    SDI-12 Soil Moisture Probe Help
    sdi-12rs485lopy
    38 Posts 4 Posters 4.0k Views 4 Watching
      robert-hh @jimpower
        jimpower @robert-hh
        @robert-hh This could be an issue, only having 12v and 3.3v sources, I thought the RS-485 breakout could do 5v to 3.3v step down but not the other way. I may have to build a 12v to 5v step down circuit.
          robert-hh @jimpower
          @jimpower RS485 is a symmetrical differential interface of at least +/- 200 mV The SDI-12 uses 5V logic levels, the xxPys a 3.3 V level. The RS485 is (mis-)used to create a half duplex interface AND to do the level transformation.
          Looking at the data sheet It is now clear to me why the 1.8 V is needed. The max output level of the RS485 to the sensor is 3.3 V. To achieve 5V, the 1.8 V is added.
            jimpower @robert-hh
            Updated, does this look correct?
            With this I did manage to receive something although not correct I am getting closer
              jimpower @robert-hh
              @robert-hh I am getting responses from the SDI-12 Probe now, the reading of the sensors is working I just can't get the full read (maybe due to the size of it) could you help me to understand how to increase the buffer size to get all readings. Please see below the commands and their expected responses.
              This works correctly
              CMD - '?!' (Probe Address)
              RES - '0'
              CMD - '02C' (Take Temp Reading)
              RES - '000312' (1-4 is the time taken to read sensors 5-6 is the amount of sensors read)
              This doesn't show all readings
              CMD - '0D0' (Show Temp Readings first 8 sensors)
              RES - '0+028.12+027.24+027.03+026.78+026.65+025.45+023.34+021.21' (temp readings after each +0)
              ***Only some of the readings show I have never been able to get more then 6 show at a time.
              This doesn't seem to work yet
              CMD - '0D1' (Show temp readings last 4 sensors)
              RES - '0+028.12+027.24+027.03+026.78'
              Hopefully it is just a buffer size issue and the payload is not too large.
                robert-hh @jimpower
                @jimpower Code and exact sensor product name would be helpful. I found a data sheet telling that the longest response string is 80 bytes. That should not be a problem with the UART. The Rx buffer length is set to 512 bytes.
                  jimpower @robert-hh
                  I'm using an Enviropro EP100G-12 which has 12 rows of sensors at 10cm intervals, each row contains a temp, moisture and ec sensor.
                  http://enviroprosoilprobes.com/Files/EnviroPro_SDI-12_CommandsV2.pdf
                  http://enviroprosoilprobes.com/Files/EnviroPro_EPCU_User_ManualV3.pdf
                  import network
                  import gc
                  import utime
                  from machine import RTC
                  from machine import ADC
                  from machine import Pin
                  from machine import UART
                  from network import LoRa
                  execfile('/flash/Network/LoRa.py')
                  f_device = open('/flash/Config/Device_Details.txt', 'r')
                  device_setting = f_device.readline()
                  device_strings = [i.strip() for i in device_setting.split(',')]
                  f_device.close()
                  pycom.heartbeat(False)
                  rtc = RTC()
                  adc = ADC()
                  lora = LoRa()
                  uart = UART(1, baudrate=1200)
                  p_tx = Pin('P3', mode=Pin.OUT)
                  p_dir = Pin('P11', mode=Pin.OUT)
                  def SDI12(cmd):
                      uart.deinit()
                      p_tx.value(0)
                      p_dir.value(1)                                                          # set output dir
                      utime.sleep_us(14000)                                                   # send BREAK
                      p_tx.value(1)
                      utime.sleep_us(8333)                                                    # send MARK
                      uart.init(1200, bits=7, parity=UART.EVEN, stop=1, timeout_chars=75)     # init with given parameters
                      uart.write(cmd)                                                         # send command
                      utime.sleep_us(8333 * len(cmd))                                         # wait to send command (byte time * command lenght)
                      p_dir.value(0)                                                          # output set to read
                      line = uart.read(75)                                                   # read data from UART
                      return line;
                  time.sleep(2)
                      batt = adc.channel(attn=1, pin='P16')
                      #s = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
                      #s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5)
                      #s.setblocking(True)
                      #s.send("Battery Status : " + str(batt.value()) + " mV")
                      #s.setblocking(False)
                      print('--------------------------------')
                      print("Battery Status     : " + str(batt.value()) + " mV")
                  #                   Measure Temperature                  #
                      utime.sleep(2)
                      line = SDI12('?!')              #Wake Up Sensor
                      print(line)                     #Print Sensor Response
                      utime.sleep(3)                  #Wait before Next Cmd
                      line = SDI12('0C2!')            #Probe Temp Measure
                      print(line)                     #Print Time/Sensors
                      utime.sleep(5)                  #Wait before Next Cmd
                      data = SDI12('0D0!')            #Probe Temp Readings
                      print(data)                     #Print Temp Readings
                      #utime.sleep(10)
                      #data = SDI12('0D1!')            #Probe Temp Readings
                      #print(data)                     #Print Temp Readings
                  #                     Garbage Collect                    #
                      gc.enable()
                      gc.collect()
                      print("Sensor Memory Free : " + str(gc.mem_free()))
                      time.sleep(30)```
                  robert-hhR B 2 Replies Last reply Reply Quote 0
                    robert-hh @jimpower
                    @jimpower Thanks. The code looks principly OK. What happens if you increase the receive timeout?
                    The documentation of the product is weird. Why cannot they include a proper protocol definition? Did you see b.t.w. CR/LF transmitted at the end of response messages?
                      jimpower @robert-hh
                      yes it says technical document "coming soon"
                      here is a snippet of my uart.readline()
                      Do you think this timeout_chars is correct? I wasn't sure what to put in here.
                      uart.init(1200, bits=7, parity=UART.EVEN, stop=1, timeout_chars=75)```
                        robert-hh @jimpower
                        @jimpower SInce the length of the response is not known, you need astrategy to tell when the respons eis complete:
                        • either the response has a known terminal symbol, like ! in the command, or \r\n, then you can read until you see that symbol, and wait as second condition for a long timeout. Waitung for \r\n is done by uart.readline().
                        • or you have to wait for a timeout.
                          The 75 char timeout seems reasonable, but to sort out implementation errors in Micropython, you could increase that for testing and see, if you receive a longer message. Thre reason I ask is, taht I faintly remember some discussion around the rx timeout of uart.read.
                          jimpower @robert-hh
                          @robert-hh I'm not sure what happened but I changed my code back to the way it was before playing around with break times, uart timeout etc and it works.
                          A note for anyone wanting to interface with SDI-12 with a LoPy you need to perform a gc.collect() after every read and then wait for 30secs before you can read from any other sensors.
                          @robert-hh thanks for your help with this it was pivotal to getting a working SDI-12 interface.
                          @AntonioValente thanks for your initial concept which lead to this solution.
                            Bryan Hom @jimpower
                            @jimpower I know this is an old thread but where are you getting the 1.8V ref from?
                              robert-hh @Bryan Hom
                              @Bryan-Hom Yuo can use a small voltage regulator and derive it from 3.3V. If
                                Bryan Hom @robert-hh
                                @robert-hh Thank you. 1 other question, am i looking at the diagram correctly that the 1.8V + should also be tied in with the 3.3v line? Wouldn't that mean the voltage going into A is 3.3V?
                                  @Bryan-Hom That's looks wrong. You can consider the 1.8V source as a function block with 3.3V/GND as input and 1.8v/GND as output.
                                  I tried also some other circuits for a SDI-12 connection, but never connected them to real sensors. https://forum.pycom.io/topic/4827/teros-12-and-sdi-12?_=1640181173389
                                    @robert-hh Thanks, so it should actually look more like this? pycom SDI-12 schematic.png
                                      @Bryan-Hom Yes.
                                        Bryan Hom @jimpower
                                          Hi Robert, you seem to be the right person to be asking these questions to, but im using @jimpower's code and i followed the drawing exactly, but i cannot seem to get any reply from the sensor. Probing around my setup it looks like i have all the grounds properly connected, 5v going into to A. I made sure to put the 10k resistor between the 3.3v and the pin 4 (rx) of the pycom. Any thoughts or suggestions? I'm trying to read SDI-12 from a Campbell Scientific AVW200 https://s.campbellsci.com/documents/es/manuals/avw200 - 772.pdf Thank you
                                          import network
                                          import gc
                                          import utime
                                          rtc = RTC()
                                          adc = ADC()
                                          #lora = LoRa()
                                          def SDI12(cmd):
                                              uart.deinit()
                                              p_tx.value(0)
                                              utime.sleep_us(12500)                                                   # send BREAK
                                              p_tx.value(1)
                                              line = uart.readline()                                                  # read data from UART
                                              return line;
                                          time.sleep(2)
                                              utime.sleep(2)
                                              command = SDI12('V!')
                                              utime.sleep(10)
                                              print(command)                  #Print Sensor Response
                                              utime.sleep(2)
                                              command2 = SDI12('0V!')
                                              utime.sleep(10)
                                              print(command2)
                                          #                     Garbage Collect                    #
                                              gc.enable()
                                              gc.collect()
                                              time.sleep(15)```
                                            @Bryan-Hom Sorry, I misread you diagram. Pin A has to be at a level between 0 and 3.3 V, like 1.8 V in the first diagram. You asked from where to get it, I recommended an 1.8V regulator which in turn gets it power from 5V or 3.3V. For a fist test, you should also be able to use a 1.5V battery.
