    [Solved]Firmware upgrade tool for the Sequans Monarch SQN3330
    fipy firmwarefipy
    17 Posts 2 Posters 3.8k Views 2 Watching
      DDA
      I was finally able to resolve the issue. The problem was with the SD card mount. The card would show successful mount , but for some reason would not show the *.dup file. I double checked my FAT32 format it looked right. Per suggestion from @jmarcelino, I formatted the card though the FiPy and then loaded the file and the issue was resolved:
      The card directory was :
      >>> import time
      >>> import os
      >>> from machine import SD
      >>> sd=SD()
      >>> os.mount(sd,'/sd')
      >>> os.listdir('/sd')
      So tried the format :
      sd=SD()
      os.mount(sd,'/sd')
      os.mkfs(‘/sd')
      After the format, and reload of the file the card directory showed as:
      >>> import time
      >>> import os
      >>> sd=SD()
      >>> os.mount(sd,'/sd')
      >>> os.listdir('/sd')
      ['FIPY_GPY_CATM1_33988.dup']
      Initial thread:
      I followed the instruction per the link below and placed the codec.py, crc.py, sqnsupgrade.py, stp.py and README.md into VBS project space :
      Per document : https://docs.pycom.io/chapter/tutorials/lte/firmware.html
      Then I uploaded those files to my FiPy:
      Connecting on COM25...
      Reading file status
      [1/4] Writing file codec.py
      [2/4] Writing file crc.py
      [3/4] Writing file sqnsupgrade.py
      [4/4] Writing file stp.py
      ets Jun  8 2016 00:22:57
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      MicroPython v1.8.6-849-83e2f7f on 2018-03-19; FiPy with ESP32
      And , I also copied the firmware files : FIPY_GPY_CATM1_33988 and FIPY_GPY_NB1_35351 dup files into a recently formated FAT32 micro SD.
      On executing
      import sqnsupgrade
      I get :
      >>> import sqnsupgrade
        File "sqnsupgrade.py", line 7
      SyntaxError: invalid syntax
      I must be doing something wrong or reading in between the lines per the instructions. Thanks in advance!!
        jmarcelino @DDA
        @dda
        I think the project files hasn’t synced correctly. Please do, os.mkfs(“/flash”) to restore the board to a clean install and try syncing the project again.
          DDA @jmarcelino
          @jmarcelino
          Thank you for your response. I followed your instructions, ran
          Connecting on COM25
          >>> import os
          >>> os.mkfs('/flash')
          Then restarted Visual Studio Code and re-powered Fipy and Uploaded files:
          Reading file status
          Creating dir workspaceStorage
          Creating dir workspaceStorage/bc895fb1973b5d5624b4a2ed2625b38c
          [1/7] Writing file codec.py
          [2/7] Writing file crc.py
          [3/7] Writing file pymakr.json
          [4/7] Writing file settings.json
          [5/7] Writing file sqnsupgrade.py
          [6/7] Writing file stp.py
          [7/7] Writing file workspaceStorage/bc895fb1973b5d5624b4a2ed2625b38c/meta.json
          entry 0x400a059c
          Then tried:
          >>> import sqnsupgrade
          Same as before, why is the import not working, the file is there and under the root directory itself. I also repeated the same by keeping the firmware files in a lib directory, same results.
          Connecting on COM25
          >>> import os
          >>> os.mkfs('/flash')
          Reading file status
          Creating dir lib
          [1/7] Writing file lib/codec.py
          [2/7] Writing file lib/crc.py
          [3/7] Writing file lib/sqnsupgrade.py
          [4/7] Writing file lib/stp.py
          [5/7] Writing file pymakr.json
          [6/7] Writing file settings.json
          entry 0x400a059c
          >>> import sqnsupgrade
            File "/flash/lib/sqnsupgrade.py", line 7
            jmarcelino @DDA
            @dda
            Thank you.
            What is the content of sqnsupgrade.py as shown in Visual Studio?
              DDA @jmarcelino
              @jmarcelino
              The content is about 1238 lines of code.
              <!DOCTYPE html>
              <html lang="en">
                <head>
                  <meta charset="utf-8">
                <link rel="dns-prefetch" href="https://assets-cdn.github.com">
                <link rel="dns-prefetch" href="https://avatars0.githubusercontent.com">
                <link rel="dns-prefetch" href="https://avatars1.githubusercontent.com">
                <link rel="dns-prefetch" href="https://avatars2.githubusercontent.com">
                <link rel="dns-prefetch" href="https://avatars3.githubusercontent.com">
                <link rel="dns-prefetch" href="https://github-cloud.s3.amazonaws.com">
                <link rel="dns-prefetch" href="https://user-images.githubusercontent.com/">
                <link crossorigin="anonymous" media="all" integrity="sha512-ffMzRgUi/mtdt6xiC1jtSP1kZPeTBajWgak1AnijhQVTr6eCui3vcdxCvFCJjbjAXg730wT/i/rceI+PIwS6kQ==" rel="stylesheet" href="https://assets-cdn.github.com/assets/frameworks-c4bbb32afb602dcf8c75be0bc4c83014.css" />
                <link crossorigin="anonymous" media="all" integrity="sha512-WZklPJpB37+ljTfVNn0494msEFLupIvcsVPpv1UCNJvCJAf0oFgpGlw4+OV4hQ3WMFTKbmuSVLk6uMmWuhnuqQ==" rel="stylesheet" href="https://assets-cdn.github.com/assets/github-0c21e211e4fd150ac107ccf0fcf751e5.css" />
                <link crossorigin="anonymous" media="all" integrity="sha512-55jV1x0Cc2ZmUyGueT7DnpTSBe4rIx9uhX4ZBXAhhUhR6Yn67TCdY6xWkdvMVqpeAhzLWIKQU5PWG1RH0eTlSQ==" rel="stylesheet" href="https://assets-cdn.github.com/assets/site-37b627a1dacd99c337a986787006aa1c.css" />
                <meta name="viewport" content="width=device-width">
                <title>pycom-libraries/sqnsupgrade.py at master · pycom/pycom-libraries · GitHub</title>
                  <meta name="description" content="GitHub is where people build software. More than 27 million people use GitHub to discover, fork, and contribute to over 80 million projects.">
                <link rel="search" type="application/opensearchdescription+xml" href="/opensearch.xml" title="GitHub">
                <link rel="fluid-icon" href="https://github.com/fluidicon.png" title="GitHub">
                <meta property="fb:app_id" content="1401488693436528">
               <div class="Popover js-hovercard-content position-absolute" style="display: none; outline: none;" tabindex="0">
                <div class="Popover-message Popover-message--bottom-left Popover-message--large Box box-shadow-large" style="width:360px;">
                </div>
              </div>
              <div id="hovercard-aria-description" class="sr-only">
                Press h to open a hovercard with more details.
              </div>
                </body>
              </html>
                jmarcelino @DDA
                @dda
                Umm that's definitely not right. Should be Python code.
                Can you try downloading it again? It's better to download the whole project as Zip from Github and it pick it from there. I think you chose to save the webpage instead.
                  DDA @jmarcelino
                  @jmarcelino
                  That was really a critical error on my part, I apologize . I have downloaded all the files again looks the same as on Git.
                  I have the two *.dup files under /sd directory in my microSD card.
                  >>>import sqnsupgrade
                  sqnsupgrade.run('/sd/FIPY_GPY_CATM1_33988.dup', 921600)
                  <<< Welcome to the SQN3330 firmware updater >>>
                  ♦Traceback (most recent call last):
                    File "<stdin>", line 3, in <module>
                    File "/flash/lib/sqnsupgrade.py", line 72, in run
                  OSError: [Errno 2] ENOENT
                    jmarcelino @DDA
                    @dda
                    Glad you got it going so far.
                    Are you saying you placed the files into a folder called sd on the SD card? That's actually not necessary, the files should be directly on the root folder.
                    The /sd is just a mount point for MicroPython
                      DDA @jmarcelino
                      @jmarcelino
                      Now I get AT+SMSWBOOT=3,0 failed.
                      I removed the sd folder from the SD card, formatted it again to FAT32 and SD card now contains just the two *.dup files for CAT-M and NBIoT only on the root.
                      On executing the following from main.py or from REPL I get the error:
                      Reading file status
                      Creating dir lib
                      [1/8] Writing file lib/codec.py
                      [2/8] Writing file lib/crc.py
                      [3/8] Writing file lib/sqnsupgrade.py
                      [4/8] Writing file lib/stp.py
                      [5/8] Writing file main.py
                      [6/8] Writing file pymakr.json
                      [7/8] Writing file settings.json
                      [8/8] Writing file workspaceStorage/bc895fb1973b5d5624b4a2ed2625b38c/meta.json
                      entry 0x400a059c
                      Entering recovery mode
                        File "main.py", line 2, in <module>
                        File "/flash/lib/sqnsupgrade.py", line 98, in run
                      OSError: AT+SMSWBOOT=3,0 failed!
                      >>> import sqnsupgrade
                      >>> sqnsupgrade.run('/FIPY_GPY_CATM1_33988.dup', 921600)
                        jmarcelino @DDA
                        @dda
                        OK it's reading the files correctly. Can you try a couple more times? Make sure it's from a clean, freshly power up, start.
                          DDA @jmarcelino
                          @jmarcelino
                          Ok repeated the following steps in order:
                          1. Ran os.mkfs('/flash')
                          2. Powered off Fipy/Expansion board 2.0
                          3. Took out SD card, formatted the SD card and reloaded the CATM 's dup file into it.
                          4. Powered Fipy on Expansion 3.0
                            5 Started VSC software & Uploaded files
                          Creating dir lib
                          entry 0x400a059c
                          Tried about 4-5 times now and about 3-4 times earlier to you reply.
                          The FiPy is on a Expansion board 2.0 and powered via the USB connection to the PC.
                            jmarcelino @DDA
                            @dda
                            Ok thanks, can you let me know the output of
                            from network import LTE
                            lte = LTE()
                            lte.send_at_cmd('ATI')
                              jmarcelino @DDA
                              @dda
                              Sorry just saw you're using the Expansion Board, have you removed the CTS and RTS jumpers from the board?
                              When using the expansion board with a FiPy, you will need to remove the CTS and RTS jumpers as these interfere with communication with the cellular modem.
                              https://docs.pycom.io/chapter/gettingstarted/connection/fipy.html
                                DDA @jmarcelino
                                @jmarcelino
                                I took out the CTS and RTS jumper at the start itself, rest of the jumpers in place.
                                The unit is not responding to
                                lte=LTE()
                                its hangs up, first time it was stuck for over 3 minutes that's when I did Ctrl-C to get out of it. Tried again and its stuck again and won't respond to lte=LTE()
                                  jmarcelino @DDA
                                  @dda
                                  So lte = LTE() doesn't respond? Even from power up?
                                  If so please open a ticket with our service desk so we can best handle it.
                                  https://pycomiot.atlassian.net/servicedesk/customer/portal/1
                                    DDA @jmarcelino
                                    @jmarcelino
                                    Finally responding now after a few power-ups.
                                    >>> lte = LTE()
                                    '\r\nERROR\r\n'
                                    '\r\nERROR\r\n'
                                    '\r\nERROR\r\n'
                                      DDA @jmarcelino
                                      @jmarcelino
                                      And on retrying the firmware upgrade again, this time I am getting a different error once and back to the same AT+SMSWBOOT failed error
                                      Resetting.
                                      Starting STP (DO NOT DISCONNECT POWER!!!)
                                        File "/flash/lib/sqnsupgrade.py", line 114, in run
                                      NameError: local variable referenced before assignment
                                      I have not done any changes to my code or file since the last error: OSError: AT+SMSWBOOT=3,0 failed!
