    DHT 11 sensor always return same value
    dht11lopypycom
    16 Posts 4 Posters 5.9k Views 5 Watching
      robert-hh @jmarcelino
      @jmarcelino The loop is a little bit slower than 1-2µs, because the loop management needs time too. But that has to be determined. So without real timing testing cou cannot get any results. There were people who managed to get this type of code working on ESP8266.
      Nevertheless, knowing about the irreular timing of the esp devices, it's better to use sensors with a stanard communication method.
        jmarcelino
        Just noticed the original poster is also using G4 (P14) which is an input-only pin, so trying to set it high dht_pin(1) does nothing. This means the DHT11 is not initialising.
          @jmarcelino Right, that's whatI wanted to check too. But at that point the docs at machine.pin should spend a few words about it. Normal users would not look into the esp32 data sheet.
            jmarcelino @robert-hh
            You don't need to look into the esp32 data sheet, it's on the LoPy pinout map with a red warning sign: https://docs.pycom.io/pycom_esp32/_downloads/lopy_pinout.pdf
            "Only Input pins!"
            The pinout map should really be required reading for everyone. Maybe the text could be made larger.
            By the way I tested the loop - you are absolutely right I was overlooking the loop and memory access involved - each cycle takes about 20 μS. So perhaps 1200 samples could be enough.
              @jmarcelino If a cycle takes 20 µs, and the actual reading time is less than 5 ms (160 µs lead in and 40 bits at 120µs worst case), then 250 samples are sufficient. So with 300 takes the buffer is large enough. So taking the wrong Input is the first thing to change.
                Good catch, I was going by the datasheet which states 23ms for a read, but that includes the initial delay already accounted for in the code.
                So in summary @bihut :
                -Change power supplt to 3.3v
                -Use another Pin that isn't input only (so don't use G5, G4, G0, G3, G31, G30)
                  robert-hh @bihut
                  @bihut I gave your code a try, and as @jmarcelino saidm
                  • the port was wrong, and
                  • the first trailing 0/1 change was not detected because python was busy with changing functions.
                    The attached code works with my AM2302, which is identical to DHT22.
                  from machine import enable_irq, disable_irq,  Pin
                  _LIMIT = const(8)
                  _BUFFERSIZE = const(1000)
                  def getval(pin) :
                      ms = [1] * _BUFFERSIZE
                      pin(0)
                      time.sleep_us(20000)
                      pin(1)
                      irqf = disable_irq()
                      mslen = len(ms)
                      for _ in range(mslen):
                          ms[_] = pin()      ## sample input and store value
                      enable_irq(irqf)
                      return ms
                  def decode(inp):
                      res= [0]*5
                      bits=[]
                      ix = 0
                      try:
                          if inp[0] == 1 : ix = inp.index(0, ix) ## skip to first 0
                  #        ix = inp.index(1,ix) ## skip first 0's to next 1
                  #        ix = inp.index(0,ix) ## skip first 1's to next 0
                          while len(bits) < len(res)*8 : ##need 5 * 8 bits :
                              ix = inp.index(1,ix) ## index of next 1
                              ie = inp.index(0,ix) ## nr of 1's = ie-ix
                              bits.append(ie-ix)
                              ix = ie
                      except Exception as err:
                          print (err, ix, len(bits))
                          return([0xff,0xff,0xff,0xff])
                      for i in range(len(res)):
                          for v in bits[i*8:(i+1)*8]:   #process next 8 bit
                              res[i] = res[i]<<1  ##shift byte one place to left
                              if v > _LIMIT:
                                  res[i] = res[i]+1  ##and add 1 if lsb is 1
                      if (res[0]+res[1]+res[2]+res[3])&0xff != res[4] :   ##parity error!
                          print("Checksum Error")
                          res= [0xff,0xff,0xff,0xff]
                      return(res[0:4])
                  def DHT11(pin):
                      res = decode(getval(pin))
                      temp = 10*res[0] + res[1]
                      hum = 10 * res[2] + res[3]
                      return temp, hum
                  def DHT22(pin) :
                      hum = res[0]*256+res[1]
                      temp = res[2]*256 + res[3]
                      if (temp > 0x7fff):
                          temp = 0x8000 - temp
                      return temp, hum
                  dht_pin=Pin('G7', mode=Pin.OPEN_DRAIN)
                  dht_pin(1)
                  temp, hum = DHT11(dht_pin)
                  temp_str = '{}.{}'.format(temp//10,temp%10)
                  hum_str = '{}.{}'.format(hum//10,hum%10)
                  # Print or upload it
                  print(temp_str, hum_str)
                  It matches with a 10% difference with two cheap commercial temp/humidity devices I have, but I cannot tell which is right or wrong
                  Update: After an hour of settling, the two sensors show almost identical readings.
                    robert-hh @robert-hh
                    @robert-hh A slight re-arrangement of lines in getval() made the capture get the leading '0' bit. That also tells how critical the timing is. Still, even with IRQ disabled, sometimes transitions are missing.
                    _LIMIT = const(8)
                    def getval(pin) :
                        mslen = len(ms)
                        pin(0)
                        pin(1)
                        enable_irq(irqf)
                        return ms
                    def decode(inp):
                        res= [0]*5
                        bits=[]
                        ix = 0
                        try:
                            if inp[0] == 1 :
                                bits.append(ie-ix)
                                ix = ie
                                if v > _LIMIT:
                        return(res[0:4])
                    def DHT11(pin):
                        temp = 10 * res[0] + res[1]
                        return temp, hum
                    def DHT22(pin) :
                        if (temp > 0x7fff):
                        return temp, hum
                    def run():
                        dht_pin(1)
                    run()
                    • Jurassic PorkJ Offline
                      Jurassic Pork
                        Jurassic Pork @jmarcelino
                        hello,
                        if someone can try my dht11 class and say me if it works for him.
                        It seems to be OK with a SiPy powered with USB .
                        DHT11_PyCom
                        Friendly, J.P
