    How to connect a LoPy to a moisture sensor?
    lopysensorsen0193moisture sensor
    15 Posts 4 Posters 4.5k Views 4 Watching
      JeromeMaquoi @robert-hh
      @robert-hh I changed the code but now, it's not working at all. I put your code on the LoPy and here is what I see when I launch it. :/
      0_1509379714724_Capture du 2017-10-30 17:06:24.png
        robert-hh @JeromeMaquoi
        @jeromemaquoi Please update the firmware. You seem to have a state of December 2016.
          @robert-hh Oh yes. Thank you ofr your answers, it works now! :D
            gruia.nichita @robert-hh
            @robert-hh Hi, Robert! Why I get the value more than 1000, but in the specification wrote that i can get value to 950.
            Thank you for your answers,
            Nichita
              robert-hh @gruia.nichita
              @gruia-nichita This statement is just for the example setup with an arduino and maybe an 10 Bit ADC. Using Lopy, the maximum output value of the ADC in 12 bit mode is 4095.
                @robert-hh So I have the same result in percentage?
                  @gruia-nichita The adc just returns a reading for a voltage. To get a percentage reading, you have to calibrate your set-up with the minimum and maximum reading. You get the minimum reading certainly when you just stick the dry sensor into the air. For the maximum reading you can stick the sensor either into wet soil or salted water. Then the perctentage reading is like:
                  act_reading/(maximum - minimum) * 100
                  assuming there is a linear relation between adc reading and humidity.
                    Rachelsimida @robert-hh
                    @robert-hh Hi, I want to know if it is the same principle and operation for me to connect lopy with an ultrasonic sensor. I try your code but it reply nothing on the screen. I have two kind of sensors but I only use one to connect with lopy.
                    This is the model of my 2 senosrs. One is HC-SR04 with 4 feet: trig,echo,vcc,gnd; The other sensor has 3 feet: vcc,gnd,sig.
                    The screenshot from using the 3 feet sensor. If there is something missing of my code. I am beginner of this.
                    Thank you!
                      robert-hh @Rachelsimida
                      @rachelsimida Yes, the principle is completely different. While for the humidity sensor you had to take an analog value, you have to determine here the length of a pulse. Would you mind to tell me the type of the other sensor which you try to use here?
                      I must say that w/o a snesor at hand I can give you only vague directions.
                      R 2 Replies Last reply Reply Quote 0
                          @robert-hh Thanks for your reply.
                          I only have two sensors at hand now. No matter which one I use, it's ok. Since the principle is completely different. For the two sensors, do you familiar with them? Can you teach me some direction about how to program if you know. It's hard to find the same topic in the website and I am extremely confused now. Thanks! This is the image of the sensor, which provided by my supervisor.0_1519505277502_hc-sr04-sonar-sensor.jpg
