    Not getting Sensor Readings in Pysense with FiPy Module
    fipyraspberry pipysensemicorpython
    79 Posts 6 Posters 30.0k Views 6 Watching
      Archana Kadam @jcaron
      @jcaron
      Can you please send us the code to read current time stamp with fipy board
      • sebS Offline
        seb @Archana Kadam
        @archana-kadam
        Please check the documentation: https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html
        https://docs.pycom.io/chapter/firmwareapi/pycom/machine/RTC.html
          Archana Kadam @livius
          @livius
          Thank you for this help now we are getting a proper output.
            Archana Kadam
            We are trying to connect to the station and access media using the procedure given the documentation. We are unable to connect to the accurate station and access point to specified IP address and ssid.
            Could you please help to this problem
            Thank You
              livius @Archana Kadam
              @archana-kadam
              Do you mean Wifi?
              How your trying looks like? Any sample code. And if this is Wifi - what are your security settings on your router - WPA2 or something different?
                @livius
                Yes, We are trying to connect WiFi and our router is setup at WPA2 configuration.We tried with sample code provided in the pycom documentation.
                We want fipy board to be worked as both station and access point
                Thank You
                  @archana-kadam
                  Did you fallowed both samples?
                  https://docs.pycom.io/chapter/tutorials/all/wlan.html
                  https://docs.pycom.io/chapter/firmwareapi/pycom/network/wlan.html
                  better show the code and then we can help more -of course without passwords ;-)
                    @livius
                    we tried with this sample examples.
                      @archana-kadam
                      1. what you get when you do
                      nets = wlan.scan()
                      print(nets)
                      1. is there your net ssid? and is there info about WPA2?
                      2. do you use static IP?
                        this line is for static ip settings - but you must change it to follow your router settings
                      wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                        @livius
                        By using
                        nets = wlan.scan()
                        print(nets)
                        we are getting details of connected WiFI.
                        Yes we have our net ssid and is configured to WPA2. Yes we were using this wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
                        to configuration. How we can know that our WIFI is connected or disconnected
                          @archana-kadam
                          you have wlan.isconnected() for that look here:
                          https://docs.pycom.io/chapter/tutorials/all/wlan.html#connecting-to-a-router
                          and are you sure that your router have same ip settings? 192.168.0.1?
                            @livius
                            from network import WLAN
                            wlan = WLAN(mode=WLAN.STA)
                            nets = wlan.scan()
                            for net in nets:
                                if net.ssid == 'mywifi':
                                    print('Network found!')
                                    wlan.connect(net.ssid, auth=(net.sec, 'mywifikey'), timeout=5000)
                                    while not wlan.isconnected():
                                    break
                            Using above code we are getting the details of connected wifi. And we have different ip address.0_1520939453939_screnshot.PNG Here is the screenshot of our output please go through the image and update.
                            Thank You
                              @archana-kadam
                              than you are connected to wifi - what more do you need?
                                @livius
                                How we can know that is connected to Wifi?
                                How we can connect to both station as well as access point?
                                  @livius
                                  Please explain the procedure of connecting fipy to server and how to send data of fipy to server
                                    @archana-kadam said in Not getting Sensor Readings in Pysense with FiPy Module:
                                    wlan.isconnected()
                                    but to be really sure - only sending by socket tell this for sure
                                    change mode from WLAN.STA in WLAN.STA_AP
                                    simply create socket and send data throught it
                                    e.g. from memory not tested but something like this should work
                                    s = socket.socket()
                                    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                                    s.connect(socket.getaddrinfo('your server ip', your_server_port)[0][-1])
                                    s.send(your_data)
                                      @livius
                                      Can we send data through pybytes ?
                                      Is a pybytes a server or its just a middleware to send data?
                                        @livius
                                        From this above code we are getting an error called OSERORR :-01
                                        s = socket.socket()
                                        s.connect(socket.getaddrinfo('192.168.0.109', 80)[0][-1])
                                        your_data = "Hello"
                                        s.send("your_data")
                                          @archana-kadam
                                          At which line of code?
                                            @livius
                                            Line number 6 and 7
                                            • 2 / 4
