Firmware update, not possible on either windows or mac osx...
@soren
Try looking in (Apple) menu -> About This Mac -> press System Report and then choose USB from the listIf your Mac can see the Expansion Board you'll have a device saying FT230X Basic UART , like this:
@jmarcelino yes, my mac see's the unit as a ft230x basic UART.
EDIT: I also tried a different USB cable now, just for the sake of excluding that.. no difference
@soren
Ok that looks good, so what do you get from als -l /dev/cu.*?Is there a line with
/dev/cu.usbserial-xxxxxxxx? (the xxxxxxxx part doesn't really matter)EDIT Also can you post the result of
kextstat -b com.FTDI.driver.FTDIUSBSerialDriver -
EDIT EDIT
Now it freakin works.. SOooo, there's a difference between vcp and the dxx ftdi drivers.. i did not know about the vcp before until just now. installing the vcp seems to be working now. also, i have currently unloaded the apple ftdi driver which might also be necessary but i'm not sure. phew, this is a rather frustrating process to go through.. thanks so much for the help @jmarcelino though!I don't see a cu.usbserial-xxxx... no, sorry. this is what i get:
crw-rw-rw- 1 root wheel 20, 3 Mar 23 10:41 /dev/cu.Bluetooth-Incoming-Port
crw-rw-rw- 1 root wheel 20, 5 Mar 23 10:41 /dev/cu.JabraStylev130-CSRGAIA
crw-rw-rw- 1 root wheel 20, 7 Mar 23 10:41 /dev/cu.iPhone-WirelessiAP
crw-rw-rw- 1 root wheel 20, 1 Mar 23 10:41 /dev/cu.lpss-serial2
here's my result of kextstat -b com.FTDI.driver.FTDIUSBSerialDriver:
list itemIndex Refs Address Size Wired Name (Version) UUID <Linked Against>
EDIT
so.. this looks like the ftdi driver is not being found at all, right? -
@soren
Yes it's not loading the driver for some reason. Can you post the result of:kextfind -case-insensitive -bundle-id -substring 'FTDI' -printto see if it's correctly installed and if there's any conflicts?
you can also try manually loading it with
sudo kextload -bundle-id com.FTDI.driver.FTDIUSBSerialDriver -
@jmarcelino said in Firmware update, not possible on either windows or mac osx...:
kextfind gives me:
/System/Library/Extensions/AppleUSBFTDI.kext
/Library/Extensions/D2xxHelper.kext
/Library/Extensions/FTDIKext.kext
/Library/Extensions/FTDIUSBSerialDriver.kextthis is so weird though. trying to unload the mac ftdi driver with:
sudo kextunload -b com.apple.driver.AppleUSBFTDI
just gives me:
Can't create –b.
Can't create com.apple.driver.AppleUSBFTDI. -
@jmarcelino
so, after being able to connect and I synced a project several times - now I suddenly am back to being unable to connect. I did not reboot my system.. It just tells me "invalid device address.." and the lopy doesn't show up in configurations.. this has got to be the most uneasy mcu i've ever dealt with -
Just saw your edit on the original post. Glad you got it working in the end!
Yeah USB serial drivers can be a confusing mess - and actually FTDI has some of the best drivers.
When you say: "synched a project", does thar mean you#re using Pymakr? If yes, don't do that. Pymakr simply adds another layer of strange issues. Better use basic tools, like an ftp client of your choice, screen or telnet, ...
There you have much better response, and if you have issues, the reason is obvious. -
I agree, stick with telnet + ftp for development and leave the serial connection for firmware upgrades and debugging.
I do think you have too many serial drivers installed and active and - as they say, too many serial drivers in the kitchen spoils the broth - you'll need to actually disable or delete the ones you don't need.
@robert-hh hi Robert, thanks for your reply.
So I managed to get an FTP access up and running (awesome!!) but I also managed to try and change the server and wlan login credentials, which now resulted in the lopy not showing up as a wlan.. (well f*'** done soren).. so now I literally have no idea how to get access to my lopy with USB not working propperly.. any ideas ?
EDIT
did a factory reset, but this did not seem to change my boot and main files.. which means i still can't see the lopy on wifi -
You could try the safe boot procedure https://docs.pycom.io/pycom_esp32/_downloads/wipy_pinout.pdf. But I'm not sure whether that brings you back to the standard WiFi credentials. I think so, but cannot remember, whethe rI've gone this path once.
You mentioned to have tried Windows. You need the VCP driver von Windows too. But that should be less of a problem. The easient choice is Linux! You could try to boot a PC (or MAC?) with a Linux test image. Most distributions have images which you can boot from USB or DVD. Try Ubuntu, Lint or Knoppix. -
@soren
You really need serial working to recover properly.I suspect your problem is that AppleUSBFTDI.kext is overriding your other FTDI driver.
There's also FTDIKext.kext - did you install more FTDI drivers in OSX other than the VCP by any chance?
Try to disable AppleUSBFTDI manually by doing
cd /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns
sudo mv AppleUSBFTDI.kext AppleUSBFTDI.disabledand then restarting. This will prevent it from loading and might allow the correct one to work.
EDIT That said I'm now more suspicious of the D2xxHelper you listed, let me know if you installed any more drivers from FTDI. You may need to disable more.
@jmarcelino Hey, OK so I think I got serial working now, but I still can't sync my project from pymakr... just keeps saying "syncing failed".. is this because there is already bootleader on the lopy? remember, I can't get into ftp because I tried changing wlan password which didn't work and now I can't connect to it.
@soren If serial is working in a sense that you get a REPL prompt with a serial terminal like screen, then you could try Adafruit's ampy tool or Dave Hylands' rshell (https://github.com/dhylands/rshell). They both are pretty generic and allow to exchange scripts with the board and run them. This way, you can also set your board again for ftp. The script I use on my LoPy to set it to station mode is:
import network import time # setup as a station wlan = network.WLAN(mode=network.WLAN.STA) wlan.connect(ssid=MY_SSID, auth=(network.WLAN.WPA2, MY_PASSWD)) while not wlan.isconnected(): time.sleep_ms(50) wlan.ifconfig(config=(MY_FIXED_IP, "255.255.255.0", MY_GATEWAY, MY_DNS)) print(wlan.ifconfig())Obviously, you have to set the proper values for MY_xxx. If you do not need a fixed address, you can skip the line with wlan.ifconfig()
@robert-hh thanks for the tip robert!
trying to connect my board with rshell now, and stuck at not knowing what "TYPE" or "TYPE_PARAMS" is supposed to mean in rshell.. the help method for connect method only says:
connect TYPE TYPE_PARAMS
connect serial port [baud]
connect telnet ip-address-or-nameEDIT:
Or the other parameters as well for that sake. I really don't understand when you make something like this, why not also make a good description and examples of everything. -
@soren
e.g.
connect serial /dev/cu.xxxxx 115200
or
rshell -p /dev/cu.xxxx -b 115200
/dev/cu.xxxx ist the name of your serial port. On my linux machine, it's /dev/ttyUSB0
Once connected, /flash shows the TLD of WiPY or Lopy.
It works OK for file transfer and management. That should bring you back to the point where ftp works. -
@robert-hh it just keeps saying "connecting..." forever..
wondering if, because i put the wlan stuff in boot.py if this could have hampered the ability to connect to the board ? I mean if what I wrote was wrong and also placed before the uart is initialized? -
Both rshell and ampy rely on a REPL prompt to be available. Did you try to connect with a simple serial terminal program like screen?
screen /dev/cu.xxxx 115200
Do you get the REPL prompt?
If not, then coding errors in boot.py before activating the UART may stop boot.py, and REPL on UART does not get active. Then, the step I would take is safe boot, which skips boot.py and main.py. Maybe that will set WiFi back to the initial state. -
@soren If you are able to update the firmware via USB, then you can co the hard way: : erasing the flash and reflashing the image. I just tried that with my LoPy. That works, erases everything in the device and brings back the REPL prompt on UART, which is set active in a hidden
_boot.py in flash, which is executed before boot.py. All that requires, that you can reflash your device. Erasing the flash is easy, of you have the source tree installed. Then just call:
make erase
But all it needs is esptool.py form the repository, and the command.
python3 ./esptool.py --chip esp32 --port /dev/cu.xxxx --baud 480800 erase_flash
Then you could reload the software, connect through UART and a simple terminal program and setup WiFi manually step by step, e.g. using the first four statement of my sample script below.
I have placed an esptool.zip archive here, which is just a copy of the tree from esp-idf. https://github.com/robert-hh/Shared-Stuff
