    Memory leak using Pin (callback)
    memoryleaklopy
    1 Posts 1 Posters 776 Views 1 Watching
      Colateral
      LOPY 1.7.9.b3.
      If you run this piece of code you will see that memory is decreasing ... in the end it stops with 'MemoryError: memory allocation failed' . Comparing to timer memory leak issue, I believe there is ALWAYS a LEAK when you are using function callbacks.
      import gc
      import utime
      from machine import Pin
      class Object:
          def __init__(self):
              print ("Object INIT ", self)
          def start(self):
              def _call(arg):
                  print('PIN changed')
              self._analogPin=Pin('P15',mode=Pin.IN,pull=Pin.PULL_UP)
              self._analogPin.callback(Pin.IRQ_FALLING , _call)
          def __del__(self):
              print ("Object DEL ", self)
          def stop(self):
              self._analogPin.callback(Pin.IRQ_FALLING , None)
              del self._analogPin
              self._analogPin = None
      print("Start memory %s" %(gc.mem_free()))
      SLEEP = 0.1
      gc.enable()
          obj = Object()
          obj.start()
          utime.sleep(SLEEP)
          obj.stop()
          del obj
          obj = None
          gc.collect()
          print("\t\tmemory %s" %(gc.mem_free()))
