    New firmware release 1.10.0.b1 (External 4MByte RAM support)
    firmware
    47 Posts 17 Posters 20.3k Views 16 Watching
    • SmeedyS Offline
      Smeedy @crumble
      @crumble Have you been able to fix this?
      Probably related. I just updated two plain LoPy units to the 1.10.0.b1 and lost the ability to use the REPL for input. Looks like some timings are wrong. I am able to send an occasional ctrl-c if I'm lucky - as it is still running the old main.py, which is odd in it self after the flash.
      SmeedyS 2 Replies Last reply Reply Quote 0
      • SmeedyS Offline
        Smeedy @Smeedy
        Ok. Managed to get the system up and running again by putting P24 low and erasing the flash using the esptool and start clean. I now have the REPL input back on the LoPy.
        So if you haven't already
        pip3 install esptool
        esptool.py --port /dev/ttyUSB2 --baud 230400 --chip esp32 erase_flash
        now you can use the UI flasher for 1.10.0.b1
        • affoltepA Offline
          affoltep @daniel
          @daniel said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
          @affoltep can you be more specific? The new firmware has the same amount of MicroPython heap available as before (67K). What is the error that you are seeing in your app?
          I was wrong. It doesn't seem to be a memory issue, but a deepsleep shield for LoPy issue. As soon I want to use the deepsleep shield an error message occurs. Unfortunately I can not send you the message, because I flashed back to the old version before doing a print.
          But here is the code I used to check:
          import deepsleep
          ds = deepsleep.DeepSleep()
          # get the wake reason and the value of the pins during wake up
          wake_s = ds.get_wake_status()
          print(wake_s)
          if wake_s['wake'] == deepsleep.PIN_WAKE:
              print("Pin wake up")
          elif wake_s['wake'] == deepsleep.TIMER_WAKE:
              print("Timer wake up")
          else:  # deepsleep.POWER_ON_WAKE:
              print("Power ON reset")
          #Initiate deep sleep shield
          ds.enable_auto_poweroff()
          ds.disable_pullups(['P17', 'P18'])
          ds.disable_wake_on_raise(['P17', 'P18'])
          ds.disable_wake_on_fall('P18')
          ds.enable_wake_on_fall('P17')
          ds.go_to_sleep(20)  # go to sleep for 60 seconds
          • SmeedyS Offline
            Smeedy @Smeedy
            Last remark. Since 1.10.0.b1 a boot.py fragment on the UART was preventing the REPL input as it seems when using the serial connection. I commented the following part:
            # uart = UART(0, 115200)
            # os.dupterm(uart)
            and I was able to use the REPL again on the 1.10.0.b1 firmware
              marmarti
              I found an issue with this version on sipy. I was simply not able to send a message to sigfox.
              • K Offline
                ksid @Smeedy
                @smeedy I think you meant P2 here or G23 on the breakout. This is exactly what I needed and solved my problem. As a note to others after erasing the flash I had to remove and re-apply power before running the UI flasher.
                  paulS @marmarti
                  @marmarti said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                  I'm also not able to send any sigfox messages with this version. Where can I get older firmware to revert to a working version?
                  • X Offline
                    Xykon administrators @paulS
                    @pauls said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                    I posted links to the previous firmware in this thread, along with a link to the downgrade instructions.
                    Christian Ehlers
                      ssmith
                      I'd like to suggest that PyCom develop a Beta program for firmware releases. Developers could test out the code and supply feedback before it is pushed to the update server. With the current scheme, anyone who updates the firmware with the update tool gets the latest firmware without a choice. Whatever is pushed by the update tool should be a fully working and tested version.
                      • X Offline
                        Xykon administrators @ssmith
                        @ssmith I'm actually looking into this at the moment.
                        Christian Ehlers
                        • K Offline
                          ksid @daniel
                          @daniel Do you know when we can expect to see the updated docs on how to use ADC.voltage() and .calibration()?
                          X sebS 2 Replies Last reply Reply Quote 0
                          • X Offline
                            Xykon administrators @ksid
                            @ksid We're currently doing some additional testing on this... we should be able to put this into the documentation in the next few days.
                            Christian Ehlers
                              paulS @Xykon
                              @xykon
                              thanks - this worked
                              • E Offline
                                Eric24
                                Where is this documented? "esp32: Add function to get the remaining deep sleep time after wake-up."
                                • sebS Offline
                                  seb @ksid
                                  @ksid The API and tutorial docs have been updated to add the new methods as well as the procedure for calibrating the ADC
                                  E K 2 Replies Last reply Reply Quote 2
                                  • E Offline
                                    Eric24 @seb
                                    @seb Sorry, but I'm not seeing where "esp32: Add function to get the remaining deep sleep time after wake-up" is documented. Can you point me to the page in the docs?
                                    • sebS Offline
                                      seb @Eric24
                                      @eric24 Sorry this feature hasn't been documented yet. I will get back to you as soon as it is documented.
                                      • sebS Offline
                                        seb @Eric24
                                        @eric24 Hi the method has been added to the docs
                                        • K Offline
                                          ksid @seb
                                          @seb Thanks, I found them and was able to start playing with the new calls.
                                          • 2 / 3
