New firmware release 1.10.0.b1 (External 4MByte RAM support)
Ok. Managed to get the system up and running again by putting P24 low and erasing the flash using the esptool and start clean. I now have the REPL input back on the LoPy.
So if you haven't already
pip3 install esptool esptool.py --port /dev/ttyUSB2 --baud 230400 --chip esp32 erase_flashnow you can use the UI flasher for 1.10.0.b1
@daniel said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
@affoltep can you be more specific? The new firmware has the same amount of MicroPython heap available as before (67K). What is the error that you are seeing in your app?
DanielI was wrong. It doesn't seem to be a memory issue, but a deepsleep shield for LoPy issue. As soon I want to use the deepsleep shield an error message occurs. Unfortunately I can not send you the message, because I flashed back to the old version before doing a print.
But here is the code I used to check:
import deepsleep ds = deepsleep.DeepSleep() # get the wake reason and the value of the pins during wake up wake_s = ds.get_wake_status() print(wake_s) if wake_s['wake'] == deepsleep.PIN_WAKE: print("Pin wake up") elif wake_s['wake'] == deepsleep.TIMER_WAKE: print("Timer wake up") else: # deepsleep.POWER_ON_WAKE: print("Power ON reset") #Initiate deep sleep shield ds = deepsleep.DeepSleep() ds.enable_auto_poweroff() ds.disable_pullups(['P17', 'P18']) ds.disable_wake_on_raise(['P17', 'P18']) ds.disable_wake_on_fall('P18') ds.enable_wake_on_fall('P17') ds.go_to_sleep(20) # go to sleep for 60 seconds -
Last remark. Since 1.10.0.b1 a boot.py fragment on the UART was preventing the REPL input as it seems when using the serial connection. I commented the following part:
# uart = UART(0, 115200) # os.dupterm(uart)and I was able to use the REPL again on the 1.10.0.b1 firmware
I found an issue with this version on sipy. I was simply not able to send a message to sigfox.
@smeedy I think you meant P2 here or G23 on the breakout. This is exactly what I needed and solved my problem. As a note to others after erasing the flash I had to remove and re-apply power before running the UI flasher.
@marmarti said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
I'm also not able to send any sigfox messages with this version. Where can I get older firmware to revert to a working version? -
@pauls said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
I posted links to the previous firmware in this thread, along with a link to the downgrade instructions.
I'd like to suggest that PyCom develop a Beta program for firmware releases. Developers could test out the code and supply feedback before it is pushed to the update server. With the current scheme, anyone who updates the firmware with the update tool gets the latest firmware without a choice. Whatever is pushed by the update tool should be a fully working and tested version.
@ssmith I'm actually looking into this at the moment.
@daniel Do you know when we can expect to see the updated docs on how to use ADC.voltage() and .calibration()?
@ksid We're currently doing some additional testing on this... we should be able to put this into the documentation in the next few days.
@xykon
thanks - this worked -
Where is this documented? "esp32: Add function to get the remaining deep sleep time after wake-up."
@ksid The API and tutorial docs have been updated to add the new methods as well as the procedure for calibrating the ADC
@seb Sorry, but I'm not seeing where "esp32: Add function to get the remaining deep sleep time after wake-up" is documented. Can you point me to the page in the docs?
@eric24 Sorry this feature hasn't been documented yet. I will get back to you as soon as it is documented.
@eric24 Hi the method has been added to the docs
@seb Thanks, I found them and was able to start playing with the new calls.
