
                    System free heap: 64744
                    Returns the high water mark of the stack associated with xTask. That is,
                    the minimum free stack space there has been (in words, so on a 32 bit machine a value of 1 means 4 bytes) since the task started. The smaller the returned number the closer the task has come to overflowing its stack.
                    Hope this helps.
                    Christian Ehlers
                      ssmith @Xykon
                      @xykon That's perfect. Thanks!
                      • SmeedyS Offline
                        Smeedy @crumble
                        @crumble Have you been able to fix this?
                        Probably related. I just updated two plain LoPy units to the 1.10.0.b1 and lost the ability to use the REPL for input. Looks like some timings are wrong. I am able to send an occasional ctrl-c if I'm lucky - as it is still running the old main.py, which is odd in it self after the flash.
                        SmeedyS 2 Replies Last reply Reply Quote 0
                        • SmeedyS Offline
                          Smeedy @Smeedy
                          Ok. Managed to get the system up and running again by putting P24 low and erasing the flash using the esptool and start clean. I now have the REPL input back on the LoPy.
                          So if you haven't already
                          pip3 install esptool
                          esptool.py --port /dev/ttyUSB2 --baud 230400 --chip esp32 erase_flash
                          now you can use the UI flasher for 1.10.0.b1
                          • affoltepA Offline
                            affoltep @daniel
                            @affoltep can you be more specific? The new firmware has the same amount of MicroPython heap available as before (67K). What is the error that you are seeing in your app?
                            I was wrong. It doesn't seem to be a memory issue, but a deepsleep shield for LoPy issue. As soon I want to use the deepsleep shield an error message occurs. Unfortunately I can not send you the message, because I flashed back to the old version before doing a print.
                            But here is the code I used to check:
                            import deepsleep
                            ds = deepsleep.DeepSleep()
                            # get the wake reason and the value of the pins during wake up
                            wake_s = ds.get_wake_status()
                            print(wake_s)
                            if wake_s['wake'] == deepsleep.PIN_WAKE:
                                print("Pin wake up")
                            elif wake_s['wake'] == deepsleep.TIMER_WAKE:
                                print("Timer wake up")
                            else:  # deepsleep.POWER_ON_WAKE:
                                print("Power ON reset")
                            #Initiate deep sleep shield
                            ds.enable_auto_poweroff()
                            ds.disable_pullups(['P17', 'P18'])
                            ds.disable_wake_on_raise(['P17', 'P18'])
                            ds.disable_wake_on_fall('P18')
                            ds.enable_wake_on_fall('P17')
                            ds.go_to_sleep(20)  # go to sleep for 60 seconds
                            • SmeedyS Offline
                              Smeedy @Smeedy
                              Last remark. Since 1.10.0.b1 a boot.py fragment on the UART was preventing the REPL input as it seems when using the serial connection. I commented the following part:
                              # uart = UART(0, 115200)
                              # os.dupterm(uart)
                              and I was able to use the REPL again on the 1.10.0.b1 firmware
                                marmarti
                                I found an issue with this version on sipy. I was simply not able to send a message to sigfox.
                                • K Offline
                                  ksid @Smeedy
                                  @smeedy I think you meant P2 here or G23 on the breakout. This is exactly what I needed and solved my problem. As a note to others after erasing the flash I had to remove and re-apply power before running the UI flasher.
                                    paulS @marmarti
                                    @marmarti said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                                    I'm also not able to send any sigfox messages with this version. Where can I get older firmware to revert to a working version?
                                    • X Offline
                                      Xykon administrators @paulS
                                      @pauls said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                                      I posted links to the previous firmware in this thread, along with a link to the downgrade instructions.
                                      Christian Ehlers
                                        ssmith
                                        I'd like to suggest that PyCom develop a Beta program for firmware releases. Developers could test out the code and supply feedback before it is pushed to the update server. With the current scheme, anyone who updates the firmware with the update tool gets the latest firmware without a choice. Whatever is pushed by the update tool should be a fully working and tested version.
                                        • X Offline
                                          @ssmith I'm actually looking into this at the moment.
                                          Christian Ehlers
                                          • K Offline
                                            ksid @daniel
                                            @daniel Do you know when we can expect to see the updated docs on how to use ADC.voltage() and .calibration()?
                                            X sebS 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
