Memory leak using timers
  • Hello,
    LOPY 1.7.9.b3.
    if you run the below code, you will see that after many loops it will raise "memory error". To reproduce in fastest way set SLEEP= 0.5. Same is with gc.enable().
    import gc
    import utime
    from machine import Timer
    class Object:
        def __init__(self, count=0):
            print ("Object INIT ", self)
            self._timer = Timer.Alarm(self._timerCallback, 0.5, periodic=False)
        def __del__(self):
            print ("Object DEL ", self)
        def _timerCallback(self, timer):
            print("Timer finish " ,  self)
            self._timer.cancel()
            del self._timer
            self._timer = None
    print("Start memory %s" %(gc.mem_free()))
    SLEEP = 1.5
    gc.disable()
        obj = Object(100)
        utime.sleep(SLEEP)
        gc.collect()
        print("\t\tmemory %s" %(gc.mem_free()))
  • The issue was posted on github.
  • @Colateral
    The most effective place to post bug reports is at https://github.com/pycom/pycom-micropython-sigfox/issues
    The forum is mostly to discuss such bugs, since there's no issue tracking.
