    Lopy sd card
    lopysdcard
    17 Posts 5 Posters 7.2k Views 5 Watching
      livius @bessonf
      @bessonf
      strange
      but try this and back with results - i have only Wipy and can not check this on Lopy:
      help(machine)
      sd = machine.SD()
      and what is your firmware?
      os.uname()
        bessonf @livius
        @livius
        For help(machine) :
         help(machine)
        <module 'umachine'>object  is of type module
          __name__ -- umachine
          mem8 -- <8-bit memory>
          mem16 -- <16-bit memory>
          mem32 -- <32-bit memory>
          reset -- <function>
          freq -- <function>
          unique_id -- <function>
          main -- <function>
          rng -- <function>
          idle -- <function>
          sleep -- <function>
          deepsleep -- <function>
          reset_cause -- <function>
          wake_reason -- <function>
          disable_irq -- <function>
          enable_irq -- <function>
          Pin -- <class 'Pin'>
          UART -- <class 'UART'>
          SPI -- <class 'SPI'>
          I2C -- <class 'I2C'>
          PWM -- <class 'PWM'>
          ADC -- <class 'ADC'>
          DAC -- <class 'DAC'>
          PWRON_RESET -- 0
          SOFT_RESET -- 4
        And for os.uname() :
        >>> os.uname()
        (sysname='LoPy', nodename='LoPy', release='1.0.0.b1', version='v1.8.6-237-g9d21f17 on 2016-12-15', machine='LoPy with ESP32')
          livius @bessonf
          @bessonf
          you must upgrade your board firmware
          current version is
          release='1.6.9.b1'
          https://www.pycom.io/resources/
          you have really old one :release='1.0.0.b1
            bessonf @livius
            @livius
            It works thank you very much. I work on the LoPy for 2 weeks and I completely missed this ...
              assia @livius
              Hi @livius said in Lopy sd card:
              You must mout your SD card in boot.py
              you mean that we put in boot.py this:
              from machine import SD
              sd = SD()
              os.mount(sd, '/sd')
              and in the main.py we put the rest ?
              because i try it but it does not work i get an OSError in :
              f = open('/sd/test.csv', 'a')
              my main.py is in /flash and i have a csv file in /sd that I want to fill it every time.
              thanks
                livius @assia
                @assia
                Which error do you get?
                And what you get after:
                os.listdir('/sd')
                  assia @livius
                  @livius
                  File "main.py", line 9, in <module>
                  OSError: [Errno 2] ENOENT
                  and line 9 is: f = open('/sd/test.csv', 'a')
                  os.listdir('/sd')
                  I get empty list
                    jmarcelino @assia
                    @assia
                    What's the storage size of the SD card?
                    Larger cards tend to be pre-formatted as exFAT which is not enabled in the default Micropython configuration (as Microsoft demands a patent license)
                      assia @jmarcelino
                      Hi @jmarcelino the storage size is 2 Go and i had formatted it as FAT32.
                      I have already managed to write in this card by executing the commands directly into the pycom console in pymakr but now as I want to execute it in main.py I do not succeed.
                      thanks
                        jmarcelino @assia
                        @assia
                        Thanks, so f = open('/sd/test.csv', 'a') works from the REPL (python console) but not in main.py?
                        Does changing 'a' to 'w' in the open(...) mode change anything (other than that the file will be empty again with each open)
                          assia @jmarcelino
                          @jmarcelino
                          I put the code in main.py :
                          sd = SD()
                          os.mount(sd, '/sd')
                          it worked but just the first time also in REPL and when I restart my lopy I get:
                          OSError in os.mount(sd, '/sd') like:
                          OSError: the requested operation is not possible
                          I suppose that the SDcard remains mounted and we can not mount it a second time in this case we must check if it is already mounted and then writing on it
                            barsznica @livius
