    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 30.0k Views 6 Watching
      livius @Archana Kadam
      @archana-kadam
      Do you use passive mode and do you limit connection to only one?
      Many ftp clients use many connection at one time.
        Archana Kadam @livius
        @livius
        Yes Passive mode is on and we did not do any limited settings for client connection
          @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
          I do not know if understand this correctly
          but you must limit connections to only one a a time in ftp client config
          below is a sample for Filezilla
          https://docs.pycom.io/chapter/toolsandfeatures/FTP.html#filezilla
            @livius
            How to get current time stamp in fipy module after ejecting and reconnecting again. We tried with utime and rtc examples provided in the pycom documentation, but when we eject the module and reconnect the time is getting reset. how to get only current year,month date and time
            Thank You
              ejecting
              By ejecting do you mean remove power competly? Or only deepsleep?
              If the first then how do you thing the time can be preserved?
              Thing about your wath on the hand if you remove battery and you place it after month do you see current time?
              If you are interested in starting time from point before reset - and loosing e.g. month is not problem for you - you can save current time to non-volatile memory. You can use pycom.nvs_set or save data to the SD card or not recommended write it to the flash.
              Only way to have time - is deepsleep with battery.
                jcaron @livius
                @livius Using deep sleep via a Pysense, Pytrack or deep sleep shield, you should be able to get the remaining time. If you save the time before going to sleep, and on boot, load that time, add the value of the deep sleep time and subtract the remaining sleep time, you should get an approximate real time.
                Haven't tried it yet, and I believe on the Pysense/Pytrack the remaining sleep is slightly off, but it should be possible.
                  Archana Kadam
                  @livius
                  we have made a parts in main.py program. In each part of program we have declared the string and tried combine all the strings into one by giving a time limit of 30 seconds, after two readings we are an error called OSError: [Errno 22] EINVAL .Would you please give us the sloution for this error. I have attached a code also please go through the code0_1520554484439_tempHum.py
                  Thanking You
                    @archana-kadam
                    you concat strings always and never clear it
                    string1 +=
                    you probably consume max buffer..
                      Archana Kadam @jcaron
                      @jcaron
                      Can you please send us the code to read current time stamp with fipy board
                      • sebS Offline
                        seb @Archana Kadam
                        @archana-kadam
                        Please check the documentation: https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html
                        https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html
                          @livius
                          Thank you for this help now we are getting a proper output.
                            Archana Kadam
                            We are trying to connect to the station and access media using the procedure given the documentation. We are unable to connect to the accurate station and access point to specified IP address and ssid.
                            Could you please help to this problem
                            Thank You
                              @archana-kadam
                              Do you mean Wifi?
                              How your trying looks like? Any sample code. And if this is Wifi - what are your security settings on your router - WPA2 or something different?
                                @livius
                                Yes, We are trying to connect WiFi and our router is setup at WPA2 configuration.We tried with sample code provided in the pycom documentation.
                                We want fipy board to be worked as both station and access point
                                Thank You
                                  @archana-kadam
                                  Did you fallowed both samples?
                                  https://docs.pycom.io/chapter/tutorials/all/wlan.html
                                  https://docs.pycom.io/chapter/firmwareapi/pycom/network/wlan.html
                                  better show the code and then we can help more -of course without passwords ;-)
                                    @livius
                                    we tried with this sample examples.
                                      @archana-kadam
                                      1. what you get when you do
                                      nets = wlan.scan()
                                      print(nets)
                                      1. is there your net ssid? and is there info about WPA2?
                                      2. do you use static IP?
                                        this line is for static ip settings - but you must change it to follow your router settings
                                      wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                                        @livius
                                        By using
                                        nets = wlan.scan()
                                        print(nets)
                                        we are getting details of connected WiFI.
                                        Yes we have our net ssid and is configured to WPA2. Yes we were using this wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                                        to configuration. How we can know that our WIFI is connected or disconnected
                                          @archana-kadam
                                          you have wlan.isconnected() for that look here:
                                          https://docs.pycom.io/chapter/tutorials/all/wlan.html#connecting-to-a-router
                                          and are you sure that your router have same ip settings? 192.168.0.1?
                                            @livius
                                            from network import WLAN
                                            wlan = WLAN(mode=WLAN.STA)
                                            nets = wlan.scan()
                                            for net in nets:
                                                if net.ssid == 'mywifi':
                                                    print('Network found!')
                                                    wlan.connect(net.ssid, auth=(net.sec, 'mywifikey'), timeout=5000)
                                                    while not wlan.isconnected():
                                                    break
                                            Using above code we are getting the details of connected wifi. And we have different ip address.0_1520939453939_screnshot.PNG Here is the screenshot of our output please go through the image and update.
                                            Thank You
                                            • 1 / 4
