    I2C accelerometer model MMA7455
    lopyi2csensormma7455i2c bus error
    25 Posts 4 Posters 10.8k Views 4 Watching
      livius @pablocaviglia
      @pablocaviglia
      try this instead
      data = i2c.readfrom_mem(SlaveAddress, 0x00, 1)
        pablocaviglia @livius
        @livius said in I2C accelerometer model MMA7455:
        Well... at least something changed!
        0_1494434698826_upload-1a5aab5e-1c1b-4e15-ac31-447f2d581053
        The 0000000 at the end is the way i found to show the byte in binary string. Btw is this way correct to do that ?
        def byteToBitArrayString(rcv):
        bitArrayStr = "1" if rcv&0 != 0 else "0"
        bitArrayStr += "1" if rcv&1 != 0 else "0"
        bitArrayStr += "1" if rcv&2 != 0 else "0"
        bitArrayStr += "1" if rcv&3 != 0 else "0"
        bitArrayStr += "1" if rcv&4 != 0 else "0"
        bitArrayStr += "1" if rcv&5 != 0 else "0"
        bitArrayStr += "1" if rcv&6 != 0 else "0"
        bitArrayStr += "1" if rcv&7 != 0 else "0"
        return bitArrayStr
          @pablocaviglia
          for bin formatthing use:
          >>> bin(5)
          '0b101'
          >>> "{0:b}".format(5)
          '101'
          to see more in memory
          data = i2c.readfrom_mem(SlaveAddress, 0x00, 5) #increase value to 5 bytes from memory
          and look what you get
          P 1 Reply Last reply Reply Quote 1
            "{0:b}".format(5)
            Uhhh good, looks much better than my awful function :D jajaja, sorry for breaking your eyes but didnt know that
              pablocaviglia
              @jmarcelino @livius @robert-hh
              Hey all, thx a lot for helping me this last days with this driver. This is the code i have until now... it's a shame that i didn't make it, but i think that i could have broken the sensor when i plugged CS to 5v instead of 3V3.
              I think i will buy another one, that will take some weeks until it gets to Uruguay :P
              Anyway, this is the code we've made until now, maybe it's useful for someone else. It's not throwing the ugly i2c bus error anymore, but the device id registry is returning always zero, and that's bad... not sure if the device is broken or what, but comparing this code with the implementation @livius has referenced, and with other implementations i found on google for other languages, it looks like the retrieval of the device id is the first action almost everyone does, so... i dont know.
              from machine import I2C
              from machine import Pin
              from machine import Timer
              def DelayUs(us):
              Timer.sleep_us(us)
              #i2c slave address
              SLAVE_ADDRESS = 0x1D
              #registers
              REG_POWER_CTL = 0x2D
              REG_BW_RATE = 0x2C
              #connected to SDO and CS of MMA7455
              CS = Pin("P23", mode=Pin.OUT)
              CS.value(1)
              CS.hold()
              DelayUs(1000)
              #main
              i2c = I2C(0, I2C.MASTER, baudrate=100000)
              print(i2c.scan())
              def setPowerCtrl(measure, wake_up=0, sleep=0, auto_sleep=0, link=0):
              power_ctl = wake_up & 0x03
              if sleep:
              power_ctl |= 0x04
              if measure:
              power_ctl |= 0x08
              if auto_sleep:
              power_ctl |= 0x10
              if link:
              power_ctl |= 0x20
              i2c.writeto_mem(SLAVE_ADDRESS, REG_POWER_CTL, bytes([power_ctl]))
              #******* main logic **********
              data = i2c.readfrom_mem(SLAVE_ADDRESS, 0x00, 1)
              print("DEVID: " + str(bin(data[0])))
              #set power characteristics
              setPowerCtrl(1, wake_up=0, sleep=0, auto_sleep=0, link=0)
              • 1
              • 2
              • 2 / 2
