    LoPy Firmware updates fail on Win10
    lopyfirmware
    18 Posts 4 Posters 5.0k Views 4 Watching
      rskoniec @Jakko
      On the 2nd screenshot you're using COM3. Do you have such device in the system?
        Jakko @rskoniec
        @rskoniec
        Yes, COM3 shows up as 'USB Serial Device'. However, this does not disappear when I unplug the LoPy from USB.
        For comparison, I checked what happens when I plug and unplug an arduino. Then, "Arduino Uno (COM6)" pops up in device manager when I plug it in, and it immediately disappears when I unplug it. Does this mean my UART connection from the LoPy is corrupted?
        J R 2 Replies Last reply Reply Quote 0
          rskoniec
          1. Is there any chance that LoPy board is fitting Expansion Board in wrong position? LoPy RGB LED should be above Expansion Board microUSB port.
          2. What kind of G23-GND connection is used? Male-male breadboard connector or just ordinary wire? I've experienced problems with UTP wire connection (was unstable causing connection errors).
          3. Could you provide a photo of your setup?
            jmarcelino @Jakko
            @Jakko said in LoPy Firmware updates fail on Win10:
            Are you sure this COM3 is really the LoPy board? Can it be something else?
            The USB device should really disappear once unplugged.
              rskoniec @jmarcelino
              @jmarcelino What I understand is that @Jakko is fully aware that COM3 is not a LoPy. ;)
                jmarcelino
                Oh OK sorry, I was going by the second screen where he tried it..
                Can you try another microUSB cable? I know you said it worked before but maybe it was another one. There are many "power only" cables out there which could explain these symptoms.
                I dont think Pycom actually send USB cables, at least I never got one.
                Also try connecting to a different port on your computer. Until it's detected as a device it won't really work.
                  @jmarcelino said in LoPy Firmware updates fail on Win10:
                  Neither do I.
                    rskoniec @Jakko
                    I assume that for Arduino test you've used different USB cable as UNO have USB B type connector.
                      Jakko
                      @rskoniec and @jmarcelino,
                      Just now I tried updating with a different USB cable (of my phone, of which I was sure the data channels were connected), and a couple of things happened:
                      • A new device popped up in device manager
                      • The firmware update worked perfectly fine
                      • I thanked you guys silently for preventing me from wasting any more time.
                      So, solved! It amazes me how such a tiny mistake can cost so much time (in total, I spend a whole day on this).
                      R 1 Reply Last reply Reply Quote 2
                        rskoniec @Jakko
                        @Jakko We're happy for your success. It's pretty regular that small mistakes sometimes make huge problems. ;o)
                          rskoniec
                          I've created a new topic https://forum.pycom.io/topic/763/firmware-upgrade-troubleshooting-checklist
                          I think it will be helpful for the others having similar issues.
                          I don't know if place in forum hierarchy is right - if not I hope Forum Admins will do the job. ;o)
                            dClaus
                            I have also the "Connecting ......... Failure !" problem with windows10 for the update of Lopy 1.4 to 1.6 !
                            The solution is :
                            • set the connection between G23 and GND,
                            • connect the LoPy expansion board to the computer with a USB cable
                            • !!! use the RESET buttom on the Lopy !!!
                            • use the firmware updater (1.1.1.b1)
                            It works for me on my 2 Lopy !
                            Damien
                            R D 2 Replies Last reply Reply Quote 1
                              rskoniec @dClaus
                              @dClaus said in LoPy Firmware updates fail on Win10:
                              Thanx! I've added this to my topic.
                                dClaus @dClaus
                                The solution is :
                                Damien
                                "use the RESET buttom" is not necessary for the WiPy2
                                  rskoniec @dClaus
                                  Thanx! Good to know. Topic updated!
