    Sensor JSON Post stops after a few hours
    jsonuartpost
    14 Posts 3 Posters 2.6k Views 3 Watching
      jimpower @seb
      RS232 Weigh Sensor [Rinstrum_2100]
      import network
      import gc
      import urequests
      from network import WLAN
      #INITIALISE LAN
      execfile('/flash/Wi-Fi/Wi-Fi.py') # connect to wifi
      #INITIALISE DEVICE DETAILS
      f_device = open('/flash/Config/Device_Details.txt', 'r') # read device details from file
      # file format is: Device Type, Device Location ie Fridge, Workshop A, Damp Pump
      device_setting = f_device.readline()
      device_strings = [i.strip() for i in device_setting.split(',')]
      f_device.close()
      #INITIALISE LIBRARIES
      gc.enable()
      pycom.heartbeat(False)
      uart1 = machine.UART(1, baudrate=9600, bits=8, parity=None, stop=1)
      time.sleep(2)
      #INITIALISE VARIABLES
      tmp = uart1.readall()
      res = urequests.post('mywebsite', json={'Weight': str(tmp)})
      res.close()
      if (res.status_code - 200) < 100: # check that response code is in the 200 range
          print("Weight POST Successful")
      print("Weight POST Successful - " + str(tmp))
          print('there was some error')
      gc.collect()
      print(gc.mem_free())
      time.sleep(57)
      • sebS Offline
        seb @jimpower
        @jimpower
        Are you using urequests from here? https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
          jimpower @seb
          @seb
          This seems like a different version to mine there were only 122 lines in mine, so I updated to this version and got the following error.
            jimpower @seb
            @seb
            I used latest urequests.py and changed line 53 to
            ai = usocket.getaddrinfo(host, port)
            I still get the same error
              timh @jimpower
              @jimpower I would suggest you wrap that call in a try/except block. Catch the exception.
              At that point (line 53, you are trying to resolve an address). My guess is wifi might have dropped out.
              It might be worth in the exception handler checking to see if wifi is still connected, and potentially checking you can resolve the name. If all is good retry, or reconnect wifi etc..
              My feeling is you should expect the link to fail at some point and your code be able to deal with it.
              J T 2 Replies Last reply Reply Quote 0
                jimpower @timh
                @timh
                I was leaning towards this however I'm not sure how to go about the try/except block. Would you be able to help me understand how to check if wifi is still connected and also if I can resolve name as wifi could be good without active internet access.
                  timh @timh
                  @timh This is very rough (and to be honest not well structured) but for instance you could implement a check for connectivity, and if you get an error then try reconnecting.
                  def linkup()
                          if wlan.isconnected():
                               try:
                                    usocket.getaddrinfo("someaddress.com", someport, 0, usocket.SOCK_STREAM)
                               except OSError as e:
                                    return False
                               return True
                          return False
                  Then in your main loop
                  try:
                      res = urequests.post('https://mywebsite', json={'Weight': str(tmp)})
                      res.close()
                      if linkup():
                          continue
                          do_something_to_reconnect()
                          # if this fails then may be machine.reset()
                    jimpower @timh
                    @timh
                    I have tried to emulate what you have done but get an error could you help me to identify
                    def linkup():
                             try:
                                  usocket.getaddrinfo("https://my.website.io", 8082, 0, usocket.SOCK_STREAM)
                                  return False
                             return True
                        return False
                    try:
                        res = urequests.post('https://my.website', json={'Weight': str(tmp)})
                        res.close()
                        print(str(tmp))
                        if linkup():
                            continue
                        wlan = WLAN(mode=WLAN.STA)
                        wlan.connect(wifi_strings[0],  auth=(WLAN.WPA2, wifi_strings[2]), timeout = 5000)
                        print('Wi-Fi Connecting To :', wifi_strings[0],)
                        while not wlan.isconnected():
                        	machine.idle()
                    gc.collect()
                    time.sleep(50)
                    getting following error
                      timh @jimpower
                      @jimpower Umm your earlier sample code shows it being imported.
                      Make sure you still have
                       import urequests
                      somewhere, and it's in your deployed code.
                        jimpower @timh
                        @timh
                        yes
                        import network
                        import gc
                        import urequests as requests
                        #INITIALISE LAN
                        f_device.close()
                        gc.enable()
                        time.sleep(2)
                        is above the I just didn't include it in previous post
                          timh @jimpower
                          @jimpower ok, so why do you get no module found when you call urequests.post now when you didn't before.
                          I can't see all your code, just snippets. The vaious sample bits of code are being changed.
                          Oh I see now what the problem is, when you import urequests you are importing as requests hence the module not found error.
                          You will need to change the sample to requests.post
                          Also as an aside why do you execfile('/flash/Wi-Fi/Wi-Fi.py') rather than importing. This seems odd thing to do.
