    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 28.0k Views 6 Watching
      livius @Archana Kadam
      @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
      Could you please share us the code to how to read other sensors and store the readings in csv file in fipy device memory using Pysense expansion board.
      This is not good to store frequently changed data to flash (limited write cycles)
      but if you really need you can use obvious python code
      with open("/flash/myfile.xyz", "ab") as f:
          f.write(data)
      for sensors look at library sample
      https://github.com/pycom/pycom-libraries/blob/master/pysense/main.py
      How to access the inbuilt file structure of FiPy.
      connect to it by ftp - look into online documentation about this basic step
      FiPy serial connection with RaspberryPi Compute Module.
      search on the forum, e.g.:
      https://forum.pycom.io/topic/2514/lopy-to-raspberry-pi-3-serial-connection
      • sebS Offline
        seb @Archana Kadam
        @archana-kadam
        When you say "we are unable to read the other sensors", could you provide more details? Was there an error occuring? If so what did it say?
          Archana Kadam
          We are not able to fetch the list of files which are stored in the pysense board
            @archana-kadam
            Do you use passive mode and do you limit connection to only one?
            Many ftp clients use many connection at one time.
              Archana Kadam @livius
              @livius
              Yes Passive mode is on and we did not do any limited settings for client connection
                I do not know if understand this correctly
                but you must limit connections to only one a a time in ftp client config
                below is a sample for Filezilla
                https://docs.pycom.io/chapter/toolsandfeatures/FTP.html#filezilla
                  @livius
                  How to get current time stamp in fipy module after ejecting and reconnecting again. We tried with utime and rtc examples provided in the pycom documentation, but when we eject the module and reconnect the time is getting reset. how to get only current year,month date and time
                  Thank You
                    ejecting
                    By ejecting do you mean remove power competly? Or only deepsleep?
                    If the first then how do you thing the time can be preserved?
                    Thing about your wath on the hand if you remove battery and you place it after month do you see current time?
                    If you are interested in starting time from point before reset - and loosing e.g. month is not problem for you - you can save current time to non-volatile memory. You can use pycom.nvs_set or save data to the SD card or not recommended write it to the flash.
                    Only way to have time - is deepsleep with battery.
                      jcaron @livius
                      @livius Using deep sleep via a Pysense, Pytrack or deep sleep shield, you should be able to get the remaining time. If you save the time before going to sleep, and on boot, load that time, add the value of the deep sleep time and subtract the remaining sleep time, you should get an approximate real time.
                      Haven't tried it yet, and I believe on the Pysense/Pytrack the remaining sleep is slightly off, but it should be possible.
                        Archana Kadam
                        @livius
                        we have made a parts in main.py program. In each part of program we have declared the string and tried combine all the strings into one by giving a time limit of 30 seconds, after two readings we are an error called OSError: [Errno 22] EINVAL .Would you please give us the sloution for this error. I have attached a code also please go through the code0_1520554484439_tempHum.py
                        Thanking You
                          @archana-kadam
                          you concat strings always and never clear it
                          string1 +=
                          you probably consume max buffer..
                            Archana Kadam @jcaron
                            @jcaron
                            Can you please send us the code to read current time stamp with fipy board
                            • sebS Offline
                              seb @Archana Kadam
                              @archana-kadam
                              Please check the documentation: https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html
                              https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html
                                @livius
                                Thank you for this help now we are getting a proper output.
                                  Archana Kadam
                                  We are trying to connect to the station and access media using the procedure given the documentation. We are unable to connect to the accurate station and access point to specified IP address and ssid.
                                  Could you please help to this problem
                                  Thank You
                                    @archana-kadam
                                    Do you mean Wifi?
                                    How your trying looks like? Any sample code. And if this is Wifi - what are your security settings on your router - WPA2 or something different?
                                      @livius
                                      Yes, We are trying to connect WiFi and our router is setup at WPA2 configuration.We tried with sample code provided in the pycom documentation.
                                      We want fipy board to be worked as both station and access point
                                      Thank You
                                        @archana-kadam
                                        Did you fallowed both samples?
                                        https://docs.pycom.io/chapter/tutorials/all/wlan.html
                                        https://docs.pycom.io/chapter/firmwareapi/pycom/network/wlan.html
                                        better show the code and then we can help more -of course without passwords ;-)
                                          @livius
                                          we tried with this sample examples.
                                            @archana-kadam
                                            1. what you get when you do
                                            nets = wlan.scan()
                                            print(nets)
                                            1. is there your net ssid? and is there info about WPA2?
                                            2. do you use static IP?
                                              this line is for static ip settings - but you must change it to follow your router settings
                                            wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                                            • 1 / 4
