Sensor JSON Post stops after a few hours
My sensor runs for a few hours and stops with following error.
Could anyone please direct me as to where I might be going wrong please find code below
import network import time import pycom import machine import gc import urequests from network import WLAN execfile('/flash/Wi-Fi/Wi-Fi.py') f_device = open('/flash/Config/Device_Details.txt', 'r') device_setting = f_device.readline() device_strings = [i.strip() for i in device_setting.split(',')] f_device.close() gc.enable() pycom.heartbeat(False) uart1 = machine.UART(1, baudrate=9600, bits=8, parity=None, stop=1) time.sleep(2) while True: tmp = uart1.readall() res = urequests.post('https://mywebsite', json={'Weight': str(tmp)}) res.close() if (res.status_code - 200) < 100: # check that response code is in the 200 range print("Weight POST Successful") else: print('there was some error') gc.collect() print(gc.mem_free()) time.sleep(57)
@jimpower ok, so why do you get no module found when you call urequests.post now when you didn't before.
I can't see all your code, just snippets. The vaious sample bits of code are being changed.Oh I see now what the problem is, when you import
urequests
you are importing asrequests
hence the module not found error.You will need to change the sample to
requests.post
Also as an aside why do you
rather than importing. This seems odd thing to do.
yes
import network
import gc
import urequests as requestsfrom network import WLAN
#INITIALISE LAN
execfile('/flash/Wi-Fi/Wi-Fi.py') # connect to wifi#INITIALISE DEVICE DETAILS
f_device = open('/flash/Config/Device_Details.txt', 'r') # read device details from file
# file format is: Device Type, Device Location ie Fridge, Workshop A, Damp Pump
f_device.close()#INITIALISE LIBRARIES
gc.enable()
time.sleep(2)
tmp = uart1.readall()is above the I just didn't include it in previous post
@jimpower Umm your earlier sample code shows it being imported.
Make sure you still have
import urequests
somewhere, and it's in your deployed code.
I have tried to emulate what you have done but get an error could you help me to identify
def linkup():
if wlan.isconnected(): try: usocket.getaddrinfo("https://my.website.io", 8082, 0, usocket.SOCK_STREAM) except OSError as e: return False return True return False
try: res = urequests.post('https://my.website', json={'Weight': str(tmp)}) res.close() print(str(tmp)) except OSError as e: if linkup(): continue else: wlan = WLAN(mode=WLAN.STA) wlan.connect(wifi_strings[0], auth=(WLAN.WPA2, wifi_strings[2]), timeout = 5000) print('Wi-Fi Connecting To :', wifi_strings[0],) while not wlan.isconnected(): machine.idle() gc.collect() print(gc.mem_free()) time.sleep(50)
getting following error
@timh This is very rough (and to be honest not well structured) but for instance you could implement a check for connectivity, and if you get an error then try reconnecting.
def linkup() if wlan.isconnected(): try: usocket.getaddrinfo("someaddress.com", someport, 0, usocket.SOCK_STREAM) except OSError as e: return False return True return False
Then in your main loop
try: res = urequests.post('https://mywebsite', json={'Weight': str(tmp)}) res.close() except OSError as e: if linkup(): continue else: do_something_to_reconnect() # if this fails then may be machine.reset()
I was leaning towards this however I'm not sure how to go about the try/except block. Would you be able to help me understand how to check if wifi is still connected and also if I can resolve name as wifi could be good without active internet access.
@jimpower I would suggest you wrap that call in a try/except block. Catch the exception.
At that point (line 53, you are trying to resolve an address). My guess is wifi might have dropped out.It might be worth in the exception handler checking to see if wifi is still connected, and potentially checking you can resolve the name. If all is good retry, or reconnect wifi etc..
My feeling is you should expect the link to fail at some point and your code be able to deal with it.
I used latest urequests.py and changed line 53 to
ai = usocket.getaddrinfo(host, port)
I still get the same error
This seems like a different version to mine there were only 122 lines in mine, so I updated to this version and got the following error.
Are you using urequests from here? https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
RS232 Weigh Sensor [Rinstrum_2100]
import network
import gc
import urequestsfrom network import WLAN
#INITIALISE LAN
gc.enable()
time.sleep(2)#INITIALISE VARIABLES
tmp = uart1.readall() res = urequests.post('mywebsite', json={'Weight': str(tmp)}) res.close() if (res.status_code - 200) < 100: # check that response code is in the 200 range print("Weight POST Successful")
print("Weight POST Successful - " + str(tmp))
You can see here that EBADF means bad file number which would suggest an issue with sockets.
I tried to match the error above to the code you posted by line 35 is
gc.collect()
, is the code you posted the same code that causes the issue?Edit: And line 112 in urequests is the
get
function which I dont see anywhere in your code, this is certainly not the same code
