New firmware release 1.10.0.b1 (External 4MByte RAM support)
I found an issue with this version on sipy. I was simply not able to send a message to sigfox.
@smeedy I think you meant P2 here or G23 on the breakout. This is exactly what I needed and solved my problem. As a note to others after erasing the flash I had to remove and re-apply power before running the UI flasher.
@marmarti said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
I'm also not able to send any sigfox messages with this version. Where can I get older firmware to revert to a working version? -
@pauls said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
I posted links to the previous firmware in this thread, along with a link to the downgrade instructions.
I'd like to suggest that PyCom develop a Beta program for firmware releases. Developers could test out the code and supply feedback before it is pushed to the update server. With the current scheme, anyone who updates the firmware with the update tool gets the latest firmware without a choice. Whatever is pushed by the update tool should be a fully working and tested version.
@ssmith I'm actually looking into this at the moment.
@daniel Do you know when we can expect to see the updated docs on how to use ADC.voltage() and .calibration()?
@ksid We're currently doing some additional testing on this... we should be able to put this into the documentation in the next few days.
@xykon
thanks - this worked -
Where is this documented? "esp32: Add function to get the remaining deep sleep time after wake-up."
@ksid The API and tutorial docs have been updated to add the new methods as well as the procedure for calibrating the ADC
@seb Sorry, but I'm not seeing where "esp32: Add function to get the remaining deep sleep time after wake-up" is documented. Can you point me to the page in the docs?
@eric24 Sorry this feature hasn't been documented yet. I will get back to you as soon as it is documented.
@eric24 Hi the method has been added to the docs
@seb Thanks, I found them and was able to start playing with the new calls.
