    BME280 on the LoPy
    bme280lopyi2c
    41 Posts 12 Posters 16.7k Views 12 Watching
      robert-hh @Devang Sharma
      @devang-sharma No specific API doc needed, since it is standard Python behaviour now. It was incompatible before, but I'm not shure, for which MicroPython version. It may be that the Pycom branch always was compatible to the Standard.
      And yes, even in that case changes toward language compliance may break code, so it should be noted.
        robd
        There are quite a few entries on the BME280.
        I have been reading them and I am still not able to fix my issues.
        I have tried several of the libraries and I am just at a stand still.
        When I do a scan of the I2C port I get 0x76 so I know that the sensor is there.
        What I get is as follows (firmware rev 1.10.2.b1)
        Thank you,
          robert-hh @robd
          @robd Actually, which bme280 code are you using at the moment? I'm a little bit lost too.
            Devang Sharma
            @robd I've faced a similar issue and added argument 'little' as @robert-hh suggested which worked for me. I don't know which library you're using. But I've been using this:
            https://github.com/LoRaWeather/BME280-LoPy-TTN/tree/master/Program/lib
            • sebS Offline
              seb
                robd @Devang Sharma
                @devang-sharma thank you for the link. I really hate learning curves. I tried the TTN libraries and I still have issues. How are you calling the library?
                I am trying with (firmware version 1.10.2.b1)
                from machine import I2C
                import BME280
                i2c = I2C(0,I2C.MASTER, baudrate=100000)
                bme = bme280.BM280(i2c=i2c)
                print('Temp = ', bme280.temperate())
                the errors I am getting are
                I then tried to see if my sensor was readable and I did
                i2c.scan()
                which returned 118 (0x76)
                then I did the following
                Any pointers to my errors?
                Thank you
                  robd @robert-hh
                  @robert-hh I have tired several libraries, LoPy_BME280, oscarBravo-wipy_bme280, and mpy_bme280_esp8266.
                  https://github.com/ButchAnton/LoPy_BME280
                  https://github.com/catdog2/mpy_bme280_esp8266
                  https://bitbucket.org/oscarBravo/wipy_bme280/src/7c03d16f48154a55a9c09af65049b0f03ef6c005?at=default
                  and thank you to @devang-sharma
                  I must be doing something really wrong for nothing to work correctly.
                  I switched over to a Si7021 and I was able to get that to work but I need to use the BME280.
                    Devang Sharma @robd
                    @robd The first error you're getting is because of indentation of the return function. Write it within def humidity(self). I guess you're new to python, it'd be better if you read docs properly.
                    The second error is due to the way you've used import BME280. The library has a class BME280. There are 2 ways to solve this:
                    1. You can import it as from BME280 import * and make a constructor just after i2c something like this: bme = BME280(address=BME280_I2CADDR, i2c=i2c)
                    OR
                    2. keep it as import BME280 and constructor as:
                    bme = BME280.BME280(address=BME280_I2CADDR, i2c=i2c)
                    Make sure to use the same name as defined in the library.
                    I hope this helps you.
                      robd @Devang Sharma
                      @devang-sharma the code used was from https://github.com/LoRaWeather/BME280-LoPy-TTN/tree/master/Program/lib
                      I copied everything over as it was and didn't modify anything.
                      The code which I tried to write and didn't work was
                      import BME280
                      print('Temp = ', BME280.temperature())
                      Yes I am new to python and right now it is kicking me, I didn't see any docs other than small comments in the code. So it was me trying to feel around and get this sensor working.
                      I was able to get a SI7021(different code) to work but not the BME280.
                      I will look at and try to understand your suggestions.
                      Thank you for your help
                        Devang Sharma @robd
                        @robd I think you didn't get me correctly.
                        Anyways, try the code as below:
                        import BME280
                        print('Temp = ', bme.temperature())
                          Lucas_Vieira
                          Hello guys. i'm having similar problems here. Would you help me?
                          import bme280 # from bme280
                          i2c = I2C(0, I2C.MASTER)             # create and init as a master
                          i2c.init(I2C.MASTER, baudrate=10000) # init as a master
                          i2c.scan()
                          print(i2c.scan())
                          bmet = []   # Lista com as temperaturas lidas com o BME280
                          bmeh = []   # Lista com as umiadades lidas com o BME280
                          bmep = []   # Lista com as pressoes lidas com o BME280
                          bme = bme280.BME280(i2c=i2c, pressure_mode=bme280.OSAMPLE_8, iir=bme280.FILTER_8)
                          bme_s = True
                              for cycles in range(10):
                                  # Le valores BME280 com media para ter maior precisao :
                                  numreadings = 5
                                  samples_temperature = [0.0]*numreadings; mean_temperature = 0.0
                                  samples_pressure = [0.0]*numreadings; mean_pressure = 0.0
                                  samples_humidity = [0.0]*numreadings; mean_humidity = 0.0
                                  for i in range (numreadings):
                                      samples_temperature[i], samples_pressure[i], samples_humidity[i] = bme.values
                                  mean_temperature = sum(samples_temperature)/len(samples_temperature)
                                  mean_pressure = sum(samples_pressure)/len(samples_pressure)
                                  mean_humidity = sum(samples_humidity)/len(samples_humidity)
                                  t = mean_temperature
                                  p = mean_pressure/101325   # Pa -> hectoPa
                                  h = mean_humidity
                                  bmet.append(t)
                                  bmep.append(p)
                                  bmeh.append(h)
                              print(t)
                              print(p)
                              #print(h)
                              time.sleep(3)
                          My problems:
                          File lib bme280:
                          bme280.py
                          S robert-hhR 3 Replies Last reply Reply Quote 0
                            svonbentzel @Lucas_Vieira
                            @Lucas_Vieira i2c.scan() reports the correct sensor? 108 (I mean)??
                              @Lucas_Vieira
                              Do you have tried the other modes?
                              The sensor is correct wired? Sda / p9 and scl p10 in example?
                                Lucas_Vieira @svonbentzel
                                @svonbentzel thank you very much for reply!
                                1. i2c.scan() report: [118]
                                2. What modes are they? I did not understand what you meant.
                                3. Yes, the pins are correct!
                                Note: Right now, it's running perfect. No more errors appear in the code, it is strange at least hahaha. However, since yesterday I have not received any sign of humidity, is there any clue where the error is? I can not find.
                                (I uncommented "print (h)" in the last code).
                                The image data is pressure (1.0), temperature (27ºC) and humidity (0.0) respectively.
                                  robert-hh @Lucas_Vieira
                                  @Lucas_Vieira The value for pressure is also strange. The class function values returns Pascal, so the expected numbers are in the range of 100000.
                                  You may also try my variations of the adafruit driver. Most of the BME280 drivers I have seen are based on that. You may have to change values(), to return t,p,h instead of formatted strings. I used that driver a lot with pycom devices and it worked well. The sensors I used were sometimes out of range.
                                  https://github.com/robert-hh/BME280
                                  There are two variants, which differn from the mode of internal calculations (float or int). The results are comparable.
                                    Lucas_Vieira @robert-hh
                                    Hi Robert.
                                    1. The pressure value is strange because I had converted to ATM. But I returned to normal, getting the value in Pascal.
                                    2. can't your drive receive temperature, pressure and humidity values ​​separately? I need to send the data to my cayenne application.
                                    I am having these cayenne LPP errors. Can you help me? I need to open a new post or we can keep talking on this I2C topic, maybe it could be wrong?
                                      @Lucas_Vieira Yes, just change the last line of the method values() to:
                                      return t, p, h
                                      I never had sent values directly to cayenne, only through TTN. Which cayenne LPP module are you using?
                                      Edit: In my tests, the value for humidity was the one with the largest error, but still not 0. Are you sure that you have a BME280 device and not an BMP280? If you look at the package, there are two lines of letters
                                      BME280:
                                      xxx
                                      Ux
                                      BMP280:
                                      xxx
                                      Kx
                                      The difference is U vs. K
                                      • 2 / 3
