    [Solved] Power consumption deep sleep Pysense/Pytrack
    pysensedeepsleepdeep sleeplopypytrack
    24 Posts 8 Posters 11.7k Views 10 Watching
      Pwntus
      Hi.
      We've done some testing with a multimeter and the Pysense shield.
      LoPy firmware: 1.7.6.b1
      Pysense firmware: 0.0.3
      Our test program disabled WiFi in boot.py and ran a 30s normal sleep (time.sleep()) and a 30s deep sleep (py.setup_sleep(30) + py.go_to_sleep()).
      Here's our results:
      USB power
      Normal sleep: ~50-60mA
      Deep sleep: ~8mA
      3.7V LiPo battery
      Normal sleep: ~40mA
      Deep sleep: ~2.5mA
      According to the specs, this should not be normal.
      Anyone else experiencing similar issues?
      Solution:
      Update firmware and use latest library.
      B 1 Reply Last reply Reply Quote 2
        jmarcelino
        Are you going into deep sleep using the Pysense calls?
        py = Pysense()
        py.setup_sleep(SLEEP_TIME)
        py.go_to_sleep()
          this.wiederkehr
          I guess it is due to the peripherals (all the sensors) which are not put into standby. also see the following post regarding the gps on the pytrack.
          https://forum.pycom.io/topic/1409/power-consumption-on-pytrack-with-sipy
            jubbs
            I am getting the same results. Latest PySense Library. Testing on 5v Input. Looks like we need to disable all the peripherals but I was hoping the PySense library would do that. This thing not sleeping well is causing me to not sleep well. Is that irony?
            main.py
            from pysense import Pysense
            time.sleep(10)
            py = Pysense()
            py.setup_sleep(30)   # setup a 10 seconds sleep time
            py.go_to_sleep()
            boot.py
            from network import WLAN
            from network import Bluetooth
            from machine import UART
            import os
            uart = UART(0, 115200)
            os.dupterm(uart)
            wlan = WLAN()
            wlan.init(mode=WLAN.STA)
            wlan.deinit()
            bt = Bluetooth()
            bt.deinit()
            • E Offline
              Emmanuel Goudot
              According to specs of pytrack peripherals,
              GPS (Quectel L76-L):
              acquisition/tracking : 22/29mA
              standby: 0.5mA (after sending "$PMTK161,028\r\n")
              backup: 7µA
              Accelero (LIS2HH12):
              Normal: 50µA (ODR 10Hz)
              Power down: 5µA
              After setup_sleep(30) and go_to_sleep(), are GPS & LIS still powered ?
              What is the PIC doing concerning them with CMD_SETUP_SLEEP & CMD_GO_SLEEP ?
                Pwntus
                Thanks for the replies @jubbs @this-wiederkehr @jmarcelino
                It has been suggested that the peripherals are not put into "standby" while in deep sleep.
                Shouldn't this be done by the Pysense/Pytrack by default? In addition, we do not initialize/use any peripherals in our test program.
                We did some more testing with the Pytrack shield.
                Pytrack firmware: 0.0.3
                Our test program disabled WiFi and Bluetooth in boot.py and ran a 30s normal sleep (time.sleep()) and a 30s deep sleep (py.setup_sleep(30) + py.go_to_sleep()).
                Here's our results:
                USB power
                Normal sleep: ~75-80mA
                Deep sleep: ~5.3mA
                3.7V LiPo battery
                Normal sleep: ~73mA
                Deep sleep: 18μA (!)
                It seems like the Pytrack gives acceptable readings while using a 3.7V LiPo battery while the Pysense still has some issues.
                  dbrgn
                  I can confirm that the pysense does not seem to properly go into deep sleep.
                  On a 3.7V LiPo, it still pulls 2.7mA in deep sleep mode. (Note, the USB cable in the photo below is not connected to any power source.)
                  photo of multimeter
                  Pysense firmware is at 0.0.3.
                  • B Offline
                    bucknall @Pwntus
                    @Pwntus (+ others) Thanks for raising this! We're now investigating this, it appears that the issue only pertains to the the Pysense. Thanks for your patience!
                    Developer Evangelist - Pycom
                    J 1 Reply Last reply Reply Quote 3
                      jcaron @bucknall
                      @bucknall Hi,
                      Have you made any progress on this? Any idea if this is hardware-related or just a firmware issue yet?
                      Thanks!
                      P 1 Reply Last reply Reply Quote 1
                        Pwntus @jcaron
                        @jcaron issues with the Pysense should be fixed in the pysense_0.0.4.dfu firmware release, but we have yet to test it. I'll post the results tomorrow.
                          jcaron @Pwntus
                          @Pwntus Ah, wondered about that, but didn't see anything in the chagelog that seemed to be related. Thanks for the (very) quick reply!
                          • B Offline
                            bucknall @jcaron
                            @jcaron @Pwntus I'll double check with Daniel regarding the power concerns. I'll confirm if this is correct (I'm London based - Daniel works from the Netherlands).
                              Pwntus
                              @jcaron @bucknall (+ others) here's our new (unofficial) Pysense test.
                              Pysense firmware: 0.0.4
                              Here's our results:
                              USB power
                              Normal sleep: ~57.2mA
                              Deep sleep: ~7.35mA
                              3.7V LiPo battery
                              Normal sleep: ~49.1mA
                              Deep sleep: 2.2mA
                              It still appears that the Pysense has issues with deep sleep.
                              • B Offline
                                bucknall @Pwntus
                                @Pwntus Ok I'll feed this back to Daniel again - apologies for getting your hopes up - I'll keep you in the loop with how this progresses.
                                Thanks for your patience,
                                Alex
                                  jmarcelino @bucknall
                                  I saw the same results for the Pysense as @Pwntus
                                  Also noticed that if you used the MPL3115A2 pressure sensor (not sure about the others) it goes into deep sleep with it in active mode increasing consumption by about 1mA. But I think this one can be solved in the Python library by setting MPL3115_CTRL_REG1 to 0x0 (to clear SBYB bit in CTRL1 register)
                                  mp = MPL3115A2(py)
                                  mp.i2c.writeto_mem(MPL3115A2.MPL3115_I2CADDR, MPL3115A2.MPL3115_CTRL_REG1, bytes([0x0]))
                                  before entering deep sleep.
                                  B E 2 Replies Last reply Reply Quote 1
                                  • B Offline
                                    bucknall @jmarcelino
                                    @jmarcelino Ah good catch! I'll test this out - Thanks!
                                      @bucknall
                                      Just to be clear that 1mA is on top of the lingering 2mA... I'm not sure what's causing that one yet :)
                                      • E Offline
                                        Emmanuel Goudot @jmarcelino
                                        @jmarcelino Are you sure sensors on the PySense are powered during deepSleep ?
                                        I have done tests on pytrack, and it looks like 3.3V is 'cut' for LoPy, LIS(accel) & GPS, explaining the ~17µA of the pytrack during deepsleep.
                                          jmarcelino @Emmanuel Goudot
                                          @Emmanuel-Goudot
                                          I see 2.6V on the MPL3115A2 Vdd pin during deep sleep so I guess it is active, for example on the Si7006-A20 (temp/humidity) I don't.
                                          My best guess is certain sensors can act as wake-up sources (e.g. pressure going above/below threshold) so they have separate power nets.
                                            dbrgn
                                            Is there any ETA on the deep sleep fix? This is delaying the shipping of one of my projects. We simply can't send it to the customer if the battery only lasts a few days or weeks.
                                            • 1
                                            • 2
                                            • 2 / 2
