    Firmware update, not possible on either windows or mac osx...
    lopyfirmwarefirmware updatefirmware upgradusb
    32 Posts 5 Posters 14.3k Views 5 Watching
      jmarcelino @soren
      @soren
      You posted a few days ago in another thread saying you were trying to use the cu.lpss-serial2 device to access the REPL on your Mac and I replied saying that wasn't the correct device.
      Are you still trying to use cu.lpss-serial2 in the firmware upgrade tool? Have you found the correct device ?
      sorenS 1 Reply Last reply Reply Quote 0
      • sorenS Offline
        soren @jmarcelino
        @jmarcelino Hi, i did not see your reply in that thread sorry.
        Looking into it now. I didn't realize the REPL and firmware update was related so closely
          jmarcelino @soren
          @soren
          Yes both firmware update and REPL are done over the UART serial.
          If you're not seeing the correct device try installing the FTDI drivers from http://www.ftdichip.com/Drivers/VCP/MacOSX/FTDIUSBSerialDriver_v2_3.dmg
          sorenS 2 Replies Last reply Reply Quote 0
            rskoniec
            @soren Or http://www.ftdichip.com/Drivers/CDM/CDM v2.12.26 WHQL Certified.zip For Windows. ;o)
              mmarkvoort @rskoniec
              @rskoniec @soren My problem why I had to install manually was probably because I had my windows updates shut down. So it wouldn't update automatically. So probably installing it manually will help.
              • sorenS Offline
                soren @jmarcelino
                @jmarcelino Right!
                I installed FTDI drivers on windows now which made it possible to update on my windows PC (actually thought that was only necessary for mac), but having installed ftdi drivers on my mac doesn't make any difference unfortunately..
                • sorenS Offline
                  soren @jmarcelino
                  @jmarcelino I do have ftdi drivers installed, but that does not seem to make a difference on my osx system. It shouldn't be the USB C dongle obscuring things, because it's working just fine with eg. Arduino boards
                    jmarcelino @soren
                    @soren
                    Try looking in  (Apple) menu -> About This Mac -> press System Report and then choose USB from the list
                    If your Mac can see the Expansion Board you'll have a device saying FT230X Basic UART , like this:
                    • sorenS Offline
                      soren @jmarcelino
                      @jmarcelino yes, my mac see's the unit as a ft230x basic UART.
                      EDIT: I also tried a different USB cable now, just for the sake of excluding that.. no difference
                        jmarcelino @soren
                        @soren
                        Ok that looks good, so what do you get from a ls -l /dev/cu.* ?
                        Is there a line with /dev/cu.usbserial-xxxxxxxx ? (the xxxxxxxx part doesn't really matter)
                        EDIT Also can you post the result of
                        kextstat -b com.FTDI.driver.FTDIUSBSerialDriver
                        • sorenS Offline
                          soren @jmarcelino
                          @jmarcelino
                          EDIT EDIT
                          Now it freakin works.. SOooo, there's a difference between vcp and the dxx ftdi drivers.. i did not know about the vcp before until just now. installing the vcp seems to be working now. also, i have currently unloaded the apple ftdi driver which might also be necessary but i'm not sure. phew, this is a rather frustrating process to go through.. thanks so much for the help @jmarcelino though!
                          I don't see a cu.usbserial-xxxx... no, sorry. this is what i get:
                          crw-rw-rw- 1 root wheel 20, 3 Mar 23 10:41 /dev/cu.Bluetooth-Incoming-Port
                          crw-rw-rw- 1 root wheel 20, 5 Mar 23 10:41 /dev/cu.JabraStylev130-CSRGAIA
                          crw-rw-rw- 1 root wheel 20, 7 Mar 23 10:41 /dev/cu.iPhone-WirelessiAP
                          crw-rw-rw- 1 root wheel 20, 1 Mar 23 10:41 /dev/cu.lpss-serial2
                          here's my result of kextstat -b com.FTDI.driver.FTDIUSBSerialDriver:
                          list itemIndex Refs Address Size Wired Name (Version) UUID <Linked Against>
                          EDIT
                          so.. this looks like the ftdi driver is not being found at all, right?
                            jmarcelino @soren
                            @soren
                            Yes it's not loading the driver for some reason. Can you post the result of:
                            kextfind -case-insensitive -bundle-id -substring 'FTDI' -print
                            to see if it's correctly installed and if there's any conflicts?
                            you can also try manually loading it with
                            sudo kextload -bundle-id com.FTDI.driver.FTDIUSBSerialDriver
                            sorenS 2 Replies Last reply Reply Quote 1
                            • sorenS Offline
                              soren @jmarcelino
                              @jmarcelino said in Firmware update, not possible on either windows or mac osx...:
                              kextfind gives me:
                              /System/Library/Extensions/AppleUSBFTDI.kext
                              /Library/Extensions/D2xxHelper.kext
                              /Library/Extensions/FTDIKext.kext
                              /Library/Extensions/FTDIUSBSerialDriver.kext
                              this is so weird though. trying to unload the mac ftdi driver with:
                              sudo kextunload -b com.apple.driver.AppleUSBFTDI
                              just gives me:
                              Can't create –b.
                              Can't create com.apple.driver.AppleUSBFTDI.
                              • sorenS Offline
                                soren @jmarcelino
                                @jmarcelino
                                so, after being able to connect and I synced a project several times - now I suddenly am back to being unable to connect. I did not reboot my system.. It just tells me "invalid device address.." and the lopy doesn't show up in configurations.. this has got to be the most uneasy mcu i've ever dealt with
                                  jmarcelino
                                  Just saw your edit on the original post. Glad you got it working in the end!
                                  Yeah USB serial drivers can be a confusing mess - and actually FTDI has some of the best drivers.
                                    robert-hh
                                    When you say: "synched a project", does thar mean you#re using Pymakr? If yes, don't do that. Pymakr simply adds another layer of strange issues. Better use basic tools, like an ftp client of your choice, screen or telnet, ...
                                    There you have much better response, and if you have issues, the reason is obvious.
                                    J sorenS 2 Replies Last reply Reply Quote 0
                                      jmarcelino @robert-hh
                                      I agree, stick with telnet + ftp for development and leave the serial connection for firmware upgrades and debugging.
                                      I do think you have too many serial drivers installed and active and - as they say, too many serial drivers in the kitchen spoils the broth - you'll need to actually disable or delete the ones you don't need.
                                      • sorenS Offline
                                        soren @robert-hh
                                        @robert-hh hi Robert, thanks for your reply.
                                        So I managed to get an FTP access up and running (awesome!!) but I also managed to try and change the server and wlan login credentials, which now resulted in the lopy not showing up as a wlan.. (well f*'** done soren).. so now I literally have no idea how to get access to my lopy with USB not working propperly.. any ideas ?
                                        EDIT
                                        did a factory reset, but this did not seem to change my boot and main files.. which means i still can't see the lopy on wifi
                                          robert-hh
                                          You could try the safe boot procedure https://docs.pycom.io/pycom_esp32/_downloads/wipy_pinout.pdf. But I'm not sure whether that brings you back to the standard WiFi credentials. I think so, but cannot remember, whethe rI've gone this path once.
                                          You mentioned to have tried Windows. You need the VCP driver von Windows too. But that should be less of a problem. The easient choice is Linux! You could try to boot a PC (or MAC?) with a Linux test image. Most distributions have images which you can boot from USB or DVD. Try Ubuntu, Lint or Knoppix.
                                            jmarcelino @soren
                                            @soren
                                            You really need serial working to recover properly.
                                            I suspect your problem is that AppleUSBFTDI.kext is overriding your other FTDI driver.
                                            There's also FTDIKext.kext - did you install more FTDI drivers in OSX other than the VCP by any chance?
                                            Try to disable AppleUSBFTDI manually by doing
                                            cd /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns
                                            sudo mv AppleUSBFTDI.kext AppleUSBFTDI.disabled
                                            and then restarting. This will prevent it from loading and might allow the correct one to work.
                                            EDIT That said I'm now more suspicious of the D2xxHelper you listed, let me know if you installed any more drivers from FTDI. You may need to disable more.
                                            sorenS 1 Reply Last reply Reply Quote 1
