    Lopy sd card
    lopysdcard
    17 Posts 5 Posters 7.2k Views 5 Watching
      bessonf @livius
      @livius
      1. The card makes 32GB.
      2. The error is :
      File "main.py", line 1, in <module>
      ImportError: cannot import name SD
      1. I use an expansion board.
        livius @bessonf
        @bessonf
        strange
        but try this and back with results - i have only Wipy and can not check this on Lopy:
        help(machine)
        sd = machine.SD()
        and what is your firmware?
        os.uname()
          bessonf @livius
          @livius
          For help(machine) :
           help(machine)
          <module 'umachine'>object  is of type module
            __name__ -- umachine
            mem8 -- <8-bit memory>
            mem16 -- <16-bit memory>
            mem32 -- <32-bit memory>
            reset -- <function>
            freq -- <function>
            unique_id -- <function>
            main -- <function>
            rng -- <function>
            idle -- <function>
            sleep -- <function>
            deepsleep -- <function>
            reset_cause -- <function>
            wake_reason -- <function>
            disable_irq -- <function>
            enable_irq -- <function>
            Pin -- <class 'Pin'>
            UART -- <class 'UART'>
            SPI -- <class 'SPI'>
            I2C -- <class 'I2C'>
            PWM -- <class 'PWM'>
            ADC -- <class 'ADC'>
            DAC -- <class 'DAC'>
            PWRON_RESET -- 0
            SOFT_RESET -- 4
          And for os.uname() :
          >>> os.uname()
          (sysname='LoPy', nodename='LoPy', release='1.0.0.b1', version='v1.8.6-237-g9d21f17 on 2016-12-15', machine='LoPy with ESP32')
            livius @bessonf
            @bessonf
            you must upgrade your board firmware
            current version is
            release='1.6.9.b1'
            https://www.pycom.io/resources/
            you have really old one :release='1.0.0.b1
              bessonf @livius
              @livius
              It works thank you very much. I work on the LoPy for 2 weeks and I completely missed this ...
                assia @livius
                Hi @livius said in Lopy sd card:
                You must mout your SD card in boot.py
                you mean that we put in boot.py this:
                from machine import SD
                sd = SD()
                os.mount(sd, '/sd')
                and in the main.py we put the rest ?
                because i try it but it does not work i get an OSError in :
                f = open('/sd/test.csv', 'a')
                my main.py is in /flash and i have a csv file in /sd that I want to fill it every time.
                thanks
                  livius @assia
                  @assia
                  Which error do you get?
                  And what you get after:
                  os.listdir('/sd')
                    assia @livius
                    @livius
                    File "main.py", line 9, in <module>
                    OSError: [Errno 2] ENOENT
                    and line 9 is: f = open('/sd/test.csv', 'a')
                    os.listdir('/sd')
                    I get empty list
                      jmarcelino @assia
                      @assia
                      What's the storage size of the SD card?
                      Larger cards tend to be pre-formatted as exFAT which is not enabled in the default Micropython configuration (as Microsoft demands a patent license)
                        assia @jmarcelino
                        Hi @jmarcelino the storage size is 2 Go and i had formatted it as FAT32.
                        I have already managed to write in this card by executing the commands directly into the pycom console in pymakr but now as I want to execute it in main.py I do not succeed.
                        thanks
                          jmarcelino @assia
                          @assia
                          Thanks, so f = open('/sd/test.csv', 'a') works from the REPL (python console) but not in main.py?
                          Does changing 'a' to 'w' in the open(...) mode change anything (other than that the file will be empty again with each open)
                            assia @jmarcelino
                            @jmarcelino
                            I put the code in main.py :
                            sd = SD()
                            os.mount(sd, '/sd')
                            it worked but just the first time also in REPL and when I restart my lopy I get:
                            OSError in os.mount(sd, '/sd') like:
                            OSError: the requested operation is not possible
                            I suppose that the SDcard remains mounted and we can not mount it a second time in this case we must check if it is already mounted and then writing on it
                              barsznica @livius
