    New firmware release 1.10.0.b1 (External 4MByte RAM support)
    firmware
    47 Posts 17 Posters 20.3k Views 16 Watching
    • X Offline
      Xykon administrators @ssmith
      @ssmith said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
      Is there a way to monitor the stack size
      machine.info()
      System memory info (in bytes)
      MPTask stack water mark: 5520
      ServersTask stack water mark: 988
      LoRaTask stack water mark: 1720
      TimerTask stack water mark: 976
      IdleTask stack water mark: 268
      System free heap: 64744
      Returns the high water mark of the stack associated with xTask. That is,
      the minimum free stack space there has been (in words, so on a 32 bit machine a value of 1 means 4 bytes) since the task started. The smaller the returned number the closer the task has come to overflowing its stack.
      Hope this helps.
      Christian Ehlers
        ssmith @Xykon
        @xykon That's perfect. Thanks!
        • SmeedyS Offline
          Smeedy @crumble
          @crumble Have you been able to fix this?
          Probably related. I just updated two plain LoPy units to the 1.10.0.b1 and lost the ability to use the REPL for input. Looks like some timings are wrong. I am able to send an occasional ctrl-c if I'm lucky - as it is still running the old main.py, which is odd in it self after the flash.
          SmeedyS 2 Replies Last reply Reply Quote 0
          • SmeedyS Offline
            Smeedy @Smeedy
            Ok. Managed to get the system up and running again by putting P24 low and erasing the flash using the esptool and start clean. I now have the REPL input back on the LoPy.
            So if you haven't already
            pip3 install esptool
            esptool.py --port /dev/ttyUSB2 --baud 230400 --chip esp32 erase_flash
            now you can use the UI flasher for 1.10.0.b1
            • affoltepA Offline
              affoltep @daniel
              @daniel said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
              @affoltep can you be more specific? The new firmware has the same amount of MicroPython heap available as before (67K). What is the error that you are seeing in your app?
              I was wrong. It doesn't seem to be a memory issue, but a deepsleep shield for LoPy issue. As soon I want to use the deepsleep shield an error message occurs. Unfortunately I can not send you the message, because I flashed back to the old version before doing a print.
              But here is the code I used to check:
              import deepsleep
              ds = deepsleep.DeepSleep()
              # get the wake reason and the value of the pins during wake up
              wake_s = ds.get_wake_status()
              print(wake_s)
              if wake_s['wake'] == deepsleep.PIN_WAKE:
                  print("Pin wake up")
              elif wake_s['wake'] == deepsleep.TIMER_WAKE:
                  print("Timer wake up")
              else:  # deepsleep.POWER_ON_WAKE:
                  print("Power ON reset")
              #Initiate deep sleep shield
              ds.enable_auto_poweroff()
              ds.disable_pullups(['P17', 'P18'])
              ds.disable_wake_on_raise(['P17', 'P18'])
              ds.disable_wake_on_fall('P18')
              ds.enable_wake_on_fall('P17')
              ds.go_to_sleep(20)  # go to sleep for 60 seconds
              • SmeedyS Offline
                Smeedy @Smeedy
                Last remark. Since 1.10.0.b1 a boot.py fragment on the UART was preventing the REPL input as it seems when using the serial connection. I commented the following part:
                # uart = UART(0, 115200)
                # os.dupterm(uart)
                and I was able to use the REPL again on the 1.10.0.b1 firmware
                  marmarti
                  I found an issue with this version on sipy. I was simply not able to send a message to sigfox.
                  • K Offline
                    ksid @Smeedy
                    @smeedy I think you meant P2 here or G23 on the breakout. This is exactly what I needed and solved my problem. As a note to others after erasing the flash I had to remove and re-apply power before running the UI flasher.
                      paulS @marmarti
                      @marmarti said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                      I'm also not able to send any sigfox messages with this version. Where can I get older firmware to revert to a working version?
                      • X Offline
                        Xykon administrators @paulS
                        @pauls said in New firmware release 1.10.0.b1 (External 4MByte RAM support):
                        I posted links to the previous firmware in this thread, along with a link to the downgrade instructions.
                        Christian Ehlers
                          ssmith
                          I'd like to suggest that PyCom develop a Beta program for firmware releases. Developers could test out the code and supply feedback before it is pushed to the update server. With the current scheme, anyone who updates the firmware with the update tool gets the latest firmware without a choice. Whatever is pushed by the update tool should be a fully working and tested version.
                          • X Offline
                            @ssmith I'm actually looking into this at the moment.
                            Christian Ehlers
                            • K Offline
                              ksid @daniel
                              @daniel Do you know when we can expect to see the updated docs on how to use ADC.voltage() and .calibration()?
                              X sebS 2 Replies Last reply Reply Quote 0
                              • X Offline
                                Xykon administrators @ksid
                                @ksid We're currently doing some additional testing on this... we should be able to put this into the documentation in the next few days.
                                Christian Ehlers
                                  paulS @Xykon
                                  @xykon
                                  thanks - this worked
                                  • E Offline
                                    Eric24
                                    Where is this documented? "esp32: Add function to get the remaining deep sleep time after wake-up."
                                    • sebS Offline
                                      seb @ksid
                                      @ksid The API and tutorial docs have been updated to add the new methods as well as the procedure for calibrating the ADC
                                      E K 2 Replies Last reply Reply Quote 2
                                      • E Offline
                                        Eric24 @seb
                                        @seb Sorry, but I'm not seeing where "esp32: Add function to get the remaining deep sleep time after wake-up" is documented. Can you point me to the page in the docs?
                                        • sebS Offline
                                          seb @Eric24
                                          @eric24 Sorry this feature hasn't been documented yet. I will get back to you as soon as it is documented.
                                          • sebS Offline
                                            seb @Eric24
                                            @eric24 Hi the method has been added to the docs
                                            • 2 / 3
