    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 30.0k Views 6 Watching
      livius @Archana Kadam
      @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
      ejecting
      By ejecting do you mean remove power competly? Or only deepsleep?
      If the first then how do you thing the time can be preserved?
      Thing about your wath on the hand if you remove battery and you place it after month do you see current time?
      If you are interested in starting time from point before reset - and loosing e.g. month is not problem for you - you can save current time to non-volatile memory. You can use pycom.nvs_set or save data to the SD card or not recommended write it to the flash.
      Only way to have time - is deepsleep with battery.
        jcaron @livius
        @livius Using deep sleep via a Pysense, Pytrack or deep sleep shield, you should be able to get the remaining time. If you save the time before going to sleep, and on boot, load that time, add the value of the deep sleep time and subtract the remaining sleep time, you should get an approximate real time.
        Haven't tried it yet, and I believe on the Pysense/Pytrack the remaining sleep is slightly off, but it should be possible.
          Archana Kadam
          @livius
          we have made a parts in main.py program. In each part of program we have declared the string and tried combine all the strings into one by giving a time limit of 30 seconds, after two readings we are an error called OSError: [Errno 22] EINVAL .Would you please give us the sloution for this error. I have attached a code also please go through the code0_1520554484439_tempHum.py
          Thanking You
            @archana-kadam
            you concat strings always and never clear it
            string1 +=
            you probably consume max buffer..
              Archana Kadam @jcaron
              @jcaron
              Can you please send us the code to read current time stamp with fipy board
              • sebS Offline
                seb @Archana Kadam
                @archana-kadam
                Please check the documentation: https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html
                https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html
                  Archana Kadam @livius
                  @livius
                  Thank you for this help now we are getting a proper output.
                    Archana Kadam
                    We are trying to connect to the station and access media using the procedure given the documentation. We are unable to connect to the accurate station and access point to specified IP address and ssid.
                    Could you please help to this problem
                    Thank You
                      @archana-kadam
                      Do you mean Wifi?
                      How your trying looks like? Any sample code. And if this is Wifi - what are your security settings on your router - WPA2 or something different?
                        @livius
                        Yes, We are trying to connect WiFi and our router is setup at WPA2 configuration.We tried with sample code provided in the pycom documentation.
                        We want fipy board to be worked as both station and access point
                        Thank You
                          @archana-kadam
                          Did you fallowed both samples?
                          https://docs.pycom.io/chapter/tutorials/all/wlan.html
                          https://docs.pycom.io/chapter/firmwareapi/pycom/network/wlan.html
                          better show the code and then we can help more -of course without passwords ;-)
                            @livius
                            we tried with this sample examples.
                              @archana-kadam
                              1. what you get when you do
                              nets = wlan.scan()
                              print(nets)
                              1. is there your net ssid? and is there info about WPA2?
                              2. do you use static IP?
                                this line is for static ip settings - but you must change it to follow your router settings
                              wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                                @livius
                                By using
                                nets = wlan.scan()
                                print(nets)
                                we are getting details of connected WiFI.
                                Yes we have our net ssid and is configured to WPA2. Yes we were using this wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                                to configuration. How we can know that our WIFI is connected or disconnected
                                  @archana-kadam
                                  you have wlan.isconnected() for that look here:
                                  https://docs.pycom.io/chapter/tutorials/all/wlan.html#connecting-to-a-router
                                  and are you sure that your router have same ip settings? 192.168.0.1?
                                    @livius
                                    from network import WLAN
                                    wlan = WLAN(mode=WLAN.STA)
                                    nets = wlan.scan()
                                    for net in nets:
                                        if net.ssid == 'mywifi':
                                            print('Network found!')
                                            wlan.connect(net.ssid, auth=(net.sec, 'mywifikey'), timeout=5000)
                                            while not wlan.isconnected():
                                            break
                                    Using above code we are getting the details of connected wifi. And we have different ip address.0_1520939453939_screnshot.PNG Here is the screenshot of our output please go through the image and update.
                                    Thank You
                                      @archana-kadam
                                      than you are connected to wifi - what more do you need?
                                        @livius
                                        How we can know that is connected to Wifi?
                                        How we can connect to both station as well as access point?
                                          @livius
                                          Please explain the procedure of connecting fipy to server and how to send data of fipy to server
                                            wlan.isconnected()
                                            but to be really sure - only sending by socket tell this for sure
                                            change mode from WLAN.STA in WLAN.STA_AP
                                            simply create socket and send data throught it
                                            e.g. from memory not tested but something like this should work
                                            s = socket.socket()
                                            s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                                            s.connect(socket.getaddrinfo('your server ip', your_server_port)[0][-1])
                                            s.send(your_data)
                                            • 1 / 4
