    BME280 on the LoPy
    bme280lopyi2c
    41 Posts 12 Posters 16.7k Views 12 Watching
      Devang Sharma
      Hello Everyone,
      I'm using LoPy and I've got the similar type of error as @binux got.
      I'm getting the following error:
      This is my code:
      Please guide me solving this!
      Thank You.
        robert-hh @Devang Sharma
        @devang-sharma The required positional argument is 'little' in the call of from_bytes(). The API was changed a while ago. You have to modify the script BM280.py into:
                result = int.from_bytes(
                    self._i2c.readfrom_mem(self._address, register, 2), little) & 0xFFFF
        The same in function readU8().
          Devang Sharma @robert-hh
          @robert-hh I've done changes as you said but got the NameError as:
          "name 'little' is not defined". How can I solve it?
          Thank You.
            @devang-sharma Sorry, it should be a string:
                        self._i2c.readfrom_mem(self._address, register, 2), 'little') & 0xFFFF
              @robert-hh, that worked! Thanks, but the same error for write8:
              Is there any link to the changed API or library? That would be better than posting every single error! :'D
              EDIT: Solved the error. Replaced value.to_bytes(1) with "value"! No more Errors!
                @devang-sharma No specific API doc needed, since it is standard Python behaviour now. It was incompatible before, but I'm not shure, for which MicroPython version. It may be that the Pycom branch always was compatible to the Standard.
                And yes, even in that case changes toward language compliance may break code, so it should be noted.
                  robd
                  There are quite a few entries on the BME280.
                  I have been reading them and I am still not able to fix my issues.
                  I have tried several of the libraries and I am just at a stand still.
                  When I do a scan of the I2C port I get 0x76 so I know that the sensor is there.
                  What I get is as follows (firmware rev 1.10.2.b1)
                  Thank you,
                    robert-hh @robd
                    @robd Actually, which bme280 code are you using at the moment? I'm a little bit lost too.
                      Devang Sharma
                      @robd I've faced a similar issue and added argument 'little' as @robert-hh suggested which worked for me. I don't know which library you're using. But I've been using this:
                      https://github.com/LoRaWeather/BME280-LoPy-TTN/tree/master/Program/lib
                      • sebS Offline
                        seb
                          robd @Devang Sharma
                          @devang-sharma thank you for the link. I really hate learning curves. I tried the TTN libraries and I still have issues. How are you calling the library?
                          I am trying with (firmware version 1.10.2.b1)
                          from machine import I2C
                          import BME280
                          i2c = I2C(0,I2C.MASTER, baudrate=100000)
                          bme = bme280.BM280(i2c=i2c)
                          print('Temp = ', bme280.temperate())
                          the errors I am getting are
                          I then tried to see if my sensor was readable and I did
                          i2c.scan()
                          which returned 118 (0x76)
                          then I did the following
                          Any pointers to my errors?
                          Thank you
                            robd @robert-hh
                            @robert-hh I have tired several libraries, LoPy_BME280, oscarBravo-wipy_bme280, and mpy_bme280_esp8266.
                            https://github.com/ButchAnton/LoPy_BME280
                            https://github.com/catdog2/mpy_bme280_esp8266
                            https://bitbucket.org/oscarBravo/wipy_bme280/src/7c03d16f48154a55a9c09af65049b0f03ef6c005?at=default
                            and thank you to @devang-sharma
                            I must be doing something really wrong for nothing to work correctly.
                            I switched over to a Si7021 and I was able to get that to work but I need to use the BME280.
                              Devang Sharma @robd
                              @robd The first error you're getting is because of indentation of the return function. Write it within def humidity(self). I guess you're new to python, it'd be better if you read docs properly.
                              The second error is due to the way you've used import BME280. The library has a class BME280. There are 2 ways to solve this:
                              1. You can import it as from BME280 import * and make a constructor just after i2c something like this: bme = BME280(address=BME280_I2CADDR, i2c=i2c)
                              OR
                              2. keep it as import BME280 and constructor as:
                              bme = BME280.BME280(address=BME280_I2CADDR, i2c=i2c)
                              Make sure to use the same name as defined in the library.
                              I hope this helps you.
                                robd @Devang Sharma
                                @devang-sharma the code used was from https://github.com/LoRaWeather/BME280-LoPy-TTN/tree/master/Program/lib
                                I copied everything over as it was and didn't modify anything.
                                The code which I tried to write and didn't work was
                                import BME280
                                print('Temp = ', BME280.temperature())
                                Yes I am new to python and right now it is kicking me, I didn't see any docs other than small comments in the code. So it was me trying to feel around and get this sensor working.
                                I was able to get a SI7021(different code) to work but not the BME280.
                                I will look at and try to understand your suggestions.
                                Thank you for your help
                                  Devang Sharma @robd
                                  @robd I think you didn't get me correctly.
                                  Anyways, try the code as below:
                                  import BME280
                                  print('Temp = ', bme.temperature())
                                    Lucas_Vieira
                                    Hello guys. i'm having similar problems here. Would you help me?
                                    import bme280 # from bme280
                                    i2c = I2C(0, I2C.MASTER)             # create and init as a master
                                    i2c.init(I2C.MASTER, baudrate=10000) # init as a master
                                    i2c.scan()
                                    print(i2c.scan())
                                    bmet = []   # Lista com as temperaturas lidas com o BME280
                                    bmeh = []   # Lista com as umiadades lidas com o BME280
                                    bmep = []   # Lista com as pressoes lidas com o BME280
                                    bme = bme280.BME280(i2c=i2c, pressure_mode=bme280.OSAMPLE_8, iir=bme280.FILTER_8)
                                    bme_s = True
                                        for cycles in range(10):
                                            # Le valores BME280 com media para ter maior precisao :
                                            numreadings = 5
                                            samples_temperature = [0.0]*numreadings; mean_temperature = 0.0
                                            samples_pressure = [0.0]*numreadings; mean_pressure = 0.0
                                            samples_humidity = [0.0]*numreadings; mean_humidity = 0.0
                                            for i in range (numreadings):
                                                samples_temperature[i], samples_pressure[i], samples_humidity[i] = bme.values
                                            mean_temperature = sum(samples_temperature)/len(samples_temperature)
                                            mean_pressure = sum(samples_pressure)/len(samples_pressure)
                                            mean_humidity = sum(samples_humidity)/len(samples_humidity)
                                            t = mean_temperature
                                            p = mean_pressure/101325   # Pa -> hectoPa
                                            h = mean_humidity
                                            bmet.append(t)
                                            bmep.append(p)
                                            bmeh.append(h)
                                        print(t)
                                        print(p)
                                        #print(h)
                                        time.sleep(3)
                                    My problems:
                                    File lib bme280:
                                    bme280.py
                                    S robert-hhR 3 Replies Last reply Reply Quote 0
                                      svonbentzel @Lucas_Vieira
                                      @Lucas_Vieira i2c.scan() reports the correct sensor? 108 (I mean)??
                                        @Lucas_Vieira
                                        Do you have tried the other modes?
                                        The sensor is correct wired? Sda / p9 and scl p10 in example?
                                          Lucas_Vieira @svonbentzel
                                          @svonbentzel thank you very much for reply!
                                          1. i2c.scan() report: [118]
                                          2. What modes are they? I did not understand what you meant.
                                          3. Yes, the pins are correct!
                                          Note: Right now, it's running perfect. No more errors appear in the code, it is strange at least hahaha. However, since yesterday I have not received any sign of humidity, is there any clue where the error is? I can not find.
                                          (I uncommented "print (h)" in the last code).
                                          The image data is pressure (1.0), temperature (27ÂșC) and humidity (0.0) respectively.
                                            robert-hh @Lucas_Vieira
                                            @Lucas_Vieira The value for pressure is also strange. The class function values returns Pascal, so the expected numbers are in the range of 100000.
                                            You may also try my variations of the adafruit driver. Most of the BME280 drivers I have seen are based on that. You may have to change values(), to return t,p,h instead of formatted strings. I used that driver a lot with pycom devices and it worked well. The sensors I used were sometimes out of range.
                                            https://github.com/robert-hh/BME280
                                            There are two variants, which differn from the mode of internal calculations (float or int). The results are comparable.
                                            • 2 / 3
